Make WiFi Jammer With ESP8266 - Hack Any WiFi Without Password!
194,405
104
43
About: Ideas Into Reality !
Hey friends, Its Kedar Here, Have you ever wanted to block all wifi signals. or just want to kick someone out from wifi or a neighbors wifi. Well this is it guys your wait is over. Here is the $8 DIY Wifi Jammer to try for yourself.
To see how effective this wifi jammer works I suggest you to check my video here
This jammer is so tiny you can fit into pocket. and carry it anywhere. it can powered through your power bank or 3.7v lipo battery. You can select which wifi network you want to jamm and attck on it . But be sure this is just for education purpose do not use for wrong purposes.
The 802.11 WiFi protocol contains a so called deauthentication frame. It is used to disconnect clients safely from a wireless network.
Because these packets are unencrypted, you just need the mac address of the WiFi router and of the client device which you want to disconnect from the network. You don’t need to be in the network or know the password, it’s enough to be in its range.
You can perform multiple attacks on this device such as you can jam any particular wifi network or you can do beacon spam or random beacon spam. or you can simple deauth all. Lets start making it.
See How The Jammer Works
https://youtu.be/N5JVQ-m5Kd0
You can use this Mobile app to control this Wifi Jammer
http://geni.us/PQhB
Step 1: Get Your Parts Ready !
So to make this wifi jammer mainly you will need only one part esp8266.
you can buy this perticular version of esp8266 as this as a nodemcu firmware on it and it is easy to program without any programmer. This esp8266 has a build in programmer.
you can buy that here
1) ESP8266
http://geni.us/1LLaBJR
2) Battery (optional)
http://geni.us/okAOH
Here is Full Instruction video
Step 2: Get Your Arduino Compiler Ready
Download the latest Arduino compiler from the Arduino website here
https://www.arduino.cc/en/Main/Software
1 Install Arduino and open it.
2 Go to File > Preferences
3 Add http://arduino.esp8266.com/stable/package_esp8266com_index.json
to the Additional Boards Manager URLs.
4 Go to Tools > Board > Boards Manager
5 Type in esp8266
6 Select version 2.0.0 and click on Install (must be version 2.0.0)
7 Go to File > Preferences
8 Open the folder path under More preferences can be edited directly in the file
don't forget to save!
9 Go to packages > esp8266 > hardware > esp8266 > 2.0.0 > tools > sdk > include
10 Open user_interface.h file with your favourite text editor or just wordpad.
11 Scroll down and before #endif add following lines: if you cant see correct copy it from the txt file included in the project files
typedef void (**freedom_outside_cb__t)(uint8 status);
int wifi_register_send_pkt_freedom_cb(freedom_outside_cb_t cb); void wifi_unregister_send_pkt_freedom__cb(void); int wifi_send_pkt_freedom(uint8 **buf, int len, bool sys_seq);
Step 3: Download the Project
1 Download project files from here (Credit goes to the orginal creator spacehuhn)
  • https://rebrand.ly/wifijammercode
2 Open Wifi Jammer > esp8266_deauther > esp8266_deauther.ino in Arduino
3 Select your ESP8266 board at Tools > Board. I used NodeMCU 0.9 but you can try NodeMCU 1.0 or Generic ESP8266 Module
4 Select your programmer at Tools > Programmer > ArduinoISP
5 Select the right port no at Tools > Port If no port shows up you may have to reinstall the drivers.
6 Upload!
Your Wifi Jammer is now ready!
Step 4: How to Use Wifi Jammer
1 First power up your ESP8266
You can use your smartphone if you have a USB OTG cable. or micro usb cable with a power bank or usb wall adapter.
2 Now you can controll your jammer using any smartphone or PC just Connect to ESP8266 Module so
Scan for WiFi networks from your Mobile or PC or MAC and connect to AndroidAP . The password is killwifi . You can change this SSID and Password from the code you uploaded. Once connected, you can use this ANDROID app to control this Wifi Jammer https://rebrand.ly/wifijammer
OR you can open up your browser and go to 192.168.4.1
3 You can now scan for networks...
Note: While scanning the ESP8266 will shut down its access point, so you may have to go to your settings and reconnect to the WiFi network manually.
...and start different attacks.
4 Click on the attack tab
choose deauth all
boom everyone on the wifi should be disconnected now
you can try other attacks as well
Happy hacking :)
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
43 Discussions
MustafaT42
Question 3 months ago
im getting this error:
no matching function for call to 'ArduinoJson::DynamicJsonBuffer::DynamicJsonBuffer(int)'
please help
DanilA3
HELP!!!!!!!!!!!!!
Arduino: 1.6.7 (Windows 7), Board: "NodeMCU 1.0 (ESP-12E Module), 160 MHz, Serial, 115200, 4M (3M SPIFFS)"
C:\Users\Danya\AppData\Local\Temp\Rar$DIa0.490\esp8266_deauther\esp8266_deauther.ino:24:17: fatal error: oui.h: No such file or directory
#include "oui.h"
compilation terminated.
exit status 1
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
static-skynet
6 months ago
does it make a difference if i delete the neopixle lines and the OLED lines? keep getting errors regarding them.
