Design Your Own Raspberry Pi Compute Module PCB
44,218
176
15
About: I'm an electronic and computer engineer. Web development and electronics design is what I mostly do, but I do enjoy working on personal projects that involve electronics but also 3D printing. And if it happe...
If you’ve never heard of the Raspberry Pi Compute Module before, it’s basically a fully fledged Linux computer with the form factor a laptop RAM stick!
With it becomes possible to design your own custom boards where the Raspberry Pi is just another component. That gives you an enormous amount of flexibility as it allows you to have access to a much greater amount of IO pins, while the same time you get to choose exactly what hardware you want on your board. The on-board eMMC also eliminates the need for an external micro SD card, which makes the Compute Module perfect for designing Raspberry Pi based products.
Unfortunately, while the Compute Module allows you to do all this it still appears to be lacking in terms of popularity compared to the traditional Raspberry Pi Model A and B. As a result, there aren’t many open source hardware projects out there based on it. And for anyone who might want to get started with designing their own boards the amount of resources they have is rather limited.
When I first got started with the Raspberry Pi Compute Module a few months ago, that was exactly the issue I was faced with. So, I decided to do something about it. I decided to design an open source PCB based on the Compute Module, that is going to have all the basic features that make the Raspberry Pi great. That includes a camera connector, USB host, audio output, HDMI and of course a GPIO header compatible with the regular Raspberry Pi boards.
The goal of this project is to provide an open source design for a Compute Module based board, that anyone will be able to use as a starting point for designing their own custom board. The board was designed on KiCAD, an open source and cross platform EDA software package, in order to allow as many people as possible to take advantage of it.
Simply grab the design files, adapt them to your needs and spin your own custom board for your project.
Step 1: Parts and Tools
To get started with the Raspberry Pi Compute Module you are going to need the following parts:
1 x Raspberry Pi Compute Module 3 - I highly recommend getting the regular version which includes the on-board eMMC and not the Lite version. If you want to use the Lite version in your project you’ll have to make a few changes to the design, and that includes adding a micro SD card connector. Finally, I have only tested the board with the CM3 and I cannot guarantee that it will work with the first CM version that was released back in 2014.
Update 29/1/2018:
It appears that the Foundation has just released the Compute Module 3+ and not only that, but now it also comes with the option for an 8GB, 16GB or 32GB eMMC! According to the datasheet, it appears that the CM3+ is electrical identical to the CM3 which means that it’s basically a drop in replacement for the CM3.
1 x Compute Module IO Board - My design was intended to serve as a starting point for designing your own custom board based on it, not to be replacement for the Compute Module IO board. So, to make your life easier I highly recommend getting your hands to an IO board and use that for development before moving to a custom board. Apart from giving you access to every single pin of the CM plus a variety of connectors, the IO board is also needed for flashing the on-board eMMC. Which is something that you cannot do with my board, unless you do some changes to the design first.
1 x Raspberry Pi Zero Camera Cable or Compute Module Camera Adapter - On my design I’m using a very similar camera connector to the one used by the Compute Module IO Board and the Raspberry Pi Zero. So, in order to attach a camera you're either going to need an adapter cable designed for the Pi Zero or the camera adapter board that comes together with the Compute Module Development Kit. As far as I know, purchasing the adapter board separately is quite expensive. So, if you like me decided to buy your CM and IO Board separately to save some money, I advise you to get the camera adapter cable designed for the Pi Zero instead.
1 x Raspberry Pi Camera Module - I have only tested the board with the original 5MP camera module and not the newer 8MP version. But since the former appears to be working just fine I see no reason the later wouldn’t as it is supposed to be backwards compatible. Either way, the 5MP version can be found for less than 5€ on eBay nowadays which is why I’d recommend getting one.
4 x Female to Female Jumper Wires - You are going to need at least 4 for configuring the camera connector on the IO board, you’ll likely want to get more though. They aren’t needed for the custom board but can be useful if you plan attaching any external hardware via the GPIO header.
1 x HDMI Cable - I decided to use a full size HDMI connector on my board to eliminate the need for adapters. Of course, if you prefer using a mini or even a micro HDMI connector feel free to adapt the design to your needs.
1 x 5V Micro USB Power Supply - Your phone charger should probably do just fine for most cases as long as it can provide at least 1A. Keep in mind that this is just a general value, your actually power requirements are going to depend on the hardware you decide to include on your custom board.
