DIY Sutures
130,200
48
38
About: I'm a life-hacking reuse junkie who loves to create, even if all I'm making is a mess. I love hammers and rocks and history and hand planes. I hugged trees before it was cool but can still operate a chainsaw...
Disclaimer: the information in this instructable might come in handy sometime, but I didn’t attend medical school and don’t have the license (or the inclination, for that matter) to practice medicine (as practice it would be, indeed)outside the friendly confines of my bathroom. The general consensus is that a doctor should be consulted in matters pertaining to your health. After all, they spent more money on their formal education than we did, and they need something to show for it.
This instructable is meant for adults only. I'm a mother, and I know how pissed I'd be if some lunatic told my son how to sew himself up. I don't need your mom pissed at you or me.
This instructable contains pictures and descriptions of an actual laceration (mine) and the skin sewing process and is therefore unsuitable for people who are squeamish about that sort of thing.
We good? Okay, let's get started, then. It's sew time.
Supplies:
Step 1: Get Your Supplies Together
What You’ll Need
Laceration that won't behave
Ibuprofen
Ice
Clean towel
Sterile Gauze
Antiseptic (hydrogen peroxide or bactine)
Needle (curved is what the doc uses but straight works, the smaller the better)
Alcohol (Isopropyl not drinking) and cotton ball
Lighter or matches
Thread (silk or nylon, fishing line works)
Scissors
Bandage large enough to cover wound
Step 2: Take the Ibuprofen
Take the Ibuprofen. This is going to hurt a little. Take another few just for good measure. Don’t take aspirin. Thin blood is not the way to go with DIY invasive medicine. Wash your hands if you didn’t already do so.
Step 3: Prep Your Work Area
Lay out your towel on a firm flat surface. This is your dedicated work surface, so make sure you have ample space. Lay everything you need out and take a quick inventory. I didn’t do this and ended up forgetting the scissors. Oops. Take the wrapper off the bandage, the top off the antiseptic. You don’t want to have to fumble with those later.
Step 4: Sterilize Your Equipment
Grab your lighter, and put your needle in the flame. Heat it up. Don't burn yourself. Wipe your needle and line down with a cotton ball soaked with alcohol. Thread your needle and set aside. (Alternatively, you could boil your needle and line in water, but I didn't want to turn on the stove and draw attention to my antics lest they be halted unnecessarily.)
Step 5: Assess & Prep the Laceration (with Final Gut Check)
Give your wound another good look. If you've come this far, you probably think you need stitches, but you might not. Would it stay together with butterfly bandages? Superglue? If so, go that route. I've glued on a few occasions with great results. In this instance, I had already tried butterflies, which failed immediately. Since the laceration was completely through the skin and a few inches long, I felt superglue wouldn't be effective.
If the area around your laceration is quite swollen (mine was), ice it for a few. You have a couple of minutes to kill before the ibuprofen starts working anyway. This will help the swelling go down and give you a little added numbing benefit. Not near enough, but we'll pretend it helps. Don't apply the ice directly to the wound. You don't want to soften too much skin or you'll have a helluva time keeping your line in it without it cutting through. Thoroughly clean your cut with an antiseptic like bactine or hydrogen peroxide. If you feel like throwing up after the cleaning of the wound, go take care of that before proceeding. I did.
Gut check time. Take a deep breath. If you feel unsure of your ability to stitch yourself, abort mission. It's okay. Most people don't do this sort of thing, anyway. Take a good look at your cut again. Still think it could benefit from stitching and still don't want to go to the hospital? Yes? Still with me? Okay, sport, grab your needle. It' sew time!
