How to Make : DIY Tealight Candle Holder
2,138
50
About: I like to make fun projects and document it all for my channel BCDesign on YouTube!
I experimented making some tealight candle holders with reclaimed Parana pine I had in my shop, I made 3 different styles trying to decide which one I should make a batch of, please have a look and share which one is your favorite with me! I like the faceted 4 candle holder the best!
I made a video of the process for my YouTube channel BCDesign please have a look and if you like it subscribe and share!
Items you will need:
  • Mitre saw
  • Chisel
  • Drill
  • 40mm Forstner Bit
  • Sandpaper
  • Wood Glue
  • Spray Lacquer
  • Tealight Candles
  • Imagination
Step 1: Tealight Holder #1
  • I set the depth adjuster screw on my mitre saw to a 1/2" deep
  • I marked the width of the dados onto the Parana pine by using the maple as a template
  • Remember for a tight fit to cut inside the dado lines
  • You will need to put a spacer against the fence of the mitre saw to account for the curve of your blade.
  • I made multiple cuts through each dado
  • Use a chisel to clear out the dado
  • I then cut my maple to size and dry fitted it into the dado,I set my mitre saw to 15o and cut all the sides
  • Next I added glue and refitted the maple into the dados and clamped it for a few hours.
  • When the glue was dry I marked the center line of the holder and drilled 2 40mm (1.57") holes with a forstner bit for the tealights.
Step 2: Tealight Holder #2
  • I cut a piece of the parana pine into a square shape
  • Set the mitre saw bevel to 25o to the right and the mitre adjustment to 15o
  • I then rotated the piece & cut straight through the point of each corner
  • When you have cut the 4 corners flip the piece over and cut the through the point of each corner again
  • This leaves the piece with a cool faceted affect
  • I marked out 4 points and used the forstner bit to drill holes for the tealights.
Step 3: Tealight Holder No.3
  • Use the same angles as for Tealight Holder #2
  • I made this holder with a rectangular piece of parana pine
  • Cut 2 corners diagonally across from each other
  • Flip the holder over then cut the opposite 2 corners to give another faceted look
  • I then drilled 2 holes for the tealights with the forstner bit
Step 4: Spray on Finish
  • I used a spray on gloss lacquer to finish the holders
  • I sprayed on multiple coats with appropriate drying time between each layer
  • You will get a nicer smoother finish if you sand with a high grit sandpaper between each coat.
Step 5: Finised!!
I really enjoyed this simple project! Tealight holders are a great beginner project or a project for when time in your workshop is limited!
Please comment and let me know which type of holder you like best!
If you like my YouTube video please thumbs up, subscribe and share!!
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    2 Discussions
    jmac044
    2 years ago
    What size of forstner bit is used for the tea lights?
    BCDesignjmac044
    Reply 2 years ago
    Hey Jim its a 40mm (1.57") bit