1 x USB Ethernet Adapter - If you plan installing or updating pretty much any package on your system, you’re going to need at least temporary Internet access. A 2-in-1 Ethernet adapter plus USB hub is probably a good combo as you only have one USB port available. Personally I use the Edimax EU-4208 which works out of the box with the Pi and doesn't require external power, but it doesn't have a USB hub built in. If you are looking into buying a USB Ethernet adapter here you can find a list with ones that have been tested with the Raspberry Pi.
If you want to add more USB ports and even Etherent directly on your custom board, I’d suggest having a look at the LAN9512 from Microchip. It is the same chip used by the original Raspberry Pi Model B and is going to give you 2 USB ports and 1 Ethernet port. Alternatively, if you need 4 USB ports consider having a look at its cousin LAN9514.
1 x DDR2 SODIMM RAM Connector - This is probably the most important component of the entire board and likely the only one that can't be easily substituted. To save you from the trouble the part that you should get is the TE CONNECTIVITY 1473005-4. It is available from most major suppliers including TME, Mouser and Digikey, so you should have no problem finding it. Be very careful though, double check and make sure that the part you’re ordering is in fact the 1473005-4. Don’t make the same mistake I did and get the mirrored version, these connectors aren’t cheap.
For the rest of the parts that I choose to include on the board you can take a look at the BOM to get more information, I tried to include links to the datasheets for most of them.
Soldering Equipment - The smallest components on the board are the 0402 decoupling capacitors, but the HDMI as well as the camera and the SODIMM connectors can also be a bit challenging without any kind of magnification. If you have good experience with SMD soldering thought it shouldn’t be a big issue. Either way, if you happen to have access to a microscope I highly recommend it.
Step 2: Flashing the EMMC
First thing you need to do before you start using your Compute Module is flashing the latest Raspbian Lite image on the eMMC. The official Raspberry Pi documentation is very well written and describes the whole process in great detail for both Linux and Windows. For that reason I’m only going to describe the steps you need to take very briefly on Linux, so they can serve as a quick reference.
First of all, you need to make sure that you have your IO board set to programming mode and the Compute Module is inserted to the SODIMM connector. To set the board to programming mode move the J4 jumper to the EN position.
Next, you are going to need to build the rpiboot tool on your system so you can use it to obtain access to the eMMC. To do so, you need a copy of the usbboot repository which can be obtained easily using git as follows,
git clone --depth=1 https://github.com/raspberrypi/usbboot && cd usbboot
Now, in order to build rpiboot you need to make sure that both libusb-1.0-0-dev and make packages are installed on your system. So, assuming you’re on a Debian based distro such as Ubuntu run,
sudo apt update && sudo apt install libusb-1.0-0-dev make
If you don't use a Debian based distro the name of the libusb-1.0.0-dev package might be different, so make sure to find how it is called in your case. Once the build dependencies are installed you can build the rpiboot binary simply by running,
make
After the built is complete run rpiboot as root and it will start to wait for a connection,
sudo ./rpiboot
Now plug the IO board to your computer by connecting a micro USB cable to its USB SLAVE port and then apply power to the POWER IN port. After a few seconds the rpiboot should be able to detect the Compute Module and allow you access to the eMMC. That should result to a new block device appearing under /dev. You can use the fdisk program to help you find the name of the device,
sudo fdisk -l
Disk /dev/sdi: 3.7 GiB, 3909091328 bytes, 7634944 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x8e3a9721</p><p>Device     Boot  Start     End Sectors  Size Id Type
/dev/sdi1         8192  137215  129024   63M  c W95 FAT32 (LBA)
/dev/sdi2       137216 7634943 7497728  3.6G 83 Linux
In my case it was /dev/sdi as I have quite a few drives already attached on my system, but yours will most definitely vary.
After you’ve been absolutely sure you have found the correct device name, you can use dd in order to burn the Raspbian Lite image to the eMMC. Before doing that though, make sure that there aren’t any partition of the eMMC already mounted on your system.
df -h
If you find any unmount them as follows,
sudo umount /dev/sdXY
Now be extremely careful, using the wrong device name with dd can potentially destroy your system and cause data loss. Do not proceed with the next step unless you’re completely sure that you know what you’re doing. If you need any more information please have a look at the documentation regarding this.
sudo dd if=<date>-raspbian-stretch-lite.img of=/dev/sdX bs=4M && sync
Once the dd and sync commands finish, you should be able to unplug the IO board from your computer. Finally, don’t forget to move the J4 jumper back to the DIS position and your Compute Module should be ready for its first boot.
