DIY Video Light (800-watt-equivalent for $86)
30,361
87
33
Griffin builds a powerful, DIY video light for $86, using hardware store parts, and eight 100-watt-equivalent compact fluorescent (CFL) bulbs. Also discussed: three-point lighting and color temperature / white balance.
Light output: 12,800 lumens, or 13 incandescent bulbs worth of power, but uses only 184 actual watts
Color temperature: 5,000 degrees Kelvin (often called "daylight")
Power consumption: draws 3.2 amps
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    33 Discussions
    indianapenguin
    3 years ago
    Would this be an equivalent for those of us without any wiring experience?
    http://www.amazon.com/LimoStudio-Quality-Socket-Adapter-AGG882-/dp/B0091HO0FY/ref=sr_1_2?ie=UTF8&qid=1452638955&sr=8-2&keywords=flourescent+light+photography
    yes and no, i had bought those lighbulbs and they saw 45w but the light intensity its like 23w, the socket base works good you just need better lightbulbs...
    jgderuvo
    3 years ago
    Hey Griffin, the wiring diagram is MIA. Can we get one? Thanks
    MarioD8
    3 years ago on Introduction
    Can i add a dimmer to this project? or i need to buy specific bulbs ?
    ABOBEGRa
    4 years ago on Introduction
    hello >> nice diy
    but where is the links to buy it :)
    i from saudi arebia and we dont have this things
    thanx
    SalterNet
    Could you do the same effect with a power strip, socket adapters and splitters?
    Oh MyD
    one more question. While at Home Depot and aced about the 12 gauge wire I ended up with solid copper 600 volt. can that be used as well?
    Oh MyD
    Thanks for the video!! I'm having a hard time finding the exact AC cable you are using. The folks at home depot pointed be in the wrong direction using your name "bare AC cable". This was after a long blank stare. Is there another name this cable goes by? Or can you direct me to a different place to get it?
    griffinityOh MyD
    Reply 4 years ago on Introduction
    You want an AC power cable with a three-pronged plug on one side, and bare wires on the other side. Tell them you're building your own light, and you need to plug it into the wall.
    speaking12
    This is a great light set! I assume this is your key; are the other two lights in the video what you use to complete the other two points? Also I would like to know what size cfl you'd recommend for a 500W softbox; the photofloods can turn an interior set into a sweatbox. Thanks
    pmuehlhauser
    6 years ago on Introduction
    almost done building this light, putting in 4 switches since a dimmer is not really a good idea since dimmable bulbs cost more and CFL dimmers cost more as well. however since I know close to nothing about power levels, I was wondering is it possible to power this with a lithium-ion battery if so what do I need? if not lithium-ion then lead?
    You won't be able to power this with a regular battery. I've used my light with a "battery" called the Goal Zero Escape 150, but it's about the size of a football.
    griffinitykwaku2814
    The "150" means 150 watt hours, so if your light uses 176 watts (8*22-watt bulbs), one light will last for 51 minutes. Three lights would last 17 minutes.
    dcyr
    Is there any chance you can give a more detailed list no where you got the parts for this from? I have been looking into buying the parts and I cannot for the life of me find it for anywhere near $86 total. That cake pan I can't find for less than like $20 or so. If you could provide stores and such that would be a HUGE help!
    griffinitydcyr
    Reply 6 years ago on Introduction
    I believe I found my cake pan at a Dollar General store. Or perhaps it was Walmart.
    jakehuitt1griffinity
    Reply 5 years ago on Introduction
    Please link all of the things you bought online. I am trying but can get this for under $150.
