DIY Solar Tracker
186,912
1,186
90
About: I am a graduate student in the Mechanical Engineering department at MIT, with aspirations of improving the world. I was raised in Durham, North Carolina and I enjoy building things, learning about entreprene...
Introduction
We aim to introduce young students to engineering and teach them about solar energy; by having them build a Helios as part of their curriculum. There is an effort in engineering to push energy generation away from the use of fossil fuels and towards greener alternatives. One option for greener energy is to use a device called a heliostat, which uses a mirror to direct the sun’s light onto a target throughout the day. Such a device can be used for many applications, from concentrating solar energy onto the heat reservoir of a power plant to illuminating areas that are blocked from the sun.
In addition to the number of uses of this technology, there is also a diverse range of structures that have been designed to enable solar tracking. The physical structure of Helios’s design, as with other heliostat designs, functions to mount a mirror onto two controllable axes. The mechanism will track the sun by using a program to calculate the star’s location in the sky thought the day, based on the global position of the Helios. An Arduino micro-controller will be used to run the program and control the two servo motors.
Design Considerations
To ensure that this project is widely dispersed, considerable effort went into designing the Helios to be built with common tools and cheap materials. The first design choice was to build the body almost entirely out of foam core, which is rigid, affordable, easy to acquire, and easy to cut. Also, for maximum strength and rigidity, care was taken to design the body so that all of the foam parts are either in tension or compression. This was done to take advantage of foam core’s strength in tension and compression, and because the adhesive that was used is more effective at supporting a load in tension than in bending. Additionally, the shaft that is attached to the mirror is powered through a timing belt, which allows for a small alignment error between the motor and the mirror, the servo motors are accurate to within 1 degree, and the platform runs on the open source Arduino platform. These design choices, along with a few other considerations, make the presented design a durable and affordable, educational tool.
Our open-source promise
The goal of Helios is to promote engineering education. Because this is our main focus, our work is licensed under the GNU FDL license. Users have full rights to reproduce and improve on what we have done, as long as they continue to do so under the same license. We hope that users will improve the design and continue to evolve Helios into a more effective learning tool.
Epilog Challenge VIAn Epilog Zing 16 Laser would allow me to complete higher quality projects, , and increase the amount of impact that I have with them.build interesting large scale things, and to tinker more effectively in general. An Epliog Laser would also allow me to build more interesting things and write more cool Instructables, such as this one about a Kayak that I refurbished. My next goal is to build a kayak from laser cut plywood that is reinforced with carbon fiber or glass fiber, as well as a cardboard surf board that is wrapped in structural fiber.
I've also entered this instructable in the Tech and the Teach It contests. If you enjoyed this post, please vote!
Step 1: Table of Contents
Table of Contents:
  • Introduction: DIY Solar Tracker
  • Table of Contents
  • Tools and Bill of Materials
  • Step 1-16 Hardware Assembly
  • Step 17-22 Electronics Assembly
  • Purchasing Links
  • Works Cited
  • Thanks for your Support!!!
Step 2: Tools and Bill of Materials
All of these tools can be purchased at local stores or at the links in the reference section. The total cost of these materials is approximately $80, if they are all purchased online at the given links.
BOM
  • Power Drill
  • Drill Bits (.1258”, .18”, and .5” Diameter)
  • Screwdriver Set
  • Straight Edge
  • Box Cutter
  • Large Vice Grips
  • 2 Foam Core Sheets (20” X 30”, ~.2in thick)
  • 9.5” Long by 1/2” Diameter Rod
  • Square Nut (7/16” -14 Thread Size, 3/8” Thick)
  • Vigor VS-2A Servo (39.2g/5kg/0.17 sec)
  • Tape
  • Timing-Belt Pulleys (2), 1” OD
  • Washers
  • Krazy Glue
  • Timing-Belt 10"
  • Templates (Files attached)
  • Mirrored Acrylic Sheet (6” X 6”)
  • Krazy Glue Gel
  • 8 Machine Screws (4-40, 25mm long)
  • 8 Nuts (4-40)
  • 1.5" long Nails
  • Starter Kit for Arduino Uno
  • Real Time Clock Module
  • Wall Adapter Power Supply (5VDC 1A)
  • 9V battery
  • 3.3 KOhm Resistor (2)
Step 3:
Print the templates in the attached file.
