DIY Rock Tumbler
185,614
216
21
My wife recently started making beads and other things from polymer clay, and wasn't getting quite the finish she wanted using sandpaper.  It turns out that even children's toy rock tumblers are relatively expensive and the professional models are definitely out of our price range, so she asked me to see if I could assemble something from old bits and pieces we had laying around.
The kind of tumbler I've seen before seemed like a fairly simple arrangement - some kind of barrel turned by horizontal rollers, similar to a tumble dryer, so that's what I set out to build.
Step 1: Parts List
Parts list - these parts all came from my junk pile. Nothing was purchased for this project, so technically it cost $0 to build. As suggested by several people (iceng and ottwafm), the tumbler would be more durable if some kind of wheel bearings were used for the rollers. Bearings for skate board wheels or ride-on mower decks should be easy to find locally.
1) electric motor from Grand Am electric window lifter.
2) old PC power supply. This one happens to be a 90W supply.
3) rollers - could be broom handle or any round pole. These are actually mini rolling pins from my wife's craft supplies.
4) various bits of wood to make a frame and base board.
5) 2 inches of garden hose.
6) power switch.
7) screws, coach bolts w/ nuts
8) anti-slip shelf liner
Tools required:
1) Saw
2) Screwdriver
3) Drill + appropriate sized bits
4) Wrench
5) Sharp knife
6) Soldering iron (or use crimp-on spade connectors)
Step 2: Initial Sizing
Cut several length of plank to make the ends of the frame, then stand them in their approximate locations.  The position of the driven roller depends on the size of the motor mount.  The position of the other roller is variable, depending on the size of the drum.  The rollers here are 5" apart on centers.  Later I decided to add a third roller at 3.5" to accomodate smaller drums.
Step 3: Motor Mount
The holes for the rollers are somewhat oversized.  This should eliminate binding and the weight of the drum will hold the rollers down.  The large hole is for the garden hose that connects the drive shaft to the roller.
The motor is built into its own mount, which is offset from the side of the motor, so I cut a shim out of a piece of scrap plywood.
Step 4: Static End
The static end just has holes for the rollers.  The slot above the middle hole allows the roller to be removed when a larger drum is being used.  In fact, a single non-driven roller could be used, with multiple slotted holes to suit different drums.
Step 5: Check the Spacing
The spacing between the ends depends on both the size of drum and the available rollers.  These are ready-made rolling pins, but broom handle or other round stock could be cut to length.
Step 6: Frame Assembly
After measuring the separation for the ends, rails are cut and attached.  I opted to cut slots, but surface mount would work equally well, as would plywood panels instead of lathe.
Mount the motor along with the driven roller.  I used coach bolts, which present a rounded head in the roller section.
The roller ends have a small amount of furniture finishing wax applied, to reduce friction in the holes.
Step 7: Wiring
Take a look at the PC power supply cabling.  There should be a single green wire going into the big connector block.  That's the "power on" wire - it enables the motherboard to switch off the power supply when the PC shuts down.  Clip that wire and one of the nearby black (ground) wires.  Connect those to the power switch (any switch will do).  I soldered mine rather than buying spade connector clips.
Next, take one of the flat, 4 pin connectors and clip off the yellow (12 volt) and black (ground) wires.  Solder those to the motor.  I cut away the connector shroud to be able to get the soldering iron into it.  Again, spade connectors would work, as would the proper connector if available.
Plug in the power supply, flip the switch and watch the roller turn!
Step 8: Tidying Things Up a Bit
1) clip off remaining wires.  I wrapped each end in tape, then bundled them with more tape.
2) screw the frame to the baseboard.
3) secure the power supply.  I had a length of pipe hanging strap available, which also sufficed to hold the power switch.  I oriented the power supply with the fan blowing towards the motor to provide cooling.
4) I had some spare storage drawers that just happen to fit nicely on the other end of the base board.
5) tests showed that the barrel would sometimes slip, which is why the rollers are now covered in anti-slip shelf liner.
Step 9: Finished Product
All done!
Step 10: Test Run on Assembled Frame
First trial run - the glass jar originally contained a candle.  It has a plastic ring that makes a good, tight seal.  The jar contains a few beads and a slurry of water and sand.  This would eventually achieve the desired result, but it demonstrated the need for some kind of internal vanes to "lift" the mix as the container rotates.
3 People Made This Project!
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
  • Fandom Contest
    Fandom Contest
21 Discussions
kootenayboy.diy
Tip 6 weeks ago on Step 8
you can add skateboard wheel bearings to the spindles to decrease heat (fire risk) and increase the efficiency just drill a hole the circumference and depth the size of the bearings enough to counter sink them adjust the spindle diameter to fit inside the bearing hole and viola. Great project by the way very simple and effective.
