DIY USB IR Receiver
60,820
395
46
About: I'm an embedded ICT student.
In this tutorial, I'm going to show you how to make a small, cheap (less than $5) USB IR receiver.
The microcontroller used acts as a standard keyboard, so it should work on every computer.
With this receiver you can use a remote control to control things on your computer.
I made this instructables based on one of my previous instructables. The difference is that it's a lot smaller and it acts as a keyboard, so you don't need extra software on your PC.
Let's get started!
Supplies:
Step 1: Parts
For this instructables you'll need a few parts:
A digispark(clone) (gearbest)
A 38kHz IR receiver (ebay)
A remote control
You'll also need some tools:
A soldering Iron
A PC with the arduino software installed
Step 2: Soldering the IR Receiver
First you need to bend one leg (OUT) of the IR receiver so it goes into P2 and the other legs go into 5V and GND.
After that you need to add a little piece of heat shrink (or tape) to the horizontal part of the IR receiver.
Place the IR receiver back on the digispark and solder the three legs together.
The only thing you need to do now is clip of the useless part of each leg.
Now you're done with the hardware part.
Step 3: Getting the Keycodes of the Remote
In this part you need to see what code is "connected" to every button on the Remote control. We need to do this, because every remote uses other codes for every key.
To do this, I used the setup and program of my previous instructables. I just opened the serial monitor to see which code was send. If you don't have an arduino for getting the codes, you can also use the part you just made. This is a little more difficult, but it gives you the same result.
First you need to install the digiusb drivers. Goto this link and on the right click "download zip". After you've downloaded the zip extract all the folder "DigisparkExamplePrograms-master" to any directory you like.
The goto "DigisparkExamplePrograms-master/C++/DigiUSB Windows Driver/" and click "installdriver".
After you've done that, you need to follow these instructions to install the right boards in the arduino IDE.
Now copy this code to a new arduino project and upload it to your digispark.
* This code is written by Laurens Wuyts
* For questions: laurens.wuyts@gmail.com
* Microcontroller: ATtiny85
* Dev board:       Digispark
#include <DigiUSB.h>
uint8_t situation = 0;
uint8_t START = 0;
uint8_t x = 0;
uint8_t BIT = 0;
uint8_t Id = 0;
uint8_t Id_inv = 0;
uint8_t Data = 0;
uint8_t Data_back = 0;
uint8_t Data_inv = 0;
uint8_t Repeat = 0;
uint8_t sended = 0;
uint16_t Time_old = 0;
uint16_t Time = 0;
uint16_t TimeDelta = 0;
void setup(void) {
  attachInterrupt(0, IR_Read, FALLING);
  pinMode(1,OUTPUT);
  digitalWrite(1,LOW);
  DigiUSB.begin();
void loop(void) {
  if(sended == 1) {
    DigiUSB.println(Data_back, DEC);
    sended = 0;
  } else {
    DigiUSB.delay(10);
void IR_Read(void) {
  digitalWrite(1,HIGH);
  Time = micros();
  if (Time_old != 0) {
    TimeDelta = Time - Time_old;
    if ((TimeDelta > 12000)&&(TimeDelta < 14000)) {
      START = 1;
      x = 0;
      situation = 1;
      Id = 0;
      Id_inv = 0;
      Data = 0;
      Data_inv = 0;
    } else if ((TimeDelta > 10000)&&(TimeDelta < 12000)) {
      situation = 2; // repeat
    } else if ((TimeDelta > 1500)&&(TimeDelta < 2500)) {
      situation = 3; //"1"
      BIT = 1;
    } else if ((TimeDelta > 1000)&&(TimeDelta < 1500)) {
      situation = 3; //"0"
      BIT = 0;
    } else situation = 5;
    if (situation == 3) {
      if (x < 8) {
        Id |= BIT;
        if (x < 7) Id <<= 1;
        x++;
      } else if (x < 16) {
        Id_inv |= BIT;
        if (x < 15) Id_inv <<= 1;
        x++;
      } else if (x < 24) {
        Data |= BIT;
        if (x < 23) Data <<= 1;
        x++;
      } else if (x < 32) {
        Data_inv |= BIT;
        if (x < 31) {
          Data_inv <<= 1;
        } else {
          /* DO SOMETHING HERE */
          sended = 1;
          Data_back = Data;
          Repeat = 0;
        x++;
    } else if (situation == 2) {
      if(Repeat == 1) {
        /*sended = 1;*/
      } else {
        Repeat = 1;
  Time_old = Time;
After you've done that, goto "DigisparkExamplePrograms-master/Python/DigiUSB/Windows/" and open "monitor.exe". In this window the keycode is printed when you press a button. Just note the button and then the code you see. You'll need them later on.
