Add Headphone Jack to Your Smartwatch
10,946
90
14
About: Ideas Into Reality !
Well The iPhone 7 doesn't come with headphone jack anymore, one of the alternative solution can be to Hack a u8 Bluetooth smart watch and add a headphone jack so you can listen your music wirelessly through smart watch from your iphone .
Its a new way to add headphone jack to your iPhone 7 ! it's certainly better than having a no headphone jack . The U8 Smart watch only costs few $ so it will not break your banks and not easy to loss unlike apple's new airpods @ $160 !!!
we will instead use bluetooth smart watch to do the job !
★☆★ Buy Parts from your online local store ★☆★
Your can buy that here http://geni.us/zrDrh
https://youtu.be/YD2qYPIfrQI
Supplies:
Step 1: Install 3.5 Mm Audio Jack
Everything is self explanatory here , i took apart u8 smartwatch by removing its back metalic plate and 4 screws , inside you will found a loudspeaker , we will replace it with similar sized 3.5mm audio jack connector ,This watch gives only mono audio output so i connected right and left channel togather .
Step 2: Few Adjustments...
in order to fit the 3.5mm audio jack into the watch you need to make few round cuts into the body and it will almost look like a professional one !
Step 3: It Works !
Yeah It works really good just connect the watch with the Bluetooth and you're ready to go !
  • Woodworking Contest
    Woodworking Contest
  • Classroom Science Contest
  • IoT Challenge
    IoT Challenge
14 Discussions
AlefR
2 years ago
very cool, I'll do it with my, already I changed his firmware and am trying to improve the appearance of the system modificand his rom when concluding comment post here for you guys !
WannaDuinoAlefR
Reply 2 years ago
but, i got the same U8 watch and some others, that every body buys,
i read thet the firmware CAN be changed! How ? got a link for us?
rickyeatough
2 years ago
I had this exact idea with my watch, which I did! However don't really use my watch, as the cheap chinese eBay seller didn't have the vibration motor which i needed!
LGT300WannaDuino
Reply 1 year ago
Or better yet, take the motor from an old phone.
3366carlos
2 years ago
awesome idea. I was wondering why you only soldered two wires. its mono.
WannaDuino
2 years ago
WannaDuino
2 years ago
but nice Ible. KEDY
WannaDuino
2 years ago
ITS, MONO.
THE BIG,, NO NO!!!
Yonatan24
2 years ago
What does this have to do with an iPhone 7?
There's a really simple method for adding a headphone jack onto an iPhone 7...
mattgamer99Yonatan24
Reply 2 years ago
you could use this $7 smart watch if you wanted to charge your phone and listen to music
Funguypro
2 years ago
Android, Android, Android. this is why I dislike Apple. Great project though, I never would of thought of that! ?
