DIY USB "Hard Drive"
734,202
628
565
About: Ex-Navy Gunner Learned to repair I.T. equipment because nobody local knew what the hell they were doing!
Using a dead Hard Drive, a 4-port USB hub, and a few Flash Drives, we will kill some time and get a few laughs from anyone seeing you use this.
**NOTE**
You guys can see MAKE magazine's rip-off article of my project at:
http://blog.makezine.com/archive/2009/03/weekend_project_flash_memory_hard_d_1.html
Thanks for the credit MAKE, I really appreciate it....
Step 1: Find a Candidate.
Any Hard Drive should do..
Step 2: Dismantle..
Take the Hard Drive apart...
Step 3: Compare
Make sure your USB hub will fit, either with the plastic case on, or not...
Step 4: Hub
For this purpose, I removed the plastic case.
Step 5: Install
I placed the "nekkid" USB hub into the area where the platter used to be.
Note: I was only placing this temporarily, if I was going to keep this mod permanent, I would glue the hub in either using epoxy or hot glue.
Edit: I forgot to mention, if this was going to be used permanently, I would coat the circuit board with epoxy, just like I do with Flash Drives.
Step 6: Flash Me!
Now add your Flash Drives, you may have to remove the casing for some to fit well.
Step 7: Button It Up.
Replace the cover to the Hard Drive, and plug in!
Now you will have a "new" Flash Drive that will be sure to get some comments.
Also, there is a way, I haven't done it, but with a certain flavor of Linux, you can install Linux onto all 4 of the Flash drives in a RAID configuration, assuming you have all the same capacities.
Have fun!
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    565 Discussions
    frenzyQuazaka
    Reply 8 years ago on Step 7
    have great news!
    This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
    Thanks for using instructables!
    https://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/
    jmoore61
    3 years ago
    sooo... just having seen the first page, you picked an 80GB drive apart for this??
    TSCirishjim68
    Walmart does not sell flash drives cheap! Microcenter  is way cheaper!
    neivadanriekard
    ya i know u can get em at staples,future shop,best buy,u can even make ur own.
    riekardneivadan
    cool, but i wanna try and make my own, how would i go about it?? what do i need?
    riekardNxtfari
    ...this build doesnt mention anthing about makin your own flash drives
    Nxtfaririekard
    Oh, sorry, I thought you said you wanted to make the USB Hard Drive. To make your own flash drive would be pretty hard. I mean, Its got over 100 pieces that have to be soldered together perfectly on a circuit board. You'd be better off buying one. They're like $10 for a pack of three.
    flame boyyyywillrandship
    Reply 8 years ago on Step 6
    512 is as much as my old desktops ram size and it is pretty slow dont go with 512 man.