Note: These have to be printed in full scale. Compare the printouts with the PDFs, to ensure that your printer has not changed the scale.
Step 4:
Secure the templates to the poster board as shown in Figure 1 and, using the center lines as guides, drill the .18 inch and .5 inch holes.
Note: Drill the .5 inch holes with the .18inch drill bit first for increased accuracy.
Step 5:
With a sharp box cutter, cut out the individual components.
Note: Cut the foam core with multiple passes of the box cutter, this will result in a much cleaner cut. Don’t try to cut through the whole sheet in one pass.
Step 6:
Glue the matching cutouts together as shown in Figure 2, using the super glue. You should be able to look through the cutouts and see that all of the holes are aligned, the base of parts 1 and 2 should be flat, and one template on part 3 should be facing out.
Note: After applying glue to one surface, join the parts and press them together for 30 seconds. Then, allow the glue to set for five minutes.
Step 7:
Using the superglue gel, glue parts 1, 2 and 3 together as shown in Figure 3. Be sure that the parts are arranged so that the .5” diameter holes are closest to the section of the base that is labeled short, also be sure that the template on the base is facing down/out. Allow the glue to set for five minutes. After the glue has set, insert 3 nails through the base and into each of the uprights for added support.
Step 8:
Cut through the top layer of both cross beams and insert them into the Helios as shown in Figure 4. Apply superglue gel to joints between the cross beams and the walls of the Helios, and the surface shared between the two cross beams, as indicated in blue. Allow the glue to set for five minutes.
Step 9:
Place a piece of tape along the cuts, as shown in Figure 5.
Step 10:
Superglue the spacer to the base, by lining it up with the template as shown in Figure 6, and allow the glue to set for five minutes.
Step 11:
Center the largest servo horn onto the bottom base and secure it with the superglue, as shown in Figure 7. Allow the glue to set for five minutes.
Step 12:
Bore out one of the timing belt-pulleys to a .5” diameter hole using the .5 inch drill bit, and check that it fits onto the .5” diameter shaft. It should either press on, or have a gap small enough to fill with super glue. If the drilled hole is too small, sand down the outer diameter of the shaft by hand.
Step 13:
Carefully bore out two square nuts to .5” diameter holes and check that they fit snuggly onto the shaft.
Note: Clamp the nut to a sacrificial surface, with a pair of vice grips, and progressively increase the diameter of the hole with multiple bits until a .5” diameter hole is left. Remember to plunge the drill bit into the nut slowly.
Step 14:
Attach a servo horn to the timing belt pulley as shown here, being careful to center the servo horn’s axis with the pulley’s, as shown in Figure 8.
Step 15:
Assemble the shaft and servo, with no glue, and align the two timing belt pulleys as shown in Figure 9. Some of the rod should be exposed from the wall opposite the pulley.
Note: Screw the servo into the uprights, being careful not to force the screws through the foam core, and screw the servo horn into the servo. You may use superglue instead of screws , however you won’t be able to easily disassemble the unit.
Step 16:
Once the shaft’s pulley is aligned with the servo’s pulley, slide the inner set of washers against each wall and glue them to the shaft using the superglue gel. They will keep the shaft from sliding out of alignment. Also, glue the pulley to the shaft using the super glue. Let the glue set for five minutes.
Step 17:
Shorten the timing belt to the correct length, around 7.2 inches, and use the superglue gel to make a loop that connects the shaft’s pulley to the servo’s pulley, as seen in Figure 10. First, wrap the belt around both pulleys and take out the slack. Now, cut the belt just after the teeth on both ends, the ends of the belt to just reach each other. Now cut around .5” of belt from the piece you just removed. Finally, bring both ends together and glue them with this extra length of belt, image 2. Once the glue dries, place the belt around the pulleys. It should be such a snug fit that you will have to unattach the pulley from the servo to fit the belt on. If it fits, place it to the side for later.