Step 6: Sew It Up
 Ever been sewn up by a medical professional? Usually they take a curved needle, run it from the outside through the entire layer of skin, then across the laceration back through the other side,bottom to top and out. Then they tie off each stitch with a square knot. This is called a simple interrupted suture. The benefit of this type of suture is its strength (since it is anchored on both sides in the entire layer of skin, which is quite thick) and its independence from other sutures. Should one suture fail, the rest will remain in their places to keep the wound together. It didn't take long to realize this method was not going to work in my situation. The first obstacle was my straight needle. Once I got it all the way through my skin, it was kind of a dead end. Turning the corner to cross the wound required a lot of strain on an already injured part of my body, and also got it to bleeding again. Compounding the problem was the fact that the laceration being stitched was on my hand. That means that I only had one hand to use, and it's job was stitching. When I tried to go back up through the other side, my skin provided enough resistance to the needle that it just pushed the skin away and the cut open wide instead of nicely piercing the skin so I could complete the stitch. I ended up holding the skin in place with 2 fingers and pushing the needle throughwith my thumb. Frankly, after one pass in this manner, I felt a little like passing out. Okay, maybe more than a little. So I modified the stitch and the rest was cake (compared to the first stitch, at least).
Instead of going all the way through the skin at a steep angle, I went only halfway through at a much gentler slope. After the needle exited at the center of the cut, instead of entering back through in the same direction and going bottom to top, I changed directions and went top to bottom again. The direction of the stitch was always toward the cut, which meant I was always pushing the two pieces of skin toward each other instead of pulling one away during the stitch.
Doing it this way is much less traumatic, but makes interrupted suturing impractical if not impossible. Instead, do a series of running stitches in this fashion. I did mine in 2 sections. (Note: Don't strain the stitched area any more than you have to, either while stitching or during your recovery period. The drawback to uninterrupted stitches is that if part of the stitch fails (ie, pulls out), the whole stitch slacks)
Starting at the midpoint where the cut is the widest, stitch to the end of the cut, alternating sides. Make sure and leave yourself a good sized tail on your first stitch so a) it doesn't pull through and b) you have something to tie onto when you start the second segment going the opposite direction.
As you stitch, the goal is to pull the line snug enough so your skin approximates its original position. If your skin is puckering or rolling at stitch points, you either are pulling the stitches too tight or not stitching deep enough to get a good anchor.
When you reach the outer edge of the laceration, loop back to the stitch prior and knot. Cut the excess line from that end only (you should still have your tail in the middle). If you don't have enough thread left on your needle to complete this running stitch segment in the opposite direction, reload now.
Now go back to the midpoint of the laceration, tie the second length of thread to the first tail, and stitch in the same fashion as before, in the opposite direction, to the other end of the cut.
When you reach the end, again loop around the stitch prior and knot. Exhale.
You made it.  Nice stitching!
Step 7: Cover It Up
 As much as you want to admire your handiwork at this point, you're going to need to get it protected. Give it another shot of antiseptic and put your bandage on.
Step 8: Watch It Close
When you get a deep cut, you always run the risk of infection. It doesn't matter if you sewed it up or your doctor did. Keep it clean, keep it protected, and watch it closely. Change the bandage a few times a day. If at some point it starts being redder, hotter, or uglier than it was when you buttoned it up, don't wait until it kills you. Take further action. Infection is serious business.
This is my hand post-healing. The scar will stick around, but I just consider it a reminder to be cautious with sharp objects.
Step 9: Update
It's been a few years and a small city's worth of views, so I thought I'd give one final update. I'm still alive and the scar has faded substantially. I still hurt myself all the damn time, but I'd like to think it's less frequent and I'm better prepared to handle it. I have health insurance now, which is awesome, but I still do much of my medicine at home. Take care of yourselves!
xo/Spring
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    38 Discussions
    GarretC3cosarara
    Reply 3 months ago
    just had my stitches done last night. the doctor there at hoag did an incomplete job, after waiting 6.5 hours in the lobby of sick people i wished i had done it myself.
    gizmologistcosarara
    Reply 11 months ago
    Doctors cost serious money for those of us that didn't drink the Obamacare Kool-Aid. There's also the business of waiting for hours in the emergency room when one could be finishing one's project. You know, the one responsible for the laceration in the first place.
    cannotw8cosarara
    Reply 3 years ago
    I had a er doctor give me two stitches without any drugs for pain and i was stuck with a 700 bill after insurance
    Phil B
    6 years ago on Introduction
    Once there was a bad joke about what you call a do it yourself surgery kit. The answer was"suture self."