Step 3: First Boot
Before booting for the first time make sure to plug a USB keyboard and an HDMI monitor to your IO board. If everything goes as expected and your Pi finishes booting, having them attached will allow you to interact with it.
When you’re prompted to login use "pi" for the username and "raspberry" for the password as these are the default login credentials. You can now run some commands to make sure that everything is working as expected as you’d normally do on any Raspberry Pi, but don’t attempt installing anything yet as you still don’t have an Internet connection.
An important thing you need to do before shutting your Pi down is enabling SSH, so you can connect to it from your computer after the next boot. You can do that very easily using the raspi-config command,
sudo raspi-config
To enable SSH go to Interfacing Options, select SSH, choose YES, OK and Finish. In case you’re asked if you want to reboot decline. After you are done shutdown your Pi and once it finishes remove the power.
sudo shutdown -h now
Next, you need to establish an Internet connection using the USB Ethernet adapter that you should already have. If your adapter also features a USB hub you can use it to plug your keyboard if you like, otherwise you can just connect to your Pi over SSH. Either way, keep the HDMI monitor plugged at least for now, to make sure that the boot process finishes as expected.
Also, near the end it should also show you the IP address that your Pi got from the DHCP server. Try using this to connect to your Pi via SSH.
ssh pi@<ip-address-of-pi>
After successfully connecting to your Pi over SSH you no longer need the monitor and the keyboard plugged in, so feel free to unplug them if you like. At this point you should also have access to the Internet from your Pi, you can try pinging something like google.com to verify it. After making sure that you have access to the Internet it’s a good idea to update the system by running,
sudo apt update && sudo apt upgrade
Step 4: Configuring the Camera
The biggest difference between a regular Raspberry Pi board and the Compute Module is that in the case of the later apart from just enabling the camera by using raspi-config, you also need a custom device tree file.
You can find more information regarding the configuration of the Compute Module for use with a camera in the documentation. But in general, the camera connector among the others also features 4 control pins, which need to be connected to 4 GPIO pins on the Compute Module, and it is up to you to decide which ones while designing your custom board.
In my case, while designing the board I choose CD1_SDA to go to GPIO28, CD1_SCL to GPIO29, CAM1_IO1 to GPIO30 and CAM1_IO0 to GPIO31. I choose these particular GPIO pins as I wanted to have a 40 pin GPIO header on my board, that also maintains compatibility with the GPIO connector of the regular Raspberry Pi boards. And for that reason I had to make sure that the GPIO pins I’m using for the camera don’t also appear in GPIO header.
So, unless you decide to make changes on the wiring of the camera connector, you need a /boot/dt-blob.bin that tells your Pi to configure GPIO28-31 as described above. And in order to generate a dt-blob.bin, which is a binary file, you need a dt-blob.dts to compile. To make things easy I’m going to provide my own dt-blob.dts for you to use which you can then adapt to your needs if you have to.
To compile the device tree file use the device tree compiler as follows,
dtc -I dts -O dtb -o dt-blob.bin dt-blob.dts
I'm not sure why but the above should result to quite a few warnings, but as long as the dt-blob.bin has been generated successfully everything should be fine. Now, move the dt-blob.bin you just generated to /boot by executing,
sudo mv dt-blob.bin /boot/dt-blob.bin
The above will probably give you the following warning,
mv: failed to preserve ownership for '/boot/dt-blob.bin': Operation not permitted
This is just mv complaining that it can’t preserve the file ownership as /boot is a FAT partition which is to be expected. You may have noticed that /boot/dt-blob.bin doesn’t exist by default, this is because the Pi uses a built in device tree instead. Adding your own inside /boot though overrides the built in one and allows you to configure the function of its pin the way you like. You can find more about the device tree in the documentation.
After that is done you need to enable the camera,
sudo raspi-config
Go to Interfacing Options, select Camera, choose YES, OK and Finish. In case you’re asked if you want to reboot decline. Now, shutdown your Pi and remove the power.
