DIY Waxed Canvas Shoes
34,287
225
46
Do you love your canvas shoes, but hate when they get wet?
I'll show you how to make your canvas shoes water resistant and all-around awesome with beeswax.
What You'll need:
canvas shoes
beeswax
paintbrush
double boiler (or a small pot and clean can).
hair dryer
towel / trivet
waxed paper [optional]
A note on wax:
Paraffin is a byproduct of fossil fuels and has been shown to be toxic in some uses. This is why I choose to use beeswax. It's easier to apply, and as a bonus I get to support my local honey store!
Supplies:
Step 1: Melting the Wax
If you don't have a double boiler, here's how to melt your beeswax:
Bring water to a boil in the small pot, then set the heat to low.
Place the beeswax into the can (I used a clean cat food can), and then place the can into the steaming water.
The wax will slowly melt.
Step 2: Wax Coat
I set up my shoe and towel on a sheet of waxed paper under sturdy surface in preparation... kind of like a little shoe waxing station. When the wax is melted, set the pot, water and all, on the towel or trivet next to your shoe.
Using quick movements, brush the wax onto the shoe . Cover the surface of the shoe evenly. Don't worry about all the white wax... we'll deal with that in the next step.
Step 3: Hot Air
Heat up the wax using a hair dryer and use the brush to work it into the fabric. Pay close attention to the seams, and do your best to get an even saturation.
You can stop here, and you'll be fine... but if you wanna go the extra mile:
Toss your shoes into an old pillowcase, tie it off, and give it a tumble in the dryer for 15-20 minutes on high.
Step 4: Testing
let's test these puppies out!
I poured a small glass of water on each shoe, and it all beaded off!
Bring it El Niño!
I've received a few questions about where to buy the shoes and beeswax. If you're not having any luck locally, here's where you can buy the shoes, (crocs Santa Cruz 2 Luxe) as well as a bag of BEESWAX PELLETS.
.Cheers!
Feet Challenge
Runner Up in the
Feet Challenge
Wax Challenge
Runner Up in the
Wax Challenge
2 People Made This Project!
  • IoT Challenge
    IoT Challenge
  • Arduino Contest 2019
46 Discussions
pmsfo
3 years ago on Introduction
Is beeswax also the best kind of wax to use to waterproof leather? All the sprays I've tried work for a while, then they fail. No fun when you are living in Washington state without a car.
starthornpmsfo
Reply 2 years ago
Wax will make a material (cloth of leather) water *resistant*, not water *proof*. You'll need to use something a good bit heavier and more "industrial" to make it waterproof, and even then, it may not last forever.
Typically, you want to apply your water resistant substance somewhat regularly on things like shoes and boots, probably a couple of times a year, depending on how often you wear them and what kind of environment. Heavy wear or cleaning will necessitate more frequent application.
Also, for leather, I'd recommend looking into specific leather protection substances. Wax will change the color and feel of leather a decent bit, and may or may not be what you want. Personally, I've had excellent experience with Leather Milk, but there are lots of options.
amastaepmsfo
Reply 3 years ago
I double boiled 200 ml olive oil and 50g beeswax, let set, then rubbed into my leather boots. let dry. water beads right off. there's a tutorial on here somewhere for just that.
CaptSnaz
A friend of mine wanted to waterproof his leather boots, so he just rubbed Vaseline into the leather & seams. - That worked well too.
Vaseline is good if you don't care about your boots lasting for more than a year or so, but homemade versions of snoseal are easy to find online and work pretty well. I made one of my own from bee's wax and mink oil (plus some other stuff I forget), works well and only needs one application a winter.
Matt Makes
Thank you for the great tutorial! I actually have the exact same style of shoes at home, mine are brown. They're awesome and seem to hold up better than something like vans. Now I can wax them and make them even more useful. Once waxed is the canvas still readily bendable? I have a canvas bag that I use for hiking and I was wondering if this technique would work for it as well?
Matt Makeshillouie
Reply 3 years ago on Introduction
Crocs. They're called "Walu Slip Ons". They really have held up well for me. I've had them for about two years and wore them almost every single day. For the first year I wore them while trekking back and forth all over campus during my last year of college. I've also worn them in the snow, in the mud, on short hikes, and have gotten them wet dozens of times. I've had Vans in the past and over time the shoe would separate from the sole, or idea eventually walk through the sole of the shoe. These Walu crocs don't seem to have those problems, they just last.
EreluMatt Makes
Reply 3 years ago
I used to waterproof leather with SnoSeal, which is at least partly beeswax. of course the whole point here is DIY. I learned that I can use SnoSeal on fabric.
All good :-)
Phil_S
Hello,
This subject cropped up a little while ago.
Barbour outdoorsy jackets are waxed sort of canvass - you could see what they use.
Beeswax is also used in decent polishes for wood, usually softened up with pure turpentine. Good woodworking suppliers will keep it.
My father was a real craftsman and used to sew a lot of stuff with thick thread, To make it easier, he always had a block of beeswax to run the thread through. When it got too ragged, he simply re-melted the block - I still have a large chunk of it.
Wood polishers use a technique called hot waxing where you apply the wax roughly, then use a hot air gun to melt it while you polish it off.
namora
The only question I have about this is that since canvas shoes do not make your feet smell bad because they breath what happens when the wax clogs the fabric up? Back to wearing socks?
