Dewalt Battery Pack Mod
3,988
14
9
About: 18 years old, student in electronic,I'm a french people who don't talk everyday in english! Quadcopter and 3D printing is life
Hi, what's more annoying than run out of battery when you need it?
I received a new cordeless drill for Christmas and I love it. But one thing bothers me, I can't see how much battery I have left. The drill stop to work when the battery is empty. So I decided to add "Battery Voltage Display Indicator Board"
Here the link for the module : https://goo.gl/t26K2V
Supplies:
Step 1: Opening
Battery model : DCB207
Screwdriver bit : T10
You only have 4 screws to unscrew to open the case.
The case open in 2 sections. Be careful with the spring.
Step 2: Drilling
I used a 3/32 bit to drill a hole and feed the wire inside the case.
Step 3: Gluing
I used hot glue to install the module to the battery pack.
After gluing, I trimmed the excess of glue.
Step 4: Soldering
The module is very easy to soldered. Only two wires are needed. They need to be soldered on each side of the battery pack. The easiest way to attach the module is to find the mains leads and soldered directly on it.
After the soldering, push the little button on the module to test the battery.
Step 5: Finishing
One last step... Close the battery pack and use it!
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    9 Discussions
    MTKapp27
    2 months ago
    Neat! Makes you wonder why dewalt didn't include this feature in their design.
    michbushi
    2 months ago
    hmm... didn't exactly make it more robust.
    Yonatan24
    2 months ago
    I made an external voltmeter to test my drill batteries, in case you might interested. Much easier than improvising something to contact the contacts inside:
    gm280
    2 months ago
    Nice idea. I have batteries with this option built into them. The only issue you have to watch for is that fact that you soldered the wires directly to the mains coming out of the battery. And that offers a shorting issue. If you ever short the wires on the outside of the battery, you will see lots of smoke and maybe even a fire. The monitoring module you use has solder connections that could short in some situations depending where it is laid down on. But that can be addressed as well.
    mimil2014gm280
    Reply 2 months ago
    I'm working on something to protect it. Maybe a 3D printed case or something like "conformal coating" to isolate the module.
    RobertW327
    2 months ago
    Nice idea . but would only do this after the batteries warranty has run out . most good brands have a 3 year warranty . this would void it for sure .
    mimil2014RobertW327
    Reply 2 months ago
    Yeah you're right but I cannot wait for the warranty expire.