After the power has been removed from the IO board, using 4 female to female jumper wires connect the pins for GPIO28 to CD1_SDA, GPIO29 to CD1_SCL, GPIO30 to CAM1_IO1 and GPIO31 to CAM1_IO0. Finally, attach your camera module to the CAM1 connector using the camera adapter board or a camera cable designed for the Raspberry Pi Zero and apply power.
If everything worked as expected after the Pi boots you should be able to utilize the camera. To try to take a picture after connecting to your Pi via SSH run,
If the command finishes with no errors and a test.jpeg gets created it means that it worked. If you want to have a look at the picture you just took you can connect to your Pi via SFTP and trasfer it to your computer.
sftp pi@<ip-address-of-pi>
sftp> exit
Step 5: Moving From the IO Board to a Custom PCB
Now that you are done with all the basic configuration you can move to designing your own custom board based on the Compute Module. Since this is going to be your first project, I highly encourage you to grab my design and extend it to include any additional hardware you like.
The back of the board has plenty of space for adding your own components and for relatively small projects you likely don’t even have to increase the dimensions of the board. Also, in case this is a standalone project and you don’t need a physical GPIO header on your board, you can easily get rid of it and save some space on the top side of the PCB. The GPIO header is also the only component that is routed through the second inner layer and removing it frees it up completely.
I should point out that I have successfully assembled and tested one of the boards myself, and I have verified that everything including the camera and the HDMI output appears to be working as expected. So, as long as you don’t make any huge changes to the way I’ve routed everything you shouldn’t have any issues.
In case you have to do some big layout changes though, keep in mind that most of the traces that go to the HDMI and camera connectors are routed as 100 Ohm differential pairs. This means that you have to take this into account in case you have to move them around the board. Also, it means that even if you drop the GPIO header from your design, which means that now the internal layers won’t contain any traces, you still need a 4 layer PCB in order to achieve a differential impedance close to 100 Ohm. If you are not going to make use of the HDMI output and the camera though, you should be able to go with a 2 layer board by getting rid of them and cut down the cost of the boards a bit.
Just for reference, the boards were ordered from ALLPCB with a total thickness of 1.6mm and I didn’t ask for impedance control, as it would likely raise the cost quite a bit and I also wanted to see if it would matter. I also selected immersion gold finish to make hand soldering of the connectors easier as it guarantees that all pads are going to be nice and flat.
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    15 Discussions
    wittend
    Question 5 weeks ago on Step 5
    Very helpful! My question: after a couple of months, how has your experience been with this design? Has everything behaved as you expected?
    I see that someone has put this design up on OSHPark (without attribution). Perhaps not the best long term choice for board production, but possibly a way to get it into people's hands to test.
    1 answer
    magkopianwittend
    Answer 5 weeks ago
    No, I haven't noticed any issues with the design so far and neither I have received any reports from others that did. As for the OSHPark listing you're referring to is it this one, https://oshpark.com/shared_projects/VVf0DE0r?
    Honestly, I don't really mind if someone wants manufacture and sell boards based on my design even unchanged. The fact though that the said person decided to upload just the gerber files without including the source KiCAD files, or at least a link to the GitHub repository so other can easily find them is something I don't particularly like. Thanks for letting me know, I'm not familiar with OSHPark but I'll see if I can find a way to contact the owner of the particular listing.
    magkopianWesleyF30
    Reply 3 months ago
    Yeah, I've seen that project before, though the goal of my own project was a bit different. What I was trying to do is design a board that can work as a base for designing your own custom PCB. For this reason the design had to be as simple as possible, while still maintaining the majority of the most popular features found on the other Raspberry Pi boards.
    StereoPi may be nice and compact but in reality it's a quite complex board, so not really what I was after with mine. Changing my design to include a second camera connector isn't actually that hard. The thing is that that's a pretty niche feature that not many people need for their projects, so it didn't make much sense to include it on the board by default and make the design more complex for no good reason.
    By the way, do you know where I can find the design files for the StereoPi? Because I've looked and I couldn't figure out where to get them.
    SgtSiff
    3 months ago
    This is a great write up, just a few questions if I may:
    What drove your decision to power VBAT with 5V, and not 3.3V? Smaller 3.3V regulator required?
