Decoy Gift Wrapping
198,126
412
66
About: Concocted Creations From The Mind Of A Maker.
The western world's Winter chill is just beginning to strengthen its clutches throughtout, and with the holiday season just around the corner, as is the secret sinister sweater's league, gift giving from all around is about to sky rocket into overdrive.
You know the drill, Wrap, rip, repeat. With the occasional ear shattering, molar cracking scream evey now and again... But whomever would think to give no more than a second thought to that massive ball of colorful paper, shiny bows and adheasive tape left occupying half the room by mornings end? After all, a present's wrapping is but a flame beneath it's pyre, right? Wrong.
Enter, decoy wrapping. Poised to look the part of an innocently wrapped, absolutely and tremendously terrible gift, all while it's diabolical interior, is anything but!
Likewise, the technique used was perfect for, yet not limited to a power drill. Experiment with it yourself; find the most perfectly imperfect and terribly tremendous decoy that is sure to make that special someone squeal!
Step 1: Materials & Supplies
Besides the actual gift itself, All the materials used in the project will most likely be found already lying around your house. As far as the fake present, I personally decided on a power drill, not only did it work well with the shape of the iPod case, I also found it's form quite recognizable; and, unless you're the crafty type person like me, I'd find it to be rather unusual. (Then again, this is instructables.... Dammit!)
List of supplies:
  • A fake gift (for molding the decoy)
  • The real gift
  • Hot glue gun
  • Hot glue sticks
  • Scissors
  • Cardboard
  • Newspaper (ordinary computer paper should suffice as well)
  • Flour
  • Water
  • Mixing bowl
  • Duct tape/Scotch tape
  • Plastic wrap
  • Utility knife
  • Wrapping paper
  • A bow (optional)
Step 2: Prep Work
Since a major amount of the work here involved paper mache, and in having past experience with it before, I knew this was going to get messy. I needed a way to prevent the drill and it's components from becoming a big goopy mess.
The solution? Simple. One or two layers of ordinary plastic wrap did the trick! After your object has been fully wrapped and sealed, it's time for the next step, prepping the pulp!
Step 3: The Pulp!
Just remember there is no exact recipe when making paper mache pulp, It's really all up to the maker, some people prefer having a thinner pulp and vise versa. Just start with about a cup of flour and slowly add warm water while stirring until it reaches desired consistency, I used a cup of flour to about 2 cups of warm water. Once the pulp is made you'll need to make the strips, I began by laying a sheet of the newspaper flat on the table, I then tore the newspaper into 1 inch wide strips Ripping long ways. You may also cut them using scissors, but I have hear that tearing them makes a stronger bond in the end. Once all this is prepared it's time to start layering!
Step 4: Paper Mache Layering
Paper mache is messy to work with so It's good to have a covered surface Which makes for an easier clean up! To start take a strip of the newspaper, dip it in the pulp and ring off any excess using you're first two fingers, Then start wrapping the Decoy object in all different directions (Random placement makes the strongest bond) once you have the layer complete, repeat the process again to create a second layer. It will take a full 24 hours for the paper mache completely dry.
Here's a time lapse of the coating process:
The whole process took about 20 minutes to complete.
Step 5: Releasing the Mold
When the mold was completely dried I took a utility knife and cut a seem along the middle of it and all around it. then I slowly peeled the mold out from the drill. I was very surprised on how well it turned out! The drill was a little dirty in some area's but was unharmed overall and still worked great!
Step 6: Reinforcements
The two halves were too fragile to just glue back together so I decided to make some reinforcements. To start I took a few pieces of cardboard and cut them to the same shape as the handles, I secured them in place with some hot glue. I then took two smaller pieces and glued them to the handle supports and the section where the handle and the head connect. Next I cut a long piece of cardboard to the width of the head and glued it on the inside. I then did the same thing but at the bottom battery pack section, These will serve as inner supports when the two pieces are sealed together.
Step 7: Back Together Again
After putting strips of glue along the inner supports I put a glob of glue on the seem and spread it along it using a scrap piece of cardboard, You don't have to do this along the whole seem just on the area's like the top and bottom sides, I sealed up All the other area's with strips of duct tape. Afterwards I realized the bottom wasn't totally even so I trimmed it up a bit with some scissors, The iPod fit in perfectly I just used a few dabs of hot glue to keep it from falling. The project it almost complete and there's only one thing  left to do...... Wrapping it up!
