DIY Sandblasting Cabinet and Etching Glass
41,608
534
38
About: http://www.youtube.com/c/AndrewWorkshop
This is a really simple but effective project for a DIY sandblasting cabinet. I wanted to etch some glass so an easy way to do it, is to sandblast the glass. The only issue is I don't want to blasting material flying around in the open air. I could purchase a retail sandblasting cabinet but I would be using it so infrequently that it would not be worth the cost. Instead I built a cabinet for under 50 bucks with parts from the hardware store.
Step 1: Materials
  • A large clear plastic storage container - preferably one with a seal build into the lid
  • Handheld sandblaster
  • Long rubber gloves
  • 2 Toilet Flanges
  • Small automotive airfilter
  • Aluminum flat stock
  • Bolts and Nuts
  • Silicone sealant
  • Zipties
  • BBQ Grate
Step 2: Check Out the Build Video
Check out my build video and the written directions and pictures to follow.
Step 3: Building the Cabinet
The cabinet design is very straight forward but I will walk through all the steps I did. Also I used a clear storage container because I can see inside, otherwise if I used a opaque container, I would need to add clear panels.
Using a large hold saw I drilled out two holes for the toilet flanges in the front of the container. Another option for cutting out the holes is also to use a rotary cut out tool. Test fitting the toilet flanges and then marking where the bolt holes should go, the holes were then drilled out. The toilet flanges had some silicone applied for a sealing gasket and they were bolted in place.
Next a square hole was cut out in the back of the container so the air filter would fit. Using some aluminum stock a mounting bracket was made to hold the filter in place. The air filter is for venting when the cabinet is in operation.
A hole was drilled in the side of the container so an air hose could be ran into the container.
The gloves were then ziptied onto the flanges, tape could also be used. It's important to get gloves that are long and large, this makes getting your hands in and out much easier. I opted for some pretty Dollarstore ones.
To keep the sand blasted items off the floor of the cabinet, I placed an old BBQ grate on the floor. When the blasting media accumulates it lands below the grate.
Step 4: Usage
Run a compressor hose into the hole that was drilled into the side of the container and connect it to a handheld sandblaster. I also seal the hole with a small piece of cloth. Place the item you want to sandblast into the container, in my case a glass bottle to be etched. Attach the lid, the container I am using has a latching system and a seal, this makes for a very tight air tight seal.
For the etching I taped off a glass bottle and cut out a few designs.
Start up the compressor and insert your arms into the gloves. Sandblast away, if everything is sealed up properly no blasting media will escape.
Usage is pretty simple and overall this cabinet exceeded my expectation. The exhaust vent worked perfectly and the mess was completely contained!
Also using a vinyl sticker cutter would work really well for making stencils for etching glass.
    • Safe and Secure Challenge
    • PCB Contest
      PCB Contest
    • Epilog X Contest
      Epilog X Contest
    38 Discussions
    Zaacharia
    Tip 27 days ago
    I am not up to sand-blasting yet but I do a lot of cleaning of glass pieces with dremel tools and I made one of these as a jiffy project. It keeps the air in my apt. clean. One thing I noticed: buy a big box so that you can have your hands at a comfortable angle; I bought a smaller box and it begins to hurt - it is difficult to work for any length of time. I will also have to cut a window into the top for a clear (lexan?) window into the box. Currently, the lid gets coated with some of the dust I generate.
    All-in-all your project is perfect for what I do. On my to do list is to check out sand-blasting but with softer material so I can blow the crap off the glass pieces (or I can figure out and fix the issue that causes bits to adhere when I get the piece out of the mold).
    Valvelifter
    4 weeks ago
    Excellent article, thanks. Cutting the plastic box with hot knife might have been easier.
    Paul Morrison
    4 weeks ago
    Great idea, I'll def make one for brightening up rusted parts. Thanks for your time !!
    JayR21
    Question 5 months ago on Introduction
    I know you said that the parts for the sandblasting cabinet could be purchased at a local hardware store but do you know the manufacturer of the tube and the gloves are, any assistance would be greatly appreciated. Jay, Oh it appears to be very simple to make.
    StuartT9
    6 months ago
    Great video! Could you list the sandblasting tools you use? I'm trying to set up some home sandblasting on a budget!
    Cheers.
    tkjtkjStuartT9
    Reply 6 months ago
    You won't get a more budget-friendly plan than ths!!! The 'Kiss Principle' is written all over this great project ...!
    If your plan involves 'light duty' blasting (that includes author's etching project) ya might wanna look at HarborFreight.com 's collection , unless you already have a satisfactory compressor unit....
    Mack937Yvsanchez111
    Reply 6 months ago
    I'll look again next time I'm in store Or maybe online item
    4
    bobdeetoe
    6 months ago
    Great project. One helpful hint... when drilling PVC or any plastic with a hole saw you will have fewer if any break-outs or breakage if you set the drill to reverse. That way the teeth don't grab the plastic and you get a nice smooth hole. Cheers !
    salmansheikh
    6 months ago
    Perhaps some Amazon or ebay links to the products you use, especially the hand blaster, would be nice.
    DavidR228
    6 months ago
    I fear that visibility into the container will deteriorate over time due to the blasting media scratching the plastic.Have you noticed anything like this?
    tytowerDavidR228
    Reply 6 months ago
    Then cut a square and screw on a piece of new perspex
    Tavan201 tytower
    Reply 6 months ago
    Visibility was going to be an issue with me, but installing an acrylic window is a great idea. Definitely going to be making my own sandblasting unit.
    smj56
    6 months ago
    Very nice. Very nice. One suggestion. I have a small sand blaster in my shop. I have connected a 5hp ShopVac to it. You could do that also. Why? It gets cloudy in there sometimes. The Vac will help with that.
    allenohana
    6 months ago on Step 2
    Nicely done! I want to build one for removing rust and paint from automotive parts. Thanks for the excellent and professional Instructable!
    JimSnap
    6 months ago on Step 1
    Great idea!, but I have big hands. ( got stuck in a drain of that size once, embarrasing.)
    Perhaps an exhaust fan? I know, it adds $. Definately going to try it. For a more delicate mask for the finer artwork try frisket material. You can get a lifetime supply at Michaels. I just got 4 yards by 18 inches wide for less than $25. It's easier to cut for the finer work. Jim