    In the CM3 datasheet (7.1 Supply Sequencing) it specifies that supplies must be brought up either sequentially, or at exactly the same time to prevent forward biasing the internal on-chip diodes. Have you experienced any lock ups with your design as it appears the there is no facility for this on the 3.3/1.8V rails? On the official IO board they use a dual regulator and have created an RC delay between the enable pins to ensure they are brought up sequentially.
    magkopianSgtSiff
    Reply 3 months ago
    One of my goals for the board was to have a 40 pin GPIO header that will be pin to pin compatible with the preexisting Raspberry Pi boards. This makes it easier for people (including me) who have already designed a project around let's say a RPi3, and want to transition to a single Compute Module based PCB. Furthermore, it maintains compatibility with preexisting Raspberry Pi HATs which is nice.
    No, I haven't had such issues, but since I'm using two linear regulators both powered from the same 5V power source and having the same input/output capacitors, they should be coming up pretty much at the same time. I haven't made any rise time measurements though to be honest.
    That was actually what I was planning doing at first, but I opted to using a couple of linear regulators to keep things simple and also make sure that my power rails are nice and noise free.
    Wapata
    3 months ago
    Too bad that Compute Module IO board still required, it cost a lot !
    But your project seem really nice and could be cheap for a device without gpio and screen ... And wifi. Well, with just USB and Ethernet. And there is a lot of them ! Router, Expander, Domotic server, 3D printing Octopie, RecalBox game station...
    But the Compute Module IO board put the price to high for all these projects.
    But, congratulations, your instructable is really good and well written, thanks !!
    magkopianWapata
    Reply 3 months ago
    Well, not strictly required, with a few changes on the design you could make the flashing of the eMMC possible without the need for the IO board. However, if you need to do any serious development you need the IO board as it gives you access to a lot more connectors to experiment with and all the GPIO pins of the CM. The IO board itself may be a bit pricey but you only have to buy it once and you can use it for the development of any project.
    Snowsongwolf
    3 months ago
    Is Autodesk monitoring me? I was just saying yesterday how I was interested in the Compute modules but didn't know how hard it would be to design a board for them, and then today this is in my Instructables email. Bravo! I'm definitely trying this out!
    magkopianSnowsongwolf
    Reply 3 months ago
    And not only that, but literally a day after publishing my project the Raspberry Pi Foundation releases the CM3+. I really don't think the timing could be any better.
    Snowsongwolfmagkopian
    Reply 3 months ago
    In fact a news article about that in my feed is what reminded me they exist. I've been trying to figure out dual display setups for Pi and somehow the Compute, which supports 2 display connections, never came up in my searches.
    mglaske
    3 months ago
    Really professional looking build! There's one Pi Board that I'm always on the lookout for, and that's a simple board with PoE ethernet onboard to be used for automation and control applications. With integrated things like 5v level shifters and RS485. If you're looking for another project!
    magkopianmglaske
    Reply 3 months ago
    Thanks, actually I was also thinking about working on a board that will feature Ethernet with PoE for quite some time. Maybe this will be one of my next projects.
    iWinR
    Question 3 months ago on Introduction
    This is pretty cool. I am just getting into the whole electrical side of the nerd world. How much did the project end up costing? And how noob ?
    1 answer
    magkopianiWinR
    Answer 3 months ago
    Honestly, the particular board was probably the most expensive personal project I've worked on so far. The PCBs alone ended up costing me near 80€, but that's to be expected from a medium size 4 layer PCB with gold finish plus the cost of DHL shipping from China. As for the components, I think I ended up paying roughly 100€ and that without including the Compute Module. And that's partly because when I design a new board I tend to buy genuine parts from reputable suppliers like TME and Mouser in order to avoid headaches.
    This project though is probably not a very good example on what to expect regarding the cost of designing a custom PCB. For example, if I only needed a 2 layer board of the same size and without gold finish which is most often the case, I'd probably wouldn't have paid over 25€ for 10 boards. Also, some parts like the SODIMM connector are quite pricey but that's a type of connector you don't use often. I'd say 50€ total for each project that involves a custom PCB is probably a good average.
    As for the complexity of the project, yeah, if you are just starting out you probably want to start with something simpler. Maybe start playing around with an Arduino and from there start learning about PCB design and eventually move your project to a custom board.