Step 4: Digispark Sketch
Ok now the "real" code for the Digispark.
In this code you need to add the keycodes you got in the previous step. For example if the "mute" key has code 100 you change:
#define mute	240
to
#define mute	100
!! Attention !!
When you define a new key, you can't use spaces in the name.
And for adding functions go into the loop function and add/change the key you like.
When you have any question at all, feel free to ask!
/**** Define Remote control keys ****/
#define Power     64
#define key_1     32
#define key_2     160
#define key_3     96
#define key_4     16
#define key_5     144
#define key_6     80
#define key_7     48
#define key_8     176
#define key_9     112
#define key_0     136
#define vol_up    224
#define vol_down  208
#define ch_up     72
#define ch_down   8
#define mute      240
#define next      172
#define prev      164
#define up        6
#define down      134
#define left      166
#define right     70
#define playpause 156
#define key_stop  180
#include "TrinketHidCombo.h"
uint8_t START = 0;
uint8_t x = 0;
uint8_t BIT = 0;
uint8_t Id = 0;
uint8_t Id_inv = 0;
uint8_t Data = 0;
uint8_t Repeat = 0;
uint8_t sended = 0;
uint16_t Time = 0;
void setup(void) {
  /* Use INT0(P2) on the Digispark */
  pinMode(1,OUTPUT);
  TrinketHidCombo.begin();
void loop(void) {
  if(sended == 1) {
    /* Assign functions to the buttons */
    if(Data_back == vol_up) {
      TrinketHidCombo.pressMultimediaKey(MMKEY_VOL_UP);
    } else if(Data_back == vol_down) {
      TrinketHidCombo.pressMultimediaKey(MMKEY_VOL_DOWN);
    } else if(Data_back == next) {
      TrinketHidCombo.pressMultimediaKey(MMKEY_SCAN_NEXT_TRACK);
    } else if(Data_back == prev) {
      TrinketHidCombo.pressMultimediaKey(MMKEY_SCAN_PREV_TRACK);
    } else if(Data_back == key_stop) {
      TrinketHidCombo.pressMultimediaKey(MMKEY_STOP);
    } else if(Data_back == playpause) {
      TrinketHidCombo.pressMultimediaKey(MMKEY_PLAYPAUSE);
    } else if(Data_back == mute) {
      TrinketHidCombo.pressMultimediaKey(MMKEY_MUTE);
    } else if(Data_back == Power) {
      TrinketHidCombo.pressSystemCtrlKey(SYSCTRLKEY_SLEEP);
    } else if(Data_back == key_0) {
      TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_0);
      TrinketHidCombo.pressKey(0, 0);
    } else if(Data_back == key_1) {
      TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_1);
    } else if(Data_back == key_2) {
      TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_2);
    } else if(Data_back == key_3) {
      TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_3);
    } else if(Data_back == key_4) {
      TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_4);
    } else if(Data_back == key_5) {
      TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_5);
    } else if(Data_back == key_6) {
      TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_6);
    } else if(Data_back == key_7) {
      TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_7);
    } else if(Data_back == key_8) {
      TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_8);
    } else if(Data_back == key_9) {
      TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_9);
    } else if(Data_back == up) {
      TrinketHidCombo.pressKey(0, KEYCODE_ARROW_UP);
    } else if(Data_back == down) {
      TrinketHidCombo.pressKey(0, KEYCODE_ARROW_DOWN);
    } else if(Data_back == left) {
      TrinketHidCombo.pressKey(0, KEYCODE_ARROW_LEFT);
    } else if(Data_back == right) {
      TrinketHidCombo.pressKey(0, KEYCODE_ARROW_RIGHT);
    sended = 0;
  } else {
      TrinketHidCombo.poll();
/* Read the IR code */
  Time = micros();
      START = 1;
      x = 0;
      situation = 1;
      Id = 0;
      Id_inv = 0;
      Data = 0;
      Data_inv = 0;
      BIT = 1;
      BIT = 0;
      if (x < 8) {
        Id |= BIT;
        x++;
        Id_inv |= BIT;
        x++;
        Data |= BIT;
        x++;
        Data_inv |= BIT;
        if (x < 31) {
          Data_inv <<= 1;
        } else {
          sended = 1;
          Data_back = Data;
          Repeat = 0;
        x++;
      if(Repeat == 1) {
        sended = 1;
      } else {
        Repeat = 1;
  Time_old = Time;
Now upload the sketch to the digispark. Unplug and replug it into your computer, wait ~5sec and enjoy your remote control.
