Death of Rats
489
5
About: i would say im a tinkerer who will have a go at most things . I thought I should really should document what I do encase it can ever help others / remind me how I did what I did . On the To Do list for the n...
I have wanted to make a Death of rats fr a while but it wast until I saw the decoration that I was able to
Materials:
Halloween rat
Black materials and basic sewing supplies
Clippers and file
Filmo
Black paint
Gold paint
Stud earring
Supplies:
Step 1: Getting the Rat
Finding the base toy was more luck than anything else. I found it in B&M (Discount / random type store) in the run up to Halloween . He sits about 30 from floor to top of his head and weirdly has bone ears( Anatomy not apparently an issue) ? At first I though "Cute" then I though " I can make my own Death of rats and my weekend was filled with its execution .
Articulation:
Tail rotates
Head rotates on top of spine
Lower jaw hinges
Similar ones I can find online
https://www.amazon.com/Crazy-Bonez-Z18145-Skeleton-Rat/dp/B011BD8JS4
Step 2: Giving Death Some Dignity
First of all he needs robes which I found plans for here
https://www.servantsofthelight.org/knowledge/makin...
Its a fairly simple pattern and I used an old Black pillow case for the material and hand sewed the basic shape.
Obvious Note : You have to scale the plans to your Rat using your common sense / what looks right
Once it was then on him it was given more shape by pinning and sewing to give it more shape. This is easier to do once its over the body as there is not enough articulation to get the robes on after taking them in,
Next the Cape and Caplet
Step 3: Caplet and Body Mods
Again following the instructions for the below
https://www.servantsofthelight.org/wp-content/uplo...
Once this was made I tried to fit it and came up with an issue that I had over looked . His ears , the Capeletjust did not sit right and after some pinning and attempting to fix I decided the ears must go .
Also to justify this I looked up images of DOR and found that the Pail Kidby ones were sans ears which eased the discomfort
http://discworld.com/management/wp-content/uploads...
20 min later with clippers and a file the ears were gone and the Capelet were sitting allot better
Step 4: Something's Missing
At this point I was pretty happy but thought something was missing .....
I realised he needed an Omega pin to show he was the end for rats ( and to keep his robes on )
The backing is from a cheap pair of stud earring with butterfly clasp so it does work as a brooch
I then rolled out some Flimo about 2mm thick and used my smallest cookie cutter to cut out a range of small circles. The raised edge and Omega are made by rolling out flimo , gently laying in the right shape on top of the discs and pressing gently enough for them to stick but not distort, Once baked then were then painted black , details gold and the best one stuck onto the earing stud
Step 5: I Now Have My Own Grim Squeaker
He trned out pretty well but there are more things I would Like to add but unsure if this would be gilding the lilly
Sythe
Hourglass with blue light
Leds in eyes
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    Jobar007
    2 years ago
    SQUEAK!