LiP3
1 year ago
Hi, i want to know the attack distance of the ESP 8266.
static-skynetLiP3
Reply 6 months ago
no greater than most 2.4Ghz devices. good for coffee shops, bad for airports.
sebiman88LiP3
Reply 1 year ago
around the same distance as your phone
WyattH20
8 months ago
Hey there, I seem to be missing a file?
Error message:
Arduino: 1.8.5 (Windows 10), Board: "NodeMCU 0.9 (ESP-12 Module), 80 MHz, Serial, 115200, 4M (3M SPIFFS)"
In file included from C:\Users\drake\Desktop\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino:13:0:
sketch\functions.h:9:25: fatal error: ArduinoJson.h: No such file or directory
#include "ArduinoJson.h"
exit status 1
Error compiling for board NodeMCU 0.9 (ESP-12 Module).
option enabled in File -> Preferences.
static-skynetWyattH20
Reply 6 months ago
if you go into manage library on your arduino program, type json into the search field, about 3 down will be the arduinojson one you need, just choose the highest NON-BETA addition and hit download.
NoZ2
8 months ago
i have this problem
Arduino : 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Carte : "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Serial, 115200, 4M (3M SPIFFS)"
sketch\APScan.cpp: In member function 'bool APScan::start()':
APScan.cpp:14: error: no matching function for call to 'ESP8266WiFiClass::scanNetworks(bool, bool&)'
results = WiFi.scanNetworks(false, settings.apScanHidden); // lets scanNetworks return hidden APs. (async = false & show_hidden = true)
sketch\APScan.cpp:14:59: note: candidate is:
In file included from sketch\APScan.h:6:0,
from sketch\APScan.cpp:1:
C:\Users\noeze\OneDrive\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:243:12: note: int8_t ESP8266WiFiClass::scanNetworks(bool)
int8_t scanNetworks(bool async = false);
C:\Users\noeze\OneDrive\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:243:12: note: candidate expects 1 argument, 2 provided
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
zmbie123
12 months ago
hey so everytime i try to upload i get this message
Arduino: 1.8.5 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Serial, 115200, 4M (3M SPIFFS)"
C:\Users\Twentytwo\AppData\Local\Temp\Temp1_esp8266_deauther-master (1).zip\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino:11:17: fatal error: oui.h: No such file or directory
#include "oui.h"
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
TheRealGummie
Question 9 months ago on Step 3
How to fix
Arduino: 1.8.5 (Windows 10), Board: "Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck"
Build options changed, rebuilding all
C:\Users\promi\AppData\Local\Temp\Temp1_esp8266_deauther-master.zip\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino:11:17: fatal error: oui.h: No such file or directory
#include "oui.h"
exit status 1
Error compiling for board Generic ESP8266 Module.
Prince FloroS
2 years ago
How to fix this error?
exit status 1
cannot convert 'uint8_t* {aka unsigned char*}' to 'uint8** {aka unsigned char**}' for argument '1' to 'int wifi_send_pkt_freedom(uint8**, int, bool)'
abhishekgoel11Prince FloroS
Reply 9 months ago
Open user_interface.h with a text editor
typedef void (*freedom_outside_cb_t)(uint8 status);
void wifi_unregister_send_pkt_freedom_cb(void);
int wifi_send_pkt_freedom(uint8 *buf, int len, bool sys_seq);
abhishekgoel11
9 months ago
In file included from sketch\Accesspoints.h:11:0,
from sketch\Accesspoints.cpp:1:
Names.h:18: error: 'DynamicJsonBuffer' has not been declared
extern JsonVariant parseJSONFile(String path, DynamicJsonBuffer& jsonBuffer);
exit status 1
when i try to compiled the program this error occurred plz someone help me in this
thanks in advanced
AjmalA8abhishekgoel11
Reply 9 months ago
I have a similar problem in another project. Try downgrading the ArduinoJson library to use 5.x version. ArduinoJson 6.x is still in beta, and has issues.
abhishekgoel11AjmalA8
Reply 9 months ago
please seen above problem and if u have any solution please mention here
abhishekgoel11abhishekgoel11
Reply 9 months ago
if i tried this step which u mention in (tried arduinojson 5.x) the result error is
C:\Users\DR\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/DynamicJsonBuffer.hpp:66: undefined reference to `__cxa_guard_release'
sketch\SSIDs.cpp.o:(.text._ZN5SSIDs4loadEv+0x8d): undefined reference to `__cxa_guard_acquire'
sketch\SSIDs.cpp.o:(.text._ZN5SSIDs4loadEv+0x9e): undefined reference to `__cxa_guard_release'
sketch\Settings.cpp.o: In function `ArduinoJson::JsonObject::invalid()':
C:\Users\DR\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/Serialization/JsonSerializerImpl.hpp:56: undefined reference to `__cxa_guard_acquire'
C:\Users\DR\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/Serialization/JsonSerializerImpl.hpp:56: undefined reference to `__cxa_guard_release'
collect2.exe: error: ld returned 1 exit status
exit status 1