Step 5: Resume
In this tutorial, I showed how to make a low cost USB remote control.
I hope you liked it, please add suggestions what you want to see next, questions or improvements below.
Laurens
4 People Made This Project!
  • Arduino Contest 2019
  • Fandom Contest
    Fandom Contest
  • Gardening Contest
    Gardening Contest
46 Discussions
MarkH43
8 weeks ago
Hi,. Great little project, many tx for sharing..... but one question I have is how can I produce the 'Ctrl, Alt, Left/Right Arrow',.. to mimic the Ubuntu screen switch.. within/from the code..
I have tried the following,.. but this does not generate the expected result:-
} else if (Data_back == ScreenRt) {
TrinketHidCombo.pressKey(0, KEYCODE_LEFT_CONTROL, KEYCODE_LEFT_ALT, KEYCODE_ARROW_RIGHT);
thankyou...
Juan AntonioP9
3 months ago
Thank you very much. Your instructions allowed me to build my own IR receiver. Anyway, after some days using it i saw a problem (maybe due to the codes my remote was sending). Some times, after pressing a key and then in a short time another different key, the second key was processed as a repetition of the first key. I tried changing the timing parameters but could not find a solution. As I could not find where the problem came from I ended looking at the NEC protocol and rewriting a part of the algorithm. Here is my code:
uint8_t STEP = 0;
uint8_t BIT = 0;
uint8_t Id = 0;
uint8_t Id_inv = 0;
uint8_t Data = 0;
uint8_t sended = 0;
uint32_t Time_old = 0;
uint32_t Time = 0;
uint32_t TimeDelta = 0;
void loop(void) {
if (sended == 1) { // Key press
// Control all keys
sended = 0;
} else if (sended == 2) { // Repetition
// Control keys that you want to have repetitions
sended = 0;
} else {
Time = micros();
if (TimeDelta > 100000 || (TimeDelta > 12500)&&(TimeDelta < 14500)) {
STEP = 0;
STEP++;
if (STEP == 1) {
if ((TimeDelta > 12500)&&(TimeDelta < 14500)) {
Id = 0;
Id_inv = 0;
Data = 0;
Data_inv = 0;
} else {
STEP = 0;
} else if((STEP>=2) && (STEP<34)) { //Accumulate the bit values between 0-31.
if ((TimeDelta > 1750)&&(TimeDelta < 2750)) BIT = 1;
else if ((TimeDelta > 625)&&(TimeDelta < 1625)) BIT = 0;
else STEP = 0;
if (STEP < 10) {
Id |= BIT;
if (STEP < 9) Id <<= 1;
} else if (STEP < 18) {
Id_inv |= BIT;
if (STEP < 17) Id_inv <<= 1;
} else if (STEP < 26) {
Data |= BIT;
if (STEP < 25) Data <<= 1;
} else {
Data_inv |= BIT;
if (STEP < 33) Data_inv <<= 1;
else {
if (Data^Data_inv == 0xFF && Id^Id_inv == 0xFF) {
Data_back = Data;
sended = 1;
} else {
STEP = 0;
else if ((TimeDelta > 40100)&&(TimeDelta < 42100)) {} // Ignore the First repetition block
else if ((TimeDelta > 10250)&&(TimeDelta < 12250)) {} // Ignore Begin of new repetition block
else if ((TimeDelta > 95750)&&(TimeDelta < 99750)) // End of a repetition block
// Repeat
sended = 2;
} else {
STEP = 0;
Time_old = Time;
ejohn
4 months ago
after getting the codes, I want to make a sender for other usage.
