DIY Wipe-On Poly Hack
36,522
539
47
About: Hi I'm Linn and on my Youtube Channel I have lots of great videos about building, construction and fun projects. You can also check out my site @ http://darbinorvar.com
Making your own DIY wipe-on poly finish for wooden projects is easy. Wipe-on poly is great because it dries quickly, you don't need to dirty a brush and it doesn't drip. However, to buy the solution in the store can be expensive, especially considering how easy it is to make your own.
After a couple of tests, I have come up with a solution that is pretty much identical to the one you buy in the store, in terms of finish and color. So let's create a custom pump can to make it easier to access the finish, and then mix our own solution.
Step 1: Make the Can
Materials:
  • 1 quart paint can
  • replacement soap dispenser
Tools
  • drill
  • 3/8 inch drill bit
Method:
Start with a clean 1 quart paint can. Measure the center of the lid and drill a hole using the 3/8 inch drill bit. Insert the replacement soap dispenser pump into the hole, push it down all the way. Here you can secure it with epoxy or hot glue to create a seal.
Step 2: Mix the Solution
Supplies:
  • Polyurethane
  • Mineral Spirits
Method:
In the can, pour in 1 cup of polyurethane and 1 cup of mineral spirits. Mix well, then put on the lid with the attached soap dispenser pump and secure the lid in place using a mallet. Try the pump out and you're ready to use your new wipe-on poly pump can!
Tip! In between uses, it can be a good idea to close off the end of the nozzle with a piece of tape to prevent air from entering the can, which will affect the finish over time.
Step 3: Conclusion - Watch the Video
For a more in depth look, check out the video that goes over all of the steps to make this simple DIY wipe-on poly finish.
    • Remix Contest
      Remix Contest
    • Build a Tool Contest
    • Epilog X Contest
      Epilog X Contest
    47 Discussions
    I store all my wipe on finishes like Danish oil, wipe on poly, beeswax oil etc in squeezy bottles that have a flip top cap with the hole in, some even have small rubber type seals within the holes - usually mayo. It's not a perfect seal, so if you don't use regularly you could add a slip of greaseproof paper or clingfilm (saran wrap for you over there :)) under the cap.
    Simply pop the cap and squeeze a small amount, no need for a paint kettle or other container. It even works for brush on paste waxes.
    Just a thought.... could you also just use an empty hand soap dispensor? It wouldn't be a good place to mix up the solution, but you could slip it into a pocket while you are working on a project. I am always walking around a table or dresser I am refinishing and having to go back to my workbench or wherever I have my poly safely set away from what I am working on. I might just have to give that a try next time I am doing this.
    darbinorvarmking37
    Reply 4 years ago on Introduction
    I can't think of anything that would not work. You can always try a sample and see how that goes.
    Beagles
    Good instructions. Think that soap pump will gum up over time, just the way they do when used on soap. When I have made my wipe on Poly, it is stored in a tin with a screw on top or a wine bottle with a screw on. A suggestion was made, that linseed oil could be added, if you do be sure it is the boiled type (not raw) or it will never dry. A couple of old painter tricks to keep your mix fresh and reduce skin over.....before you put on the lid, blow through a straw into your container, that will displace any O2 with your CO2. Or, shoot your propane torch, unlit of course, into the container, it will displace the O2 also (heavier).
    If you wish to experiment a bit on colours, use marine varnish with various ratios and you can add some stain for varied colours. A varnish/stain mixture has been available commercially in the past.
    AndiMN
    4 years ago
    Just a thought. Could a vacuum pump & stoppers like you use to get air out of opened bottles of wine be used to keep the mix from being exposed to air & curing in the can/jar? You could take the dispenser pump out, put the stopper in the hole, then use the vaccuum pump to remove the air?
    kuma.rhyuAndiMN
    If you attempt to vacuum out the air from the storage container, you are just boiling out the lightest components of the mixture faster and are more likely to cause the mixture to change consistency and usefulness more quickly than if you just seal it up.
    MeursydotesAndiMN
    If you are mixing in 50% mineral spirits, then oxygen exposure will be a non-issue.
    It looks like good stuff you made. But does anyone have a suggestion where to find the Dutch translations for "wipe-on poly finish", "polyurethane" and "mineral spirits". Alas dictionaries are useless for these kind of words.
    I did use polyurethane lacquer in the past called "Cowirant" which I loved, it was German stuff. But cannot find it anymore. Would that be the same as your "polyurethane"?
    Mineral spirits (en-US) = White spirit (en-GB) = Terpentine (nl). Polyurethane is (most likely) polyurethaanhars. A quick Google search tells me the minwax stuff is hard to find in the Netherlands.
    GenerallyOdd
    I use canning jars for a lot of stuff. For stuff that is sensitive to UV exposure, I just stuff the jar in old socks and store in the back of the pantry which works PRETTY well - but I got some PlastiDip and am going to use that to cover a case of jars.
    John916R
    Great article. I mix mine as needed and add a small amount of Japan Dryer to the mix. It will give you a much faster drying time. By thinning down the poly, you also reduce the gloss of the original product.
    MeursydotesJohn916R
    Adding Japan Dryer does not change the curing time of the product. It only shortens the skinover time. The curing of the alkyd resin is due to oxygen curing and is not affected by the Japan Dryer.
    John916RMeursydotes
    Drying time and cure time are two different states. The fast drying time allows me to apply multiple coats before the coating cures. This allows for a better bonding of the two coatings without the recommended light sanding.
    zchais
    I did this recently. It's just thinning varnish so it's much runnier. It takes a long time to mix so much thinner (mineral spirits... Meths!). And make sure not to whisk cos you don't want bubbles(!). But do mix properly as it'll just be thinner at the top!
    Tip: Instead of the squirt gun, you could try plugging in a vinaigrette pourer.
    Could one use a glass canning type jar, e.g., Mason Jar, peanut butter jar, and just use a twist cap? Then you could remove the pump, clean it and put a piece of tape over the hole. Good idea to tape the pump to the jar. Also, you could see exactly how much product you have left. This is a good video, I'm planning on staining and varnishing my window sills soon. Thanks.
    Yes, glass would really be better. You just have to make sure you don't expose the mix to too much air or it will start to cure in the jar.
