Electronic Component Plaque for 1000 Instructables Followers!
3,497
21
11
About: -----------------------------------------------------------------16 year old, sick with a deadly disease called DIY-itis!-----------------------------------------------------------------Hi FTC! My I'bles con...
̶I̶n̶ ̶t̶h̶i̶s̶ ̶I̶n̶s̶t̶r̶u̶c̶t̶a̶b̶l̶e̶,̶ ̶I̶ ̶w̶i̶l̶l̶ ̶r̶e̶v̶i̶e̶w̶ ̶t̶h̶e̶ ̶s̶u̶p̶e̶r̶ ̶c̶o̶o̶l̶ ̶p̶l̶a̶q̶u̶e̶ ̶t̶h̶a̶t̶ ̶I̶n̶s̶t̶r̶u̶c̶t̶a̶b̶l̶e̶s̶ ̶s̶e̶n̶d̶ ̶y̶o̶u̶ ̶w̶h̶e̶n̶ ̶y̶o̶u̶ ̶r̶e̶a̶c̶h̶ ̶1̶0̶0̶0̶ ̶f̶o̶l̶l̶o̶w̶e̶r̶s̶.̶JUST KIDDING!
Did you know that I recently hit 1000 followers and 1 MILLION views on Instructables? I am extremely excited to finally reach both milestones, so in this Instructable, I'm going to make myself my own plaque!
I got the idea for making this from Youtube. YouTube sends you a (non-homemade!) "play button" plaque when you reach 100K, 1M, or 10M subscribers.
Since almost all of my projects and Instructables are about woodworking and electronics, I thought I would make my own from scrap wood, and decorate it with some useless electronic components, which I have accumulated over the years, and never put to use so far...
If you'd like to make your own plaque, along with the wood and components that are listed above, you'll also need a hand saw, some measuring and marking tools, wood glue, and some CA glue.
Pssst! Want to see what I'll make for 2000 followers? Follow me on Instructables! :)
Step 1: Choose Your Electronic Components
To start the project, I went through all of my containers that had electronic components, and selected the specific ones that I wanted.
Add whatever you want!: Nuts, bolts, bearings, diodes, transistors, switches, LED's, connectors, resistors, screwdriver bits, heatsinks, springs, potentiometers, motors, Solar panels, coils, capacitors, Fuses, camera sensors, and more! (And most importantly don't forget the Instructables sticker!)
Ceramic capacitors, anyone?
Step 2: Cut Wood to Size
I then went through my pile of wood, and selected three pieces that I thought would look nice. After doing that, I got the idea of making it a bit fancier, and cut off the corners in a 45 degree angle. While doing this, I also thought of a quick tip for people that don't have Miter-Saws, like me: start the cut with a hacksaw, and finish the rest with a hand saw.
I used the hand saw that I won in the Instructables 2015 Shelving Contest to cut the board to the length that I wanted. This saw is EXTREMELY sharp. It took me about 5 seconds to saw through each one!
Step 3: Glue the Boards Together
After I had finished mitering the corners, I applied wood glue to the boards, and clamped them together. Since I wasn't able to use regular clamps, I used CA glue to hold them in place while the wood glue dried...
Step 4: Add the Instructables Sticker!
While the glue was drying, I glued the Instructables sticker to the middle of the plaque. This is the most important part of this Instructable. Do not forget to do this!
Do I need to provide instructions on how to do this? :)
Step 5: Arrange the Electronic Components
Since I had already chosen which the components I wanted, all I had to do was arrange them in the way that I wanted. I wanted it to look like they were placed on totally randomly, and I think I did a pretty good job. You tell me!
If any of the components that you choose have long legs, I recommend that you snip them off.
Step 6: Glue the Electronic Components!
I used some CA glue to glue all of the components onto the wood. I suppose other adhesives will work too, but super glue is cheap, and cures really quickly.
If you LOVE watching videos of stuff that doesn't even move, you can click here to watch my video about the plaque. If you liked it, make sure to check out my new YouTube Channel, as I upload quick videos of my projects in action, and more!
DONE! Now all I have to do is sneak into Peter Brown's shop, and dunk it in Epoxy!
How would YOU decorate YOUR plaque?
Don't forget to Follow me on Instructables, I have over 80 Instructables that I'm sure you'd like!
DON'T BE SHY! Liked it? Let me know! Didn't like it? Let me know why!
I read ALL comments, and reply to as many as I can, so make sure to leave your questions, suggestions, tips, tricks, improvements, and any other ideas in the comments below! - Thanks!
THANK YOU INSTRUCTABLES!!!
    • Paper Contest
      Paper Contest
    • Epilog X Contest
      Epilog X Contest
    • Remix Contest
      Remix Contest
    11 Discussions
    Yonatan24
    2 years ago
    ​Do you want a FREE PRO Membership?
    I'm giving a FREE 3-Months PRO Membership to the first member that makes their own wood & electronics plaque!
    Here's what you have to do to be able to receive the free membership:
    1. Follow me on Instructables
    2. Reply to this message with pictures of the end result (Don't forget to click "I Made It!")
    3. Nothing! I will PM you the free code!
    lucanletterYonatan24
    Reply 2 years ago
    should I use wood planks as a base, or could I also use for example some circuitboards? (just in case that I'll make it :D )
    Yonatan24lucanletter
    Reply 2 years ago
    EDIT:
    I'm giving a FREE 3-Months PRO Membership to the first member that makes their own plaque from junk materials!
    Any material that you want.
    ThirdEarthDesignYonatan24
    Reply 2 years ago
    Nice idea, kinda like it :)
    I'd just call it "Instructbables Plaque from Salvaged Components"
    Reply 2 years ago
    Did you used to have a comment here asking for name suggestions for this project or did I just totally imagine that?
    offseid
    2 years ago
    Congratulations on your achievements! :)