Step 18:
Glue the mirror template onto the back of the mirror, or draw the center line by hand. Then, using the line as a guide, glue the square nuts onto the mirror with the super glue gel. Make sure that the mirror is able to rotate 180 degrees from facing straight up to facing straight down without interfering with anything, and then glue the square nuts to the shaft with the superglue gel.
Note: The bottom edge of the square washers should be aligned with the dotted line on the template.
Step 19:
Install the final servo, secure the bottom base to the final servo with a screw through the servo horn, and place the timing belt onto the pulleys to complete the Helios.
Note: Once you understand how the electronics and software work, by reading below, you can adjust your Helios to increase its accuracy.
Step 20:
Connect the servos as shown, leaving the power disconnected from the DC jack. (Figure 12)
Note: Connect the 9 volt battery directly to the Arduino through the jack on the board and connect the Arduino to your computer through its USB port. DO NOT connect the 9 volt battery to the prototyping board, as this may damage your real time clock.
Step 21:
Download and Install Arduino Version 1.0.2 from here
Note: This download includes the Helios control code and all the libraries that you will need to run it. To install, download the folder and unzip it. The Arduino program runs directly out of its directory, no formal installation is required. For general installation directions and directions on how to install drivers for your Arduino, head here.
Step 22:
Run the Blink Arduino Sketch based on the directions here. Once you get this short sketch to work, you can be sure that you have properly connected your Arduino to your computer.
Step 23:
Open the control program (ArduinoCode >Helios_2013) to set the time and location of the Heliostat, and to upload the program onto the Arduino.
1) Choose whether you want Helios to act like a solar panel and track the sun (set the variable heliostat=0) or a heliostat (set the variable heliostat=1)
a. Note: We suggest that you try it as a solar panel first to make sure that it moves how you expect. If one of the axis seems to be off, then you may have put in one of the servos backwards.
2) Gently turn Helios clockwise all the way. Then point the whole machine east.
3) Enter the coordinates of your location.
a. Find the coordinates of a location by Google searching the address. Next, right click the location and select “What’s here?”. The coordinates will appear in the search box, with latitude and the longitude.
b. Change the default latitude and longitude values in the program to the latitude and longitude values of Helios.
4) If you choose to use Helios as a solar panel, then skip this step. If you choose to use Helios as a heliostat, then enter the altitude and azimuth angle of Helios’s target. The coordinate system is defined in Figure 15.
5) To set the Real Time Clock, determine the current time in UTC and replace the corresponding variables with these values, in military time. Then delete the “//” where indicated, upload the sketch, and replace the “//” (Ex. 6:30pm EST is 10:30pm UTC. In the program this would look like hour=22, minute=30, and second=0)
a. After the clock is set, unplug the servos and run the code in “solar panel” mode (heliostat=0). Verify the calculated angles of the solar tracker with something like the solar position calculator from sunearthtools.com (http://www.sunearthtools.com/dp/tools/pos_sun.php). “dAzimuth” is the Azimuth angle of the sun as predicted by Helios and “dElevation” is the elevation /altitude angle of the sun. Both Helios’s and the website’s predictions should agree to within around five degrees. Any discrepancy within this range is from the uploaded time being off by a few minutes, and would cause an unnoticeable change in Helios’s behavior.
b. Once Helios’s prediction for the sun’s location is accurate, then replace the “//” to comment out the code that sets the clock. The real time clock only needs to be set once, so it will not have to be updated as you upload new sketches or change targets.
6) Remove the USB and power from the Arduino and connect the servo motors again.
Step 24:
If Helios was assembled correctly, then it should point towards the target that you command and keep the sun’s reflection stationary there when power is applied to the Arduino once again. Helios will correct the sun’s reflection every degree. This means that the sun’s refection will shift until the sun has moved one degree, at this point Helios will move to correct the reflection. Once you understand how the program works, you may want to play with the variables “offset_Elv” (Elevation) and “offset_Az” (Azimuth) to compensate for any assembly error. These variables control the orientation of Helios’s coordinate system.