Step 8: Wrapping
To get the best "Obvious" look I ended up wrapped the whole present in three sections The base, the handle and the head, depending on what your decoy is, the wrapping process will always vary; So just try to get it nicely fitted and make sure none of the paper mache is being exposed.
Step 9: Weight
Due to restricted time I wasn't able to experiment with adding weight to it, but it definitely was something I thought about. Various objects have various sizes and weights, so depending on the object the remaining space could be filled with something lighter, like a joint compound or possibly a denser substance such as concrete. Again, these are just idea's as I wasn't able to test them, so feel free to try your own idea's and see what works best for you!
Step 10: Complete!
Top the whole thing off with a bow and voila, the perfect gifting gag! I'd absolutely like to add weight to it the next time I attempt this, but overall the project was relatively easy to make and very satisfying to see the finished product!
I wish you the best of luck with you decoy and until next time, happy holidays!
7 People Made This Project!
  • Pie Contest
    Pie Contest
  • Jewelry Challenge
    Jewelry Challenge
  • Fat Challenge
    Fat Challenge
66 Discussions
topkat29
3 years ago
I would do this but I would put a real gift, a decoy gift, or a favorite candy, maybe tickets to some event. I would not take that much time just to give an empty container.
Team Dogoman RCtopkat29
Reply 3 years ago
Did you not see the first few pictures? He put an ipod in the bottom.
topkat29Team Dogoman RC
Reply 3 years ago
I did see them but did not notice the iPod-silly me. Thanks. Happy Holidays.
Tones Shed
3 years ago
awsome, the recipient must have been underwhelmed
king_grimloc
3 years ago
Candy would work as weight instead of concrete, and it would be an addition to the gift.
nealbirch
3 years ago
Hershey Kisses are nice and heavy.
rayleb
3 years ago
Very cool, haven't done pranks lately because I ran out of ideas, tadaa, new ideas abound
maxhirez
3 years ago
I would love to get a hard-back copy of "War and Peace" into what looks like a Scotch whiskey bottle. Nice work!
kevincarruthers
3 years ago
I think this is great. My son is a hunter so I think I'm going to wrap a "shot gun" up for him
vatech90
3 years ago
Great idea! I'm always trying to find ways to disguise gifts for my kids.
gregdavid
3 years ago
I would not want to end up with knife marks on my drill when I cut the mold free. If I were to do this, I would use something a bit thicker & more protective than just the two layers of plastic wrap. Perhaps a couple old socks or nylons or some sort of cloth ribbon wrapped all around first, not unlike is done for a human cast to help protect the skin esp when the cast is removed. Then the plastic wrap in between for release, so the cloth does not become part of the cast.
gregdavidgregdavid
Reply 3 years ago
Still very cool idea. Gonna have to try it someday. Make a big one that looks like a vacuum cleaner, blender or mop (etc.) for one's wife or loved one with some very fabulous jewelry or lingere inside!
SwiperF
3 years ago
On Step #5: Releasing the Mold.
You don't need to cut the mold all the way just to get the object out.
You can cut partially then pull out the object, put reinforcements, insert the gift, close the mold, put more paper mache layers, then wrap the gift,
Terranan
3 years ago on Introduction
This is jus beautiful... Though, being instructables, I think a lot of us would be disappointed that it wasn't a drill. ;p
Stryker
4 years ago on Introduction
Thanks for posting. I made mine out of insulation board and hollowed out the "battery" area to put the gift. It's the same thickness as the drill but less work. Also cut out a wood saw shape from coroboard.
kouraf16
When I was in the university, in a class we had to wrap plushies in plastic wrap, then with simple transparent tape. The resulting "cocoon" was surprisingly durable and it was much easier to make than papier-mache. You should try that as well. Also you shouldn't ask why I was making plushie cocoons in university. To this day, I wonder myself.
jtmcdole
4 years ago on Step 9
This is genius. I usually hide gifts inside of other gifts, al'la russian nesting dolls, but this is just fun 'evil' that I will employ in future gifting. Thanks!
