Devil May Cry Neon
3,359
12
4
About: 3D printing, Prop Making, Geek and Gamer. Well I could be a Dwarf with a short beard, and the gun may just seem Big :) https://t.co/OjF8uPcrzH
After many Questions even before i
started to make it i decided to make a tutorial on how to make Your own Devil May Cry Nero Neon Sign
what You Need is
Aquarium airline 4mm inner-6mm outer diameter
3.2mm EL-Wire
EL-Wire end caps
EL-Wire connectors
EL-Wire driver Copper Tape
Frame
Soldering Iron and Solder (duh)
Glue Gun and lots of glue
Scissors
Lighter
black insulation tape or black heatshrink tube
Heat gun or hotair soldering station
Hope i didn`t forget about anything :)
Step 1: Printout Measuring and Frame
Lets get to work ;)
First of all You need to figure out how big You want it to be
I printed mine through MS paint over 4x3 sheets of paper "You can use template posted here"
Next step is to measure the length of the wire needed,
To do so You need to get the airline and simply follow Your printout with it (always add couple of cm for that nasty margin of error it`s always better to have more than not enough)
Step 2: Frame and Assembly
When all parts are measured its time to start ordering, order enough Elwire connectors etc
I had my frame custom cut in something called aluminium composite which in short is acrylic glass sandwiched between two layers of aluminium
that's possibly the most expensive part of this, mine cost me nearly 60GBP
Step 3: Put Wire Through the Airline and Let It Rest
Now one of the trickiest bits put Your El-wire through the tubing
Best way to do it? Get a long string tie it on one end of the wire and needle on the other one OR something small enough to fit inside the tube and simply when the needle goes through the tube pull it to get the wire through the tube,
let it rest for an hour or two as it will surely come in a coil it will help it to relax and straighten it
Step 4: Preparation for Glueing
Now take it out of the tube and outline sections of Your frame with the tube
You`ll need to cut the tube into sections to avoid crossing tubed sections and it will allow You to mask the wire where needed
It makes those cross sections much easier
Step 5:
Now simply cut the section You want to glue
Again put the EL-wire through the tube section and start gueing it to the frame with hot glue, glue and repeat
(Sorry don't have a pic of the prcess)
Once section is done, mask bits of the wire if needed with insulation tape or heat shrink tube, make sure to overlap it slightly with the tubing, on those tight sections like M or Y its good to heat the "bend" to make it softer, sure it will deform the airline but it wont be visible when its dark and everything is on
once whole word is done You have two options,
A) Cut the wire into sections one for each word (requires cutting an soldering)
B) Use continuous wire, which will require longer wire and more masking (No need for cutting and soldering)
as for how to solder and handle EL-wire there's a great tutorial
https://elwirecraft.co.uk/el-how-to-and-tips/how-t...
I also ordered all my parts from here they also provide great advice if You need more helpespecially when choosing drivers required
Tip
If You need more info or simply want to commission one Hit me up on My FB page Nerd Armoury or twitter @LyhtemLashlo
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    4 Discussions
    Blocxa_
    5 months ago
    Hi great idea!! Very cool! Perhaps is there anything else I can use instead of the metal frame? It's a bit expensive haha
    LyhtemLashloBlocxa_
    Reply 5 months ago
    well it can be made in any material that is fairly sturdy, and can be painted so wood acrylic polycarbonate etc etc
    It`s true, especially giving how easy to work with it is and its superior to Classic neon durability