Step 25: Purchasing Links
Foamcore: http://www.amazon.com/Elmers-Acid-Free-Boards-16-Inch-902015/dp/B003NS4HQY/ref=sr_1_4?s=office-products&ie=UTF8&qid=1340998492&sr=1-4&keywords=20x30+foam+core
Rod: http://www.mcmaster.com/#cast-acrylic/=i6zw7m (Part Number: 8528K32)
Box cutter: http://www.amazon.com/IRWIN-2082300-Utility-Standard-Retractable/dp/B0001Q2EOS/ref=sr_1_2?ie=UTF8&qid=1340619344&sr=8-2&keywords=box+cutter
Servo: http://www.hobbyking.com/hobbyking/store/__16641__Vigor_VS_2A_Servo_39_2g_5kg_0_17sec.html
Tape: http://www.amazon.com/Henkel-00-20843-4-Inch---500-Inch-Invisible/dp/B000NHZ3IY/ref=sr_1_1?s=hi&ie=UTF8&qid=1340619520&sr=1-1&keywords=invisible+tape
Templates: Print the pages at the end of this document. Paper can be purchased online at: http://www.amazon.com/Inches-Letter-Bright-Sheets-998067R/dp/B004WL0L9S/ref=sr_1_1?ie=UTF8&qid=1340864035&sr=8-1&keywords=paper
Square nut: http://www.mcmaster.com/#machine-screw-square-nuts/=hflvij (Part Number: 98694A125)
Super glue: http://www.amazon.com/Krazy-Glue-KG92548R-Instant-0-18-Ounce/dp/B000BQSFSM/ref=sr_1_2?ie=UTF8&qid=1340861717&sr=8-2&keywords=Krazy+Glue
Super glue gel: http://www.amazon.com/Krazy-Glue-KG86648R-Instant-0-07-Ounce/dp/B000H5SFNW/ref=sr_1_4?ie=UTF8&qid=1340863003&sr=8-4&keywords=all+purpose+instant+krazy+glue
Straight Edge: http://www.amazon.com/The-Classics-12-Inch-Stainless-TPG-152/dp/B002IXKD9U/ref=sr_1_1?ie=UTF8&qid=1340863091&sr=8-1&keywords=ruler
Power Drill: http://www.amazon.com/Black-Decker-9099KC-7-2-Volt-Cordless/dp/B0002TXNX0/ref=sr_1_1?ie=UTF8&qid=1340863181&sr=8-1&keywords=power+drill
Screws: http://www.mcmaster.com/#machine-screw-fasteners/=mumsm1 (Part Number: 90272A115)
Nuts: http://www.mcmaster.com/#hex-nuts/=mums50 (Part Number: 90480A005)
Mirror: http://www.mcmaster.com/#catalog/118/3571/=i705h8 (Part Number: 1518T18)
Screwdriver Set: http://www.amazon.com/Stanley-66-052-6-Piece-Precision-Screwdriver/dp/B00009OYGV/ref=sr_1_5?s=hi&ie=UTF8&qid=1340863503&sr=1-5&keywords=screwdriver+set
2 Timing-Belt Pulleys: https://sdp-si.com/eStore/Direct.asp?GroupID=218 (Part Number: A 6M16-040DF25)
Timing-Belt: http://www.mcmaster.com/#timing-belts/=i723l2 (Part Number: 7887K82)
Drill Bits: http://www.amazon.com/Bosch-TI18-18-Piece-Titanium-Assortment/dp/B0000TZZWE/ref=sr_1_6?s=hi&ie=UTF8&qid=1340874037&sr=1-6&keywords=drill+bits
Washers: http://www.mcmaster.com/#catalog/118/3226/=hzc366 (Part Number: 95630A246)
Large Vice Grips: http://www.amazon.com/7-Inch-Curved-Locking-Pliers-Cutter/dp/B00004YO5L/ref=sr_1_10?ie=UTF8&qid=1340863806&sr=8-10&keywords=vise+grips
Nails: http://www.mcmaster.com/#standard-nails/=i708x6 (Part Number: 97850A228)
Arduino Kit: http://www.amazon.com/Starter-Kit-Newsite-Uno-Breadboard/dp/B0051QHPJM/ref=sr_1_2?s=electronics&ie=UTF8&qid=1367794217&sr=1-2&keywords=arduino
Real Time Clock Module: https://www.sparkfun.com/products/99
Power Supply: http://www.amazon.com/gp/product/B006GEPD6U/ref=oh_details_o01_s01_i00?ie=UTF8&psc=1
Battery: http://www.amazon.com/Duracell-Batteries-9Volt-size-battery/dp/B00009V2QT/ref=pd_sbs_hpc_9
Resistors: http://www.radioshack.com/product/index.jsp?productId=2062345
Step 26: Works Cited
4photos. (2112, 07 07). 3d compass navigation. Retrieved June 6, 2013, from 4photos: http://4photos.net/en/image:43-215776-3d_compass_navigation_images
