DIY Self Watering Dog Dish
57,059
328
39
About: how to make, how to build, how to do it yourself, create, invent
Here's an easy way to keep your dogs dish or bowl full of water so he or she won't go thirsty! Recently I was at the hardware store and had a 4" PVC coupler in my hand and had an ah-ha moment! I realized right away how I could make a self watering dog bowl to eliminate my dogs occasional dry water dish. What I came up with was an easy to make self filling dog dish that works flawlessly! It re-purposes a soda bottle, pop bottle, or cola bottle to make this self watering bowl, which is good for the environment, and my dog!
Step 1: A Quick Video
Some can visualize better by watching the video. Good luck with this Instructable!
Step 2: Parts List
All dog bowls are different in size so specific measurements for this instructable aren't necessary. Watch the video at the end to get a better idea.
You'll need:
1) a piece of plywood for the base.
2) a piece of 2x4 for the stand
3) one white 4" PVC coupler (get it at the hardware store)
4) 4 screws.
5) 2 litre pop bottle with "hour glass" shape
6) optional: paint it whatever colour you like!
Step 3: The Base
First, take the piece of plywood and use the 4" PVC coupler to scribe a rounded shape on the front corners. This will keep it feet and dog paw friendly.
Step 4: Cutting the Base
Now use a jig saw to cut the corner pieces. If you don't have a jigsaw, a good sanding will do the trick.
Step 5: Sanding and Smoothing
This step is optional. I used my router with a rounding bit to round out the edges of the 2x4 to give it that store bought pro look.
Step 6: Adding the Base
Now pre drill 2 holes in the base for the 2x4. Use 2 screws to attach the base to the 2x4. You don't have to pre-drill but it makes it easier to assemble.
Step 7: Cutting the Coupler
Next make 2 marks on the coupler about an inch or 26mm apart and cut it out using a hacksaw. Use sandpaper to smooth out the edges.
Step 8: Drilling the Coupler
Make 2 marks and drill the coupler. It's easy to spread the PVC coupler apart a bit to get the drill in there or drill from the back.
Step 9: Attaching the Coupler
We're ready for the last step! Place your dog bowl on the base. Fill the bottle with water and screw the cap on. Now slide the bottle into the PVC coupler upside down making sure the hour glass part of the bottle is seated in the middle of the coupler. Now hold the PVC coupler against the 2x4. The level of the water will be determined by the position of the mouth of the bottle. You can choose to have a low water level or high, whichever you want. Now remove the bottle and screw the PVC coupler to the 2x4 with 2 screws.
Step 10: Your Dog Will Love You!
You're finished! Slide the bottle into the coupler and remove the cap!
Step 11: How to Make a Self Watering Dog Dish
Dog Challenge 2016
Grand Prize in the
Dog Challenge 2016
2 People Made This Project!
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Jewelry Challenge
    Jewelry Challenge
39 Discussions
swiperfox
2 years ago
Here is a another way to do it.
*a 2-liter bottle
*a foot-long pvc or plastic hose with diameter to fit on mouth of 2-liter bottle; the other end with 45-degree cut (just like a big needle in appearance)
*a bowl - to which the pointed end of the pvc will stand upon; probably needed to secure it in place so it won't be displaced when the pets drink; but removable if needed to clean it.
*a string - to tie the bottle to a post
Because of the foot-long pvc, there would be more headroom for the pets to drink from the bowl.
swiperfoxOliviaM28
Reply 2 years ago
It really does work. Its another version of it is a water bottle for chickens.
And the Water Dispenser for Humans
chrisnotapOliviaM28
Reply 2 years ago
You can see in the video that it actually does.
msennett
2 years ago
With it pushing triple digits temps every day, I ran out and bought 3 4in couplers and 3 sodas for the project. One for dog area, back patio and in the house! My bottles must be a new manufacture batch that are a mm or so too small. They catch if empty but no so much when filled. I added heavy rubber bands between the mount screws to squeeze the PVC. They squeeze enough to hold the bottles. Quick, easy and very effective project. Awesome, thanks.
TWJL1
2 years ago
cool!!!! Im gonna ask my cousin to make it!!!
Ali Suhail
2 years ago
Great Idea! thanks for sharing. looking for an idea to build a food dispenser for cats pellets.
jmcguire3Ali Suhail
Reply 2 years ago
I think this would work well it you just cut the top of the bottle off at the first curve and placed it close enough to the cat's bowl so it would only run out when there was no other food holding it back. Did that make any sense?
Ali Suhailjmcguire3
Reply 2 years ago
Thank you very much, it does make sense! will try it and let you know
Ali Suhailjmcguire3
Reply 2 years ago
Anthony.
2 years ago
now, if one can only take the dog out to do its thing after drinking the water. and whatever else they normally have to do.
JonathanMurray
2 years ago
Nicely done - now finish it by... finishing it! A coat of polyurethane (or even just paint) to keep the wood from soaking up spilled/splashed water would be a must here. Your plywood base will soon start pulling itself apart otherwise.
JenA22
2 years ago
Great idea we did this with a big glass bowl and attached the water bottle to spindles that were already part of the kitchen division....
Thik about FREEZING THE WATER BOTTLE toss a few bottles of water in your freezer the dog has cool water and do try to check inside and clean the bottles of slime - its a good idea to toss them after a few uses - they peel inside sometimes.
Our girls had distilled water and loved ice cold water.
Wish we could just get a bowl made of glass with the screw in bottle portion attached .....that's all for now....take care
ele421
2 years ago
I will make one for my dog
mstall9
2 years ago
What a great idea! I was a little frustrated, however, that the list of tools needed to do this project was not all-inclusive. There was a need for sandpaper, jigsaw, hacksaw, router and a drill - none of which were mentioned in the tools needed list! These things may be commonplace for most folks, but being a single woman I don't have many tools. Of the five things I listed above, I only have a drill, so I would need to make arrangements to get these other tools. Just wanted to point this out; have a great day!
chrisnotapmstall9
Reply 2 years ago
Still learning........my first instructable. Sorry.