Really great instructions Well done I've got the parts to make one but I'm going to use steel bars on small bearing's but your idea is brill john
LiamOSM
5 years ago on Introduction
I'm going to try and make a rock tumbler using one of those 120v motors from microwaves that turn at ~30rpm.
tacamaralLiamOSM
Reply 4 years ago on Introduction
I tried that - the problem is that it's so slow that the jar will do two or three revolutions per minute, so it will take forever to polish anything.
What I then did was connecting the motor through a flexible steel shaft to the cover of the jar. It works, but it's not as simple and functional as this one.
ottawafm
4 years ago
I agree with iceng. Try using skateboard wheel bearings. Or something similar.
dontrememberottawafm
Reply 4 years ago
Yes, some kind of wheel bearings would definitely be a good idea. At the time of building, I had a minimal budget to work with, and was really happy to be able to complete the assembly for $zero outlay. As it happens, the tumbler was used for less than two weeks, and has been gathering dust since. I have updated the parts list to suggest wheel bearings for durability.
iceng
Running 4 tumblers 24/7. I loose a tumbler with good bearings every few months for some mechanical reason or motor.
Your Ible is well presented and made however wood on wood even with lubrication will not long last.
See if you can modify it to use a bearing for conger life.
dontremembericeng
Thank you for the suggestion. I would probably fit some kind of ball-bearing races if it ever needs upgrading. However, right now it is barely being used at all, and the original dry sockets are holding up OK.
m6255
5 years ago
Awsome. I have a different use. I have a whole lot of ammunition brass I want to sell but needs to be cleaned. I had a vibratory cleaner that burned out. Then I saw online people using Thumblers Tumbler with number 47 stainless steel pins. It's in water with a few tablespoons of dish soap. The results were better than anything I did with my dry media and vibrator. When I looked to purchase the tumbler they were anywhere from 100 to 250 and up. 5 pounds of pins around 30 bucks. This invention will work wonderfully except I'm worried how the coffee can will hold up with all that brass and pins rolling around in there. Anyone use one of these for this?
agrodolcem6255
I'm going to make one for jewelry and my husband may use it for his brass. I was looking around on YouTube and saw someone using a big thermos. That's what I'm gonna try. They're pretty thick so I think it'll be fine.
dontrememberm6255
Reply 5 years ago on Introduction
You could equally well use something like a paint can, those generally fit tight enough to need a mallet to close. Any tube with a screw top would work too - a strip of duct tape would help stop it unscrewing. Once you find an appropriate container, you can size the frame to fit. Also, you'll want to pick a motor that can drive the weight without running too hot, and make sure the rollers don't bind. You could even pick up some cheap ball bearing races for the rollers.
spark master
7 years ago on Step 8
excellent project. I only suggest (unless another beat me to it) you can coat the rollers with silicone rubber in a tube (if you have left over from something else), or even several coats of rubber cement or rubber inner tube sleeves..
but use wut ya got!
verra nice indeed
dontrememberspark master
Reply 7 years ago on Step 8
Thank you! As it happens, we had a couple of yards of rubber shelf liner available, so that's what was used.
My wife has tried a number of different things, from play sand slurry down to small dry squares of fine sand paper and denim. I'm not sure which produced the best results. I suppose it depends partly on how smooth the beads are to start with.
gloflyer
7 years ago on Introduction
Totally awesome job. I have a VERY expensive rock tumbler, but needed an extra barrel. I tried the folger's coffee can, but it did not turn reliable. Now I will try adding the shelf liner. It was a big DUH when i saw what you did.
A few tips: Normally you would use tumbling grit instead of sand. I am going to assume that the beads are already reasonably shaped, you just want to add a polish, so a finer grit or even a polish should work fine.
There is way too much sand. Depending on the size of container, back it off to a few tablespoons of grit, and then fill it up about 1/2 way with water.
You do not need any vanes. If you get the slurry to the right consistency, it will slide as needed on its own.
Good luck and let us know how it works.
P.S. A lot of folks use a thin coat of Future floor wax on the beads, and then bake them gently in a low oven.
dontremembergloflyer
Thanks!! I give my wife credit for the shelf liner - I thought maybe just wrapping the rollers would work, but she went ahead and wrapped the barrel too, which works substantially better.
ichibon
7 years ago on Step 4
this is such an awesome project. i will inddeed give it a go. 5/5 from moi.
rimar2000
Very good work!
Yes, to add vanes is a need. But it is an easy task, now.
