Design a Parametric Pulley (DXF / STL)
About: Hello, I'm Bruce. I'm a student in Belgium. I have a wide variety of interests: electronics, computers, technology, ... In my spare time I spend a lot of time on: projects, exploring the internet, cycling. ...
When I needed to make a pulley for a sumo robot I was building. I didn’t quite find the all in one solution I was searching for, I just needed the DXF of a specific tooth profile for a specific number of teeth.
So I could import this in Fusion 360 to make the custom pulley I want.
I found out about a parametric pulley designer on thingiverse http://www.thingiverse.com/thing:16627 but I couldn’t edit them in Fusion 360 to my needs.
I found a workaround on a site: http://rasterweb.net/raster/2012/07/16/openscad-t... .to export the tooth profile as a dxf.
And I simplified the complete workflow into one scad file. So you could easily generate a custom pulley with a specific: number of teeth, tooth profile and shaft diameter.
Step 1: Opening the File
You can get the latest version of the scad file on my thingiverse http://www.thingiverse.com/thing:2316122/#files
Or you can get the file in this step.
To open the scad file you need to download openscad. Which you can find here for free: http://www.openscad.org/downloads.html
Step 2: Editting the File
Edit the parameters you see in the first three lines.
  • N_tooth = 42; //number of teeth
  • shaft_Dia = 4.2; //shaft diameter in mm
  • profile = 14; //profile options: 1=MXL 2=40DP 3=XL 4=H 5=T2.5 6=T5 7=T10 8=AT5 9=HTD_3mm 10=HTD_5mm 11=HTD_8mm 12=GT2_2mm 13=GT2_3mm 14=GT2_5mm
When you changed the parameters press F6 to render the design.
If you are satisfied with the outcome you can export the file as a DXF.
This DXF can be imported in almost every vector program and cad program: Fusion 360, Autocad, SolidWorks, Inkscape...
In the next step you'll see how I make an example pulley in Fusion 360. But you can stop here if you just need the DXF.
Step 3: Making the Pulley in Fusion 360
This is a step by step photo series of how I made a pulley in fusion 360.
If there is any need for it I'll make a video of this process.
    • Build a Tool Contest
    • Paper Contest
      Paper Contest
    • Pie Contest
      Pie Contest
    nishantkinshu
    10 months ago
    Worked flawlessly. I can't thank you enough.
