Demogorgon From Stranger Things
21,777
70
20
About: My name is Lina Toro, I live in Medellin, Colombia and I´ve been a makeup artist for more than 5 years. I´m a self taught makeup artist specialising on editorial makeup and special effects.
This is my Makeup / FX created from scratch for the character of the Demogorgon.
I made this using stuff I had laying around at home and some supplies I collected whilst doing (or trying to do) basic special FX. I used materials such as paper, glue, wire and paint cause I also enjoy doing crafts at home to relax and I thought this would be an easier way to create something without having to invest a ton of money.
MATERIALS USED:
-random thick plastic skull mask
- elmers glue and water mix (half and half)
- a drill
- clear acrylic paint
- coloured paint in red, beige and black
- wire
- newspaper
- cold porcelain
- coffee diluted on water
- a mix of flour, latex and red food coloring (paste texture)
- velcro stripes
- liquid latex
Supplies:
Step 1: Measure the Mask to Your Face
Measure the mask to your face and using the same holes you made to attach the "leafs" add velcro stripes on the back of your head so you can wear it comfortably.
For better support I added one on the top part and two on the sides, this will make it more confortable to wear and make all the weight lay on the head instead of the sides.
Step 2: Finish Off My Making the Neck With Latex
Add a light coat of vaseline to your neck and using toilet paper and latex make the neck piece as desired. Once it dries take it off and let it dry completely before painting it over.
I used acrylics for painting the piece and special fx wax to make sure the neck piece would "melt" seamlessly to my own neck. Then used cream makeup to merge the neck piece to the rest of my body carefully watching that the colors and textures I used would match each other.
Step 3: You´ll End Up With Something Like This
This is the end result, just shoot it or wear it and enjoy your demogorgon look!
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    20 Discussions
    blem94361
    Question 7 months ago on Step 3
    Wha? I did not understand a thing here. Did you have to buy the mask? Did you make it?
    bwywxbw
    Question 10 months ago on Introduction
    where are the instructions? How did you paint it? etc
    StephanieH188
    1 year ago
    Up until recently this had the full step by step instructions. Now it's down to 3 and it's missing the beginning steps of how to create the leaves/latex/teeth. Is there away to get these back?
    JJ67
    1 year ago
    that's amazing! you did a fantastic job!
    LuPhi
    2 years ago
    wow this is just disgusting in every dimension.
    that was a compliment. but seriously it looks so ugh please stay away from me ?
    XaqFixx
    2 years ago
    This is the sh*t of nightmares... in the best possible ways. Guillermo del Toro needs to hire for practical effects, your 'ibles brings me more joy than Tom Savini's books.
    invadersilkeXaqFixx
    Reply 2 years ago
    and this totally my favorite comment EVER...you have no idea how freaking happy this made me! I adore both Savini and del Toro...thank you from the bottom of my heart! you just made a colombian girl SUPER happy!
    invadersilkenumbass
    Reply 2 years ago
    I made it to wear it for photos, shot it for my makeup portfolio but the weight falls on the head so it´s pretty confy I must say. I think if you like to wear it for a party you should try doing bigger holes on the eyes and then painting your eye area with black greasepaint so they wont stand out through the mask.
    Also using less material for the "leafs" or making less "leafs" would help with the weight if you dont feel confortable with having a big piece on your head at all time. The thicker the layers of paper on the "leafs" the heavier it would be. You can also add some sort of stick on the bottom to hold it with your hands if you still find it too heavy for you.
    The weight is confortable so it depends on your taste but I found it pretty wearable for the 4 hours I had it on.
