DIY Solar Battery Charger (LiPo/Li-Ion)
4,189
31
10
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will have a look at a commercial solar battery charger. That means I will conduct a few tests with it and afterwards create my own DIY version that improves the functionality of such a solar battery charger. Let's get started!
Supplies:
Step 1: Watch the Video!
The video gives you all the information you need to create your own Solar Battery Charger. During the next steps though, I will present you some additional information.
Step 2: Order the Components!
I got my components from LCSC.com: https://lcsc.com/
Here you can download the BOM files for the project. There you can find the part numbers. But feel free to check with the schematic whether you ordered all the required components.
Step 3: Order the PCBs!
Here you can find the schematic, board layout and Gerber files for the project. Feel free to upload the Gerber files to https://jlcpcb.com/quote to order 10 PCBs for cheap.
Or you can simply open my EasyEDA project with my board design and click the fabrication output button: https://easyeda.com/GreatScott/SolarLiPoChargeProt...
Step 4: SOLDER!
There is not much to say here. Solder all the components to the board and you are done. Feel free to use the attached pictures as a reference.
Step 5: Success!
You did it! You just created your own Solar Battery Charger.
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    10 Discussions
    armins2
    3 months ago
    Hello , can you help me about choosing inductor for limited charging current of 1A and input voltage of max 14v ? , i'm using different chip from same company but it has same working principle. i'm using chip for two series connected li-ion cells so my vbatt is 8.4v .I get some value but not shure is it correct example for all my values i calculated inductance of 28uH but max current of inductor should be 1.5A or 2A , how to choose that ? ic is "CN3795"
    Omar Alkassab
    3 months ago
    Dear Scott, can you tell me what are changes should be made to let this circuit to charge 12V 7Ah sealed lead acid battery? I want 3 connectors: one for the solar panel, one for the battery and one for load.
    Thank you in advance
    georgek52
    4 months ago
    awesome work Scott. Can you please let me know what resistors I have to use for a 12v 10W panel?
    georgek52georgek52
    Reply 3 months ago
    anyone? i'm almost ready to start soldering :(
    Efficient Sparks
    4 months ago
    Terrific job! Your tutorials are always so presice and consise. I will always await for the realease of new videos of yours!
    Spike718
    5 months ago
    For those who are new such as myself there are additional components not in the Sheets.
    Resistors in the 0603 Package:
    100, 1K, 2k, 7.5K, 33K, 180K (if using 18V-21V panel), I May be missing a resistor if using 5V panel.
    LEDs: 0603 Package - Red/Green/What Ever Color
    Correction- If your going to use a 18V-21V panel you can use a 28K instead of using a 33K+180K- In parallel.
    More Parts:
    C84817 - MT3608 - saw it in the EDA tool after thinking about what is doing the step-up
    C32254 - FS8205
    - Saw it in EDA Tool.
    I think for a 5V panel, the resistors could be 8.66K for R9 and 2.74K but I'm not 100% sure on this.
    Total Items missing:
    100, 1K, 2k, 7.5K, 33K, 180K OR 28K(if using 18V-21V panel)
    C84817 - MT3608 - DC-DC Converters Step-Up Adjustable 1 2V 24V 28V SOT-23-6
    C32254 - FS8205
    - MOSFET 2 N-Channel (Dual) 20V 6A 1.2V @ 250uA 28 mΩ @ 4A, 4.5V SOT-23-6
    CrazyW
    5 months ago
    Can I use arduino to adjust the mppt voltage ?
    Spike718
    Question 5 months ago on Introduction
    Thanks for the schematics and the videos!
    What LED # did you use? I wanted to try and make this but the sheet did not include the LEDs
    Thanks Again!
    1 answer
    jrock321
    This is a great project. I would like this with a potentiometer to adjust the mppt voltage.
