DVD Cases Into Lampshade
661
11
4
About: Hi there, my name is Katarina and I've been an IT technician at Rapid PC Rescue for over 10 years. Apart from being an IT technician I'm also a DIY and crafts enthusiast. I love to learn new things and tech...
I've been in need of a lampshade for a while and now I've finally decided to make one. Whilst searching for suitable materials I came across some old Playstation game cases and here is the rest ;)
Tools & Materials:
  • 6 DVD cases
  • transparent plastic bag
Supplies:
Step 1: Preparing the Cases
First of all I removed the transparent plastics from each of the cases and saved them for later. Then I separated the two halves with a hobby knife and cut away the top and the bottom edges with scissors.
Step 2: Cutting
Next I needed to cut the plastic cases into 1cm strips, to do this I marked the top(s) and the bottom(s) of the cases and scored lines with a hobby knife.
At first I thought it would be quite easy to cut through the plastic cases with a hot knife, but it proved to be quite a lengthy process so I resulted in using a modelling jigsaw which turned out to be much quicker. After this I ended up with 60 1cm strips.
Step 3: Cleaning the Strips
For cleaning the edges of the strips I used a hobby knife with blade No18 followed by scraping with No11.
Step 4: Preparing for Welding
In order to weld the structure together I needed a filament, so I cut up the reminder of the cases with scissors.
Once I done that I printed myself a template and started cutting off the edges for triangles with a hot knife.
Step 5: Welding the Triangles
Before I started the welding process I aligned three pieces onto the template to form a triangle. Next I slid the tip of the soldering iron set at 300°C over all of the joints from both sides. To strengthen the joints I melted the filament into the grooves made by the soldering iron.
Step 6: Coloring
In order to add some color to the lamp shade I placed the transparent plastic film from the cases over the triangle and ran the hot knife along the edges whilst pressing down with a card. I needed to to this for 18 out of 20 triangles, however I only had enough transparent plastic film for 12 triangles so for the remaining 6 I used a transparent bag.
Next I used sharpies in different colors to stain the triangles.
Step 7: The Top Triangle
For the top of the lamp shade I cut out a circle from the back side of a case and cut it furthermore to fit into the triangle, not forgetting about the hole for the lamp fitting. Next I welded the two pieces together adding filament as I went.
In order to achieve the 138.19° angle of the icosahedron I stuck the template to the desk and added a piece of wood positioned so that when two triangles meet they would have the correct angle.
Step 8: Welding
To make the welding process easier I melted the filament in 5 places along the joint whilst pushing two triangles together. This made adding the filament over the joint very easy. Then I just carried on adding the triangles to form the top and the bottom half of the icosahedron.
Step 9: Joining the Halves
Before joining the halves I slid the soldering iron tip over all of the joints on the outside to make them stronger. To finish off I placed the top part onto the bottom and welded them together adding filament wherever needed.
Step 10: Final Thoughts
The project took about 10 hours to finish, which was a little longer than I predicted, but it was worth it. I really like how it turned out and I love the effect it creates on the walls.
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    4 Discussions
    PaulChau
    2 months ago on Introduction
    Hopefully it is still not too early to be upcycling DVD covers now. At first I thought these were CD covers, but little do I know that DVD covers might become obsolete too soon enough when everything goes digital.
    nerdyKatPaulChau
    Reply 8 weeks ago
    The ones I used were from the PS2 game cases, so it was definitely not too early to upcycle those :D
    I love the end effect of this. I reckon you could get the same kind of thing with a little bit of cellophane too but seeing this idea gives me a lot of inspiration. If you could get designs in on the transparent cases, it could end up being a really unique art installation in your home!