    KelseyL26Phil B
    Reply 5 months ago
    Oh my gosh that's hilarious!!
    KelseyL26
    5 months ago on Step 6
    Your commentary made me laugh at all the right times!
    gizmologist
    11 months ago
    I love it! I once had a nasty bleeder (courtesy of the ever-present X-Acto knife) and a hot soldering iron handy... Do-it-youself cauterization works too... Ouch!
    GreekAres
    Question 1 year ago
    I got a cut in my upper leg about 5 days ago, roughly 3 inches long, a centimeter wide, and half a centimeter deep. From what I’ve read it would have needed stitches but it being a week ago it doesn’t seem advisable. It has lightly scabbed over, would you recommend I try a stitch the wound? If so should I try and soften the scabbing?
    Spring WiseGreekAres
    Answer 1 year ago
    Nope. I’m not an MD, mind you, but that seems ill advised. Think of the scab as your sutures. Keep it clean and may your recovery be speedy.
    icengGreekAres
    Answer 1 year ago
    No doctor, nurse or EMT will suture a wound after 6 hours because deep infection is a very real possibility..
    matthysb
    Tip 1 year ago on Step 8
    If you do dangerous stuff and figure that this probably will come in handy, get a sharpening stone, pick a needle that you will be using for the stitches and give it a flat bevel to form a blade at the front.
    This will make the entire project that much easier. It cut(badum tsssss) my stitching time in half. It was a lot easier to pierce the skin on both sides of the wound.
    SherylinRM
    1 year ago
    I had my arm ripped open once and sewed it up. Was not fun but it worked :)
    Good instructable :)
    violetsmuse
    1 year ago
    I agree with you, I wouldn't have used super glue either, it looked too deep. I grew quite faint while reading the steps but sometimes one has to make do. As in not having enough insurance, no access to medial care, etc. I don't have a weak stomach nor am I afraid of anything medical. Weird that I got woosy, lol. You were so brave and good for you!
    sarahlynnmurphy
    5 years ago
    Super glue works really well on cuts that won't stay closed! No need to stick yourself with a needle :-)
    slo5ohsarahlynnmurphy
    Reply 5 years ago on Introduction
    +1 for superglue. Newskin works well on minor cuts, but I find it will peel off in less than a day. Superglue stays put and will seal the wound shut.
    Drake88slo5oh
    Reply 2 years ago
    Something I have done in the past - newskin(superglue) and then steri-strips. Depending on the length of the wound this might work and might not. Usually I use the steri-strips first, then glue the areas between the strips carefully so the glue does NOT get on the strips. I also try to keep the area covered with at least two layers of heavy gauze(or some flexible bandages -placed to hold the wound closed- covered over with another large plastic backed bandage).
    Also - pain killers are okay, but a local anesthetic is better - try using some of the OTC stuff they have for toothaches(Lidocaine) that is usually in the mouthwash/toothpaste isle of the local pharmacy/ store. Try not to get it directly into the wound - just rub it in gently with a *gloved*(do NOT want numbed finger doing stitches!) finger keeping it out of the wound as best you can. Keep rubbing it in for a minute or two after the feeling around the wound stops to increase the numbness duration so you can make the stitches correctly(my first time I didn't do this and had to hurry - the wound is a little 'off' and the skin now 'pulls' a little funny when I need it to move).
    CraigH71
    2 years ago
    About to spend 5 days sailing offshore. Thanks for the tutorial, hopefully I won't need it!