Any ideas? help
happohiken
5 months ago
Hello. Thank you for sharing this fine post.
I'd like to ask you for help. I've followed your instructions (installed drivers and so), but when I open monitor.exe, I get a popup with the following message: "no digiusb device detected". Do you know what could I do?
Thank you very much, best regards
ejohnhappohiken
Reply 4 months ago
I got the same message because I choose the wrong board
"DigiSpark Pro (Default 16MHz)"
Pault274
1 year ago
Hi, Great instructable working like a charm. Having one problem. If I press a button to long it executes twice. Is there a way to increase a time out between button presses?
Greetings
Bez4Pault274
Reply 5 months ago
I have the same problem. Is there a fix? I made this over a year ago and finally got it working but I have to press every button very briefly.
Laurens-WuytsBez4
Reply 5 months ago
You could try to disable the repeat functionality, but then it will only send a key every press and won't send again when you press long on a button.
To do this, you could delete/comment out this line:
if(Repeat == 1) {
// sended = 1; // << Comment out this line
} else {
Repeat = 1;
Laurens
Bez4Laurens-Wuyts
Reply 5 months ago
Thanks for replying Laurens. I figured out a similar work around just after I replied, just had to look at the code closer. Unfortunately that fix doesn't work well for volume up an down so I added "delay(185);" after every keypress except volume up and down and it now works really well. This delay works well for me in Kodi on an Rpi3.
Laurens-WuytsBez4
Reply 5 months ago
Ah, its good to hear that you got it working the way you want it. :).
Thanks for sharing your workaround for other people with the same problem!
Laurens
mark angelob3
9 months ago
Sir can I ask what will I exactly do with the monitor.exe when i try to open it, Error because i need python. And How many source code I need to compile on my digispark?
DylanD581
1 year ago
After coding this to work with an Apple Remote... every time I plug it into a different computer, do I have to download a river for it to work?
ПавелГ13
1 year ago
Hi! Please help!
Do I need a Python for work?
I don't understand where i can find this - "DigisparkExamplePrograms-master/Python/DigiUSB/Windows/" and open "monitor.exe" . Is it a python?
Alex Lillybear
2 years ago
Hi Laurens, I know it's been a while since you made this instructionable, but I'll try asking anyway.
I'm
trying to get my Harmony 525 to play nicely with this reciever, byt I
can't for the life of me get the monitor to register events. I've tried
by adding known NEC protocol devices to the Harmony, but no luck at all.
I was thinking maybe you could point me in the right direction?
Thanks for an exellent project!
Alex LillybearAlex Lillybear
Reply 2 years ago
Nevermind, it's working now. Now I jest need to find a compatible remote with most of the functions I need. So far, Andersson R1 surround receiver has given me the most options on my Harmony 525. Thanks again!
Magicoolme
2 years ago
Hi, I build it but it works only if I press the key on the remote repeatedly very very very fast. What can it be?
sfriziona
2 years ago
Hi,
thanks for sharing this project, I followed instructions and found very easy.
Now
I got no experience with arduino but neeed to add some key , could someone point me in the right direction to find out how
to remap and assign new key and functions?
I got a programmable harmony remote and try to get it work with a raspberry Pi 3 with libreelec.
Thanks....
davids1983
2 years ago
I built this and its great, it is the only method i can get anything from. I tried writing something based on the pulsein code and I got nothing at all. Well done.
I am having some issues though with ghost false positive signals every now and again, also the repeat function I had to switch it off to make it more usable. Do you have any ideas to improve error correction?
My other observation is the first sketch could replaced by a simple if and variable to put it in to 'learn mode' with TrinketHidCombo.print(Data_back_,DEC) that way users could flash their digispark, re open the sketch and merely select your #define keys point their remote and press the button, then change the variable and use as expected. This is what i did and it worked well.
Jeeru
2 years ago
What I want to do is do kind of a "fake" HDMI-cec with my HTPC.
I want to be able to control Kodi on my htpc, just simple things linke up/down/left/right and the ok button. Right now my raspberry pi does that perfectly through HDMI-cec. I'm switching to an HTPC, which doesnt support cec. This DIY might (kinda) fix that for me. I'd want to use the remote of my Yamaha receiver, but how do I know which protocol it uses? I can't find if it uses NEC or RC5 or RC6.
