DIY Tripod Phone Holder
6,814
134
8
About: Mohamed El Makrini known as Ironman, my super power is to learn and build new things with my hands, this is my Youtube channel "MedProjects" where I upload videos of things I made. my goal is to sh...
In this DIY I will show you how to make a sheap Tripod Phone Holder using only a PVC pipe!
So lets start this simple project
Supplies:
Step 1: Tools You Need
• PVC Pipe
• Bolt matches with the tripod screw
• Hacksaw
• Tamplate of your phone
• Rasp
• Super Glue + Hot glue
• Heat gun or Lighter (be careful with the heat)
Ruler + Pencil
Step 2: Cutting the PVC
1. I Measured 4,5 cm then I cut the PVC pipe by the hacksaw, after that I split it.
2. Then I straighten up the piece by heating it using fire (you can use heatgun) (SAFTY FIRST WEAR GLOVES)
3. Next I smooth the edges using the rasp (you can use sandpaper)
Step 3: Measuring the Dimensions
So now we gonna measure the dimensions of the phone then applying them on the piece
1. I measured 5mm from one side of the piece.
2. 8,94mm Depth
3. 61,3mm Width
4. then 8,94mm Depth
Now I heat up the peice following the lines I drew, after that I fold the piece in that line (look the pictures or the video)
Step 4: Gluing the Bolt
1. I put some superglue on one side of the piece I made the I attach the bolt.
2. Next I reinforce it by adding hot glue.
3. Then I paint the whole piece in black.
Step 5: The END
I hope you like this project
Thank You
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    8 Discussions
    randone
    3 years ago
    Hey, great instructable, but bolt is misspelled the Step 4 title
    MedProjectsrandone
    Reply 3 years ago
    oh that's right thank you! I will edit the title
    thanks!
    howtoraju
    3 years ago
    Wonderful. This is what I've been looking for for a long time. Thank you.
    bnaivar
    3 years ago
    I tried making a holder that ended up basically a vise and limited getting to the phone buttons. I like your way better.
    ZiddiK
    3 years ago
    nice work. i was looking for a way to mount phone for camera stand, now you found me a way..thank you, keep it up
