DRILL POWERED MINI BIKE
112,515
1,166
114
It's been awhile but I am back for 2015 with my newest creation, this project was in the pipeline for years I have drawn out plans and dreamed about doing it. So I got the chance to bring another dream of mine to life, WARNING this project is not for the ones faint of heart. On a scale of 1 to 10 its a 10 maybe even an 11 on how hard its to make something like this happen. Plus I only had a 30 day deadline keep in mind I work full time 40 hours a week and 2 days off a week. So I only really had 10 days to make this happen.
Step 1: BLOOD SWEAT AND GEARS
This is the heart and soul to this whole project, Drills have plenty of power to offer but its getting going in the right way is the trick. You can go get a right angle attachment and mod it, sadly I don't do things that way. To the CNC and lathe with this assembly. Full aluminum housing with 304 stainless right angle gears and output, to a simple #25 sprocket. The holster is a quick release design with adjustments. Because there are a number of different drills that can be used. I designed it so I will fit different makes and models of drills, just change and shift the holding bracket to make different drills to fit.
Step 2: Getting Power to the Ground
For this project I was using an old pocket bike I found in the trash . The rear rim came with a small light weight sprocket. That's gone and replaced with a bigger #25 sprocket to match the out put. There isn't much to say about this step.
Step 3: Mock Up
On the mock up I needed to make sure the front sprocket lined up with the rear tire. And how I would mount it to the bike. To solve this problem I reused the slotted plate where the engine sat and relocated it on in the frame. Now I need to cut it all apart and re-weld it.
Step 4: FABRICATION
So I relocated the old mount plate to the top of the frame to hold the gear drive. Re enforced the frame and changed the saddle. It was molded with a gas tank cover, So that was removed and needed to do body work to fill in what was missing. I know it looks small but it took about 16 hours of fabrication to get all the parts to work together
Step 5: LIVE TO RIDE
Yes the color changed from a stain to a copper tone gloss. This bike can reach about 35mph on a fully charged I-on battery. It will also turn peoples heads when you zip past them riding on a drill. This bike can fit Rigid, Makita, Dewalt, Ryobi, etc. A drill with about 1700 to 2000+ rpm is ideal to get this bike moving. Overall this bike is a great, fun to ride and handles great.
Step 6: NEW AND IMPROVED UPDATES AND REDESIGNS
This bike have been built in 2015 and since then I've working on improving it and making it better. Run smoother and go faster. Also I needed to make it look cooler because everyone knows if it looks cool in must go faster. This bike had a major problem with popping its chain off the sprocket. So the frame as been completely redesigned so it has better lineament, along with adjusters to keep tension. A better roller to keep the chain from hitting the swing arm what is made from an old long board wheel. To give it a more finished look it received a new saddle, and a candy orange paint job with diamond plate panels. Also a new headlight because I broke the old one OOPS.
Move It
First Prize in the
Move It
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Gardening Contest
    Gardening Contest
114 Discussions
nnfrancois13
Question 3 months ago
would a black and decker 9.6v work? and is it possible to put 2 on?
BooKooDesignsnnfrancois13
Reply 3 months ago
Sorry for the delay I've been alittle busy at my maker space but to your question. No it will not work is this bike at all due to the holster design, and the chuck on the drill must be 5/8" small drills will not work on this platform. Also this bike is known to break drills that are too lite duty. Exciting news is the GEN 3 is going to be released and might be made to order late this year if all goes to plan. This is old which is GEN 1, Generation 3 will have a fully working swing arm, chain guards. Gen 2 saw mostly cosmetic changes. If your interested on knowing more about this Bike or A.I. LABS please let me know. Also what project are you working on?
BooKooDesigns
2 years ago
So I know its been a while since I've posted I first would like to thank all of you for such positive feed back, I other news I am thinking about making more of these bikes for others please feel free on messaging me for more information
kuhldad
2 years ago
Awesome rig! Is it possible to get drawing sheet for the holster/ right angle gear mounting plate?
ac-dcBeachsideHank
Reply 3 years ago on Introduction
It is likely the extra drag of the trailer causes a reduction in travel distance, requires more power than the solar cells on it can create during that period of time. Take a good look at successful solar powered vehicles and you will see they have a very low drag, narrow wheels, light weight, etc.
BeachsideHankac-dc
What you point out are possible factors, however it should also be kept in mind that the bike may well be parked in the sun during shopping or library visits or other intermittent needs, in which case some energy can be replenished. The design of the trailing charger doesn't necessarily have to be a a conventional work either, that is where creative thinking can be employed to overcome and achieve.
Rob54BeachsideHank
Reply 2 years ago
Creative thinking can overcome many PROBLEMS but it cannot overcome the laws of physics. Not even Albert could achieve that.
BeachsideHankRob54
Reply 2 years ago
I think you misunderstand the word "overcome":
... "succeed in dealing with (a problem or difficulty)"
You are assuming it is the same thing as "change", which of course is not possible.
Einstein never sought to change anything, only understand it.
DIY-GuyBeachsideHank
Reply 2 years ago
I like this electric drill powered mini-bike idea a lot!
The "trailer" idea does not have to be the limit of choices.
A folding panel, handlebar mounted panel, side mounted "wings" that lift up; each of these are creative ways to overcome some of the weight increases imposed by a trailer design.
Best not to get locked into one idea when looking for solutions, (or when defending the authority of physics). Creative design can get around physical limitations of specific configurations and no physics principles are broken. Brainstorming design options is one way to explore the results of "purist physics" while improving performance.
holtto1
2 years ago
do u think i could use an angle grinder & battery to power it?
i would probably make bracket to hold the angle grinder against the tire and use friction to go.
PUCKA
2 years ago
theyre good master tool drill?
JosephA45
3 years ago
ive done this myself i have the bike all made but my issue is WHAT DRILL DO YOU USE!!!!!!! mine burned out so i honestly am just looking for an exact answer to what drill will work