Commons, C. (2010, January 1). Real Time Clock Module. Retrieved May 28, 2013, from Sparkfun: https://www.sparkfun.com/products/99
Commons, C. (2011, January 1). DC Barrel Jack Adapter - Breadboard Compatible. Retrieved May 28, 2013, from Sparkfun: https://www.sparkfun.com/products/10811
Commons, C. (2013, May 16). Ethernet library. Retrieved May 28, 2013, from Arduino: http://arduino.cc/en/Reference/Ethernet
ElmarM. (2013, March 24). Haunted Doll. Retrieved May 28, 2013, from instructables: https://www.instructables.com/id/Now-the-fun-part-create-a-creepy-story-to-go-wit/step17/Arduino-and-Breadboard-setup/
Gaze, M. (n.d.). STEPsss. Retrieved May 28, 2013, from kennyviper: http://kennyviper.com/Temp/Chloe/electronic%20workshop%20final%20work/Male%20Gaze/male%20gaze/Stepsss.html
sonlineshop. (2012, January 1). Resistor 2.2K Ohm. Retrieved May 28, 2013, from http://sonlineshop.com/index.php?route=product/product&product_id=72
Step 27: ​Thanks for Your Support!!!
We would like to extend a huge thank you to Alexander Mitsos, our supportive advisor, and all of the people that supported us throughout this project:
  • Whitney Meriwether
  • Benjamin Bangsberg
  • Walter Bryan
  • Radha Krishna Gorle
  • Matthew Miller
  • Katharina Wilkins
  • Garratt Gallagher
  • Rachel Nottelling
  • Randall Heath
  • Paul Shoemaker
  • Bruce Bock
  • Robert Davy
  • Nick Bolitho
  • Nick Bergeron
  • Paul English
  • Alexander Mitsos
  • Matt C
  • William Bryce
  • Nilton Lessa
  • Emerson Yearwood
  • Jost Jahn
  • Carl Men
  • Nina
  • Michael and Liz
  • Walter Lickteig
  • Andrew Heine
  • Rich Ramsland
  • Bryan Miller
  • Netia McCray
  • Roberto Melendez
Tech Contest
Runner Up in the
Tech Contest
Epilog Challenge VI
Runner Up in the
Epilog Challenge VI
4 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
90 Discussions
Job_04
3 days ago
Hi,
While testing in solar panel mode, I found out that my setup is rotating in the wrong direction. I use a different servo so perhaps the rotational direction is opposite. How can I change the code to get it in the proper direction?
pdaniel7Job_04
Reply 3 days ago
You can try to find the line that sends commands to the motor in the code and then negate the angle command.
MarcoP169
7 weeks ago
Hi Everyone,
I’m helping our local school (I’m an amateur astronomer) to do some science outreach programs...the problem is that I’m really uncapable to use those fantastic instructions as I’m a biologist with 0 skills for DYI.
Would be someone of you having one ready that you do not use anymore? we would be very happy to buy and use it.
Why that would be important for us?
What we would like to do is to mount permanently a small refractor to perform the experiment of William Herschel (discovery of IR) + some basic solar physics (rotation period of the sun) or basic solar spectroscopy (and telluric spectroscopy) + size and presence of sunspot.
we also would like to use it as a “moonstat” as there is a very simple way, using a telescope to calculate the distance earth-moon measuring the size at different altitude in the sky using a DSLR mounted on the telescope. This is our “highlight” project for this year as will be a way to explain parallax “hands on”.
