DIY Carbon Tape Heated Gloves V1.0
56,205
122
57
About: DIY carbon heated clothing.
diy heated clothing kit
I bought a carbon heating flex tape from www.carbonheater.us (or on Amazon) and sewed it into an ordinary insulated fleece gloves.
For every glove I used 150 cm of carbon. It powered by 12 V. Current is about 1,5A for each one.
Supplies:
Step 1:
New glove (on the left) has 3 layers (on the right).
Step 2:
Tape sewed by hands on the inner side of glove . Connected in parallel 2 x 75 cm.
Because of tape is thin and very soft I placed it directly to fingertips side.
Step 3:
You can sew wire to carbon tape to make a good and flexible connection.  The contact place shouldn't be hotter then the tape itself. If not you must increase the contact area.
Step 4:
Now carbon tape placed between two gloves.
Step 5:
Step 6:
Ready to use. Very comfortable with my heated vest and insoles.
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    57 Discussions
    knickersintheoven
    3 months ago
    Not much info here. Can we get a little more detail? Not quite understanding the setup/battery pack/specs.
    john_john
    1 year ago
    Hello @Shenzhen, which temperature do you advise to target for for gloves?
    Shenzhenjohn_john
    Reply 1 year ago
    The most of factory made heated clothing heat up to 75C but of course should have a dimmer.
    john_johnShenzhen
    Reply 1 year ago
    75°C in gloves? I 'm surprised,it seems to be very hot.
    If i'm right with your gloves (12v, 75cm tape length) you are around 65°C, is it enough or not?
    I would have target 30°C,is it too low (with an ambiant temp around 0°C)?
    Shenzhenjohn_john
    Reply 1 year ago
    The main question is the total power. If you have enough power for a surrounded temperature and a surface area you maybe fill comfortable even at 30C. But usualy it's difficalt to make it xxC deg + xx power/area simultaneously. Moreover if your body (or fingers) already cold but you just powered your heater at 30-40C (maybe more) you doesn't fill it sometime because carbon never reach that 30-40C and has to heat your cold body untill it became warm that regured lot of time and power. You can make it faster with more power per area or with more temperature. A thin heater gets more power per area and you will fill it immediately even with a low temp (30-40C) after power but it's wrong filling. Only small area bacame warm but whole the body doesn't. The most of Chines heated clothing made the same way.
    Shenzhen
    2 years ago
    For me it should be at least 10W per glove. For that power you need 10W : 3.7V = 2.7A. This big current is not good for any battery but of course it will work. With one 18650 Panasonic 3.4Ah 3.7V the run time will be obout 1.2 hour. The bad thing you have to use 3-4 pieces of carbon 20-25cm of length and connect them in parallel.
    scoottyy
    2 years ago
    Would a 3.7v battery for each glove be warm enough for a cold winter?
    (what battery set up do you use?)
    joshuac102
    3 years ago
    Can this generate 120 deg F to 140 deg F temps for about a 2 hour time frame on batteries?
    Shenzhenjoshuac102
    Reply 3 years ago
    Yes, you can get it with 0.8-0,9 meter of 15mm carbon tape at 12v. It can heats upto
    120 deg F to 140 deg F. You should notice it's just 9-10 Watts of power and maybe not enough for some applications. You can connect two or more carbon stripes connected in parallel to increase the power.
    Working time depends on heated clothing power consomption and you batteries power capacity. If you will use Panasonic 18650 3400 mAh (the best for now) connected 3 in series, the run time will be more than 3 hours with one stripe of carbon tape 0.8-0,9 meter of 15mm.
    SteveB136
    3 years ago
    so if i use normal batteries like duracell AA 1.5 volt, is it guna work ?
    ShenzhenSteveB136
    Reply 3 years ago
    Yes, but you should connect them in series to get more voltage. At least 6 volt.
    Conney
    3 years ago
    Hi, Shenzhen. Would this project be safe to be used with a USB charger (like a cell phone charger)? I want to make gloves to use while I type on the computer when is too cold. Would a wall plugged charger be safe? Thanks a lot.
    ShenzhenConney
    Reply 3 years ago
    The most of USB gives 0,5A or less so the total power is just 2,5W (5V x 0,5A = 2,5)
    But if your charger can 2A you get 10W of heat. The problem is you have to change length of carbon and wiring to work at 5V.
    Is it safe...? Well it is a charger and does not designed to work with a full power for a long time. Some of them does not have overheat and short circuit protection. It is not the best idea to use a charger instead of a power supply but if you know how to use it it safe enough.
    ConneyShenzhen
    Reply 3 years ago
    Makes sense, thanks a lot!
    ShenzhenMechackM
    Reply 3 years ago
    I like 18659. The best you can buy is Panasonic 3400 mAh. This one is ~12 watts of energy.
    MechackM
    3 years ago
    Here is a picture of the battery,
    It reads: 6f22 size 9v alphacell brand.
    What battery do u recomend i use?
