DIY SURVIVAL CONTAINERS FROM CO2 CARTIGES
23,483
228
21
I recently got some empty co2 cartiges from a friend of mine. After keeping them in my workshop for a year, I had the idea of transforming them into small containers, that are really resistant, and can serve you as extra airsoft pellets tanks or as containers to keep your money when camping.
Step 1: Watch the Video
You can watch the video here (if the video above does not work) : https://youtu.be/KRZ1vxZrKHE
Step 2: What You Will Need:
You will need these tools:
_a hacksaw
_a drill
_a vice
_sandpaper
_a dremel (if you dont have one, you can use sandpaper)
You will also need these materials:
_an empty CO2 cartige
_some glue
_the cap of an apple compote bottle / baby food bottle
_a keyring
Step 3: Sanding
To start, sand down the text that is on the cartige. If you use a drill, it will give your cartige also a nice industrial look.
Step 4: Sawing
Saw your cartige in half at about two thirds of it's size.
Step 5: Processing the Cap of the Compote Bottle
Snip off the cap of the compote bottle and sand it like shown in the video. At the end, the cap should fit in the co2 cartige.
Step 6: Gluing
Glue the two parts of the compote bottle and the cartige together, so, that you get two pieces that can be screwed together.
Step 7: Drilling the Hole for the Keyring and Adding It (the Keyring)
Drill a hole in the upper part of the cartige, so, that it penetrates it from the two sides. After that, add the keyring.
Step 8: SUCCESS!!
Congratulations! You just created a small weather resistant container, that can save your life in the wild nature! Now let go outside and test it out! :D
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    21 Discussions
    Wild rose uk
    2 years ago
    WOW!! That's excellent!
    We have lots of empty cartridges. We had planned to scrap them when we had enough. And using yogurt pouches is clever if you do not have the tools. Hope they take metal pellets and the necks on ours seems to be smaller.
    Will post when had a go.
    kceddygilbequick
    Reply 2 years ago
    i think the author is using the cap from a squeezable apple puree 'bottle'
    in the states there is a brand called go go squeezers
    gwaligorski
    2 years ago
    I think if you use the cap the other way it would be waterproof. Not sure if that is possible but, I like the idea of a waterproof pill container.
    Using the cap the other way will not make it waterproof, cause there's also a hole :( But to make the container waterproof, you must just add some hot glue to the top part!
    I noticed your cut the green cap and put it in the larger portion of the CO2 container. If you put it the other way and didn't cut the top would that work? I don't know the fitment beside what I saw in the video so I was just asking. A little hot glue to the top in your way would also waterproof it but, was just curious if it would work.
    I put the green cap in the bigger part, cause it's diameter is smaller, so you can put bigger things inside. But yes, if you dont saw the green cap in half and put it the other way, the container will be waterproof! :D
    twbishop
    2 years ago
    Snip off the cap of the compote bottle? What part is this? Thanks
    doo da do
    2 years ago
    If made waterproof you could put medicine in it
    4DIYers
    2 years ago
    Now this is cool!
    flaming fox
    2 years ago
    the video is cool because you can carry bb gun bullets but it is to small so the bb gun container is much better than the co2 container
    trustmefada
    2 years ago
    video not working on my app and the link isnt working, can you paste the video title?
    seamster
    2 years ago
    Very cool, I love the finished look! :)