For all that would be terribly convenient to keep the instrument on a table...
Hope you can help us,
marco.prunotto@gmail.com
Mike3872
Question 2 months ago
Hi, is there any alternative for the vigor vs 2 that I can use?
1 answer
Mike3872Mike3872
Answer 2 months ago
I bought a MG995 High Torgue Metal Gear Analog Servo, ill tell you if it works.
DaveL177
3 months ago
Perhaps someone or some entity would finance their projects/education by offering kits of the electronics complete with programs for the more mechanically inclined experimenters. Presumably, the electronics would drive any reasonably sized solar array so it is a matter of designing the mechanics to suit. This is a bit of a simplification but surely there is a niche for such devices--or perhaps they exist?
Well thought through presentation and for the post-dinosaur crowd perfectly clear but for we dinosaurs, the electronics fly way over. Thanks to all contributors.
pdaniel7DaveL177
Reply 2 months ago
Thanks Dave! If you find somebody interested in financing something like this please point them my way!
Gerardo GMR
10 months ago
exellelent!!!!!!!!!!!!!!!!111111
do you sell the files to use with a 3d printer??
pdaniel7Gerardo GMR
Reply 10 months ago
I don't sell the files for 3d printing. I would recommend laser cutting over 3d printing as well
brightled
12 months ago on Step 1
great project ,an updated heilostat from the first spectroheiloscope,I plan to build but mine will use steppers instead of servos
Thanks a lot for your tutorial.
I have setup everything and the mechanical system works fine.
The problem I have is that the clock' time is wrong.
Opening the serial monitor I get always this:
UT 45: 165:85 165/165/165
I have setup in the write way the clock.
In fact running the example on the RTClib with arduino I get always the right date and time
The RTC module I use is DS1307 just the one mentioned in your tutorial and photos.
I will grateful if you can help me solving this problem.
It's a pity I cannot use the system in the right way.
Thanks a lot for your help-
Arnaldo
jrantilla5arnaldoarmida
Reply 1 year ago
Arnaldo, did you ever discover how to fix this issue? I am experiencing the same difficulty and am not sure how to fix it. I have spent a lot of time trying to figure out how to resolve this issue.
pdaniel7arnaldoarmida
Reply 4 years ago on Introduction
I don't have the time to dig back into my code. I suggest searching for some forums and/or copy pasting code from the working sketch to the sketch that you are trying to run.
pdaniel7
1 year ago
And thanks!
denissato
1 year ago
Congratulations, great project! I have a question: How does the system work at night? (In solar panel mode). Does it turn it off?
pdaniel7denissato
Reply 1 year ago
It's battery powered, so it will run as long as the batteries are charged
NickK145
2 years ago
I was able to get the electronic side of this working very quickly,I have not built the hardware components yet It is reporting to within a degree or two to the sun tracking site in the instructable but appears to be tracking the sun even though there is no sun. I have not yet been through the code but I would have thought it would default to a standby position at sunset? a minor problem is a semicolon missing in the download code bringing up an expecting or statement error. I used a duinotech RTC module that built in pull up resistors so can be directly connected to the assigned pins.Fantastic project., and easy to follow for an arduino Newb who doesn't know how code ;)
pdaniel7NickK145
Reply 2 years ago
I am glad to hear that the project is going well for you! I didn't add in a standby position, but that is a good idea. Good catch with the semicolon. Feel free to paste the corrected code block here so that others can correct the code if they also get an error.
prabhnoorkaur
2 years ago
hey! i cant locate the timing belt pulleys , there are so many in the links provided for them, please help!
pdaniel7prabhnoorkaur
Reply 2 years ago
Hey, sorry about that. Any that fit should work, you don't have to get the same ones that I used. It has been a while, so I can see how my links expired unfortunately. Look for a matching pulley and belt that have the appropriate inner pulley diameter for the shaft, an outer diameter that isn't so big that the two pulleys will touch (smaller the better), and a thickness close to around 3/4" so there is enough grip on the shaft.
