DIY Solar Powered Mason Jar
75,762
556
69
[ Play Video ]
In this Instructable, I am going to show you how to make a Solar Mason jar. This is a great project for people with minimal electronics skills and its completely wire free.You can make this within a hour.This is an inexpensive and easy way to add charm to any outdoor space which give off beautiful glow well after the sun sets.It is perfect to gift your beloved and the most important thing is, it is environment friendly.
If you are an electronics enthusiast, you can make the circuit also.Earlier I have written an Instructable on that.You can find it here .
You can find all of my projects on : https://www.opengreenenergy.com/
Step 1: Materials and Tools Required :
1. Mason Jar ( Amazon )
2. Solar Garden Light (Aliexpress / Amazon )
3. Frosted Glass Spray Paint ( Amazon )
4. Card Board
5.Masking Tape ( Amazon )
6.News Paper
7.Scissors ( Amazon )
8.Hobby Knife ( Amazon )
9.Glue Gun ( Amazon )
Step 2: Separate the Solar Light
The Solar garden light comes in variety of size and look.All lights are not adequate for making this mason jar.
So buy the light as shown in the picture.I have purchased it from aliexpress, link is given in the earlier step.
Simply unscrew the Solar light from its plastic bulb. The entire solar unit is self-contained and can be used without further disassembly.Don't forget to remove the plastic covering from the solar cell.
Step 3: Clean the Jar
Apply glass cleaner on the surface of the mason jar.
Clean it thoroughly with a soft / microfiber cloth.
Step 4: Cover the Base
Cover the base of the mason jar by using masking tape and then cut out the excess portion.
This step is needed to leave the bottom portion unpainted.This will helps to use it as a flashlight.
Step 5: Frost the Jar
Why frosting is required ?
Frosting the jar helps to diffuse the light all around the surface and gives a nice glow to the entire jar.
Steps :
Spread a news paper on the floor, then place a piece of cardboard on it.
Remove the mason jar lid and keep it on the cardboard, with mouth to the down side.See the above picture.
Apply frosted glass spray over the entire surface.Then leave it 10 -15 minutes to dry out.
Repeat the same process for 2 to 3 times ( 2-3 coats ).Its depends on you, how much frosting you like.
Safety : Wear nose musk during the frosting.I will recommend to do it outside and a well-ventilated space.
Step 6: Make the Cardboard Ring
While the jar is drying, unscrew the lid from Jar and remove the flat part (disc shape ) of the lid
Use a a marker to trace the shapes of the disc onto the cardboard.
Place the garden light ( solar panel down side) at the center of the earlier trace out and trace around it.
Cut the traced portion by using a scissors/hobby knife.The final cut out is a ring shape.
Note : To make the light water proof , you can use a plastic sheet instead of cardboard as described above.
Step 7: Prepare the Lid
Insert the Solar garden light in to the cardboard ring.It should fit tightly.
Then apply hot glue around it.
Removed the glass bulb.
Step 8: Mount the Solar Light
Insert the prepared solar light into the lid.
Then screw the lid onto the jar
Step 9: Finishing
For quick test, just slide the solar light switch to ON position and cover solar cell by your hand.The light should turned ON.
Place the Jar in the bright sun light, the solar cell will charge the battery.
When sun goes ( during dark ) ,it will be automatically switched ON.
You can make few of similar jars and place them in your garden or lawn.
Now enjoy your new solar mason jar.
If you enjoyed this article, don’t forget to pass it along!
Follow me for more DIY projects and ideas. Thank you !!!
Solar Contest 2016
Runner Up in the
Solar Contest 2016
4 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
69 Discussions
SeverinoJ1
7 months ago
i'd like to buy some of them to save energy inside my home. do you know where can i buy just the top of the devices? i have my own project with recycled glass bottles.
Lisadphill
2 years ago
I was wondering if you could use some wire, make a hole in each side of the top ring where it can be hung in tree limbs or something like that? What do you think?
lexpres61Lisadphill
Reply 1 year ago
Hi Lisadphill, you could do it that way but I prefer to add floral wire under the bottom lip where the lid screws on, and twisting it to make 2 loops, one on each side of the jar. You can then attach some jack chain to your desired length for hanging. Hope the pics are clear enough to show what I mean.
BarbaraH88
2 years ago
I have made these before but never with the frosting on the jar. Such a nice addition. I will be adding it to my gift jars in the future. Thank you so much for the great idea and for the link to these lights. Much better than what I've been using.
savagemom2
2 years ago
Nice ible!! Instead of just painting your jar, you could use Armour Etch - a glass etching cream, also available on Amazon for a permanent change to glass. Paint will chip. Not 100% positive it will work on canning jar but canning jar lids will fit on other jars. Can also easily use to create designs in etching - stripes, swirls, zigzags, etc
MarichuO
2 years ago
I need to try this! Keep on doing what you do to help the environment. This is one great way to cut on electricity cost.
KateH36
2 years ago
A nonprofit called Liter of Light.org makes similar solar lights from clear plastic water bottles to illuminate homes in developing energy poor countries. Night lighting provides light for school work, or home businesses. www.literoflight.org
Awesome!
nubiman
2 years ago
rocket science duh
kimsanamm
2 years ago
could not find these lights at amazon do you have a part number and price range
butterflydtxkimsanamm
Reply 2 years ago
I buy them at Walmarts. Have also seen them at othet stores
