Different Methods of Driving 7 Segment LED Displays With Arduino
26,652
50
5
I would just like to show a few different methods of connecting 7 segment LED displays to an Arduino or Atmega 328 IC. They are only simple counter codes either automatically counting via the code or incremented / decremented via a pair of push button switches or a potentiometer . I have used 220 Ω resistors in all these circuits but you would be advised to calculate the correct ones required for the particular 7 segment displays that your are using. This will ensure that you do not damage the IO pins of the 328 IC. The constraints to these maximum currents, courtesy of
http://www.gammon.com.au/forum/?id=11473
are -
- The IO pins have an absolute maximum rating of 40 mA per pin.
- Also the following groups of pins should not have more than 100 mA drawn from them
* Digital pins 0 to 4
* Digital pins 5 to 1
* Analog pins A0 to A5
- In addition to that, the entire processor chip has a maximum rating of 200 mA current consumption.
The 7 segment LED displays are common cathode and the shift register is a 74HC595. I have included a photo of the 7 segment LED from the front showing the relationship between the pin numbers and the corresponding LED segment that the pin controls.
I also have this same content on a hand coded website at
http://www.pedrosdigitalsolutions.com/7SegLEDcircu...
It is not a responsive site so it is best viewed on a laptop or desktop computer. The Arduino code is nicely formatted by some Javascript that a friend wrote and overall it is just much more aesthetically pleasing content IMO. Thanks for dropping by :)
Step 1:
  1. Directly from Arduino / Atmega 328
  2. Via shift register from Arduino / Atmega 328
  3. Directly from Arduino / Atmega 328 with direct port manipulation
  4. Multiplexed via shift register from Arduino / Atmega 328 / Pushbutton counter
  5. Multiplexed via shift register from Arduino / Atmega 328 / Potentiometer counter
1 - Directly from Arduino / Atmega 328
Counts automatically from zero to nine and then repeats
Code
// Thanks to Grumpy Mike http://www.thebox.myzen.co.uk/Tutorial/Arrays.html
// LED Segment allocation within byte = {DP ABCDEFG }
int pins [] = {2, 3, 4, 5, 6, 7, 8, 9 }; // pin 9 allocated to DP but not used (first element of binary array in char tenCode)
int digit[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 };
int counter = 0; // initialise counter as zero
int timer = 1000; // delay timer interval
char tenCode[] = {B01111110, B00110000, B01101101, B01111001, B00110011, B01011011, B01011111, B01110000, B01111111, B01111011 };
void setup()
for(int i = 0; i < 8; i++) // set digital pins as OUTPUTS
pinMode(pins[i], OUTPUT);
void loop()
for(int j = 0; j < 10; j++)
displayEleven(digit[j]);
delay(timer);
void displayEleven(int num)
int mask = 1;
if((mask & tenCode[num]) == 0)
digitalWrite(pins[i], LOW);
else digitalWrite(pins[i], HIGH);
mask = mask << 1;
Step 2:
2 - Via shift register from Arduino / Atmega 328
Code
// LED Segment allocation within byte = {ABCDEFG DP}
int latchPin = 8;    // connect to pin 12 on the shift register
int dataPin  = 11;   // connect to pin 14 on the shift register
int clockPin = 12;   // connect to pin 11 on the shift register
int i = 0;
byte digit[] = {B11111100,B01100000,B11011010,B11110010,B01100110,B10110110,B10111110,
B11100000,B11111110,B11110110};
void setup()
pinMode(dataPin, OUTPUT);       // Configure dataPin  as OUTPUT
pinMode(latchPin, OUTPUT);      // Configure latchPin as OUTPUT
pinMode(clockPin, OUTPUT);      // Configure clockPin as OUTPUT
void loop()
for (i = 0; i < 10; i++)
digitalWrite(latchPin, LOW);                                           // Pull latch LOW to start sending data
shiftOut(dataPin, clockPin, LSBFIRST,digit[i]);         // Send the data
digitalWrite(latchPin, HIGH);                                        // Pull latch HIGH to stop sending data
delay(1000);
Step 3:
3 - Directly from Arduino / Atmega 328 with direct port manipulation
Code
// Because Direct Port Manipulation uses pins 0 and 1, which are the RX and TX
// pins respectively, you have to disconnect these pins when uploading the code
byte i = 0;
byte digit[10] = {B01111110, B00110000, B01101101, B01111001, B00110011, B01011011, B01011111, B01110000, B01111111, B01111011 };
void setup()
DDRD = B11111111; // set PORTD (digital 7~0) to outputs
void count()
for(i = 0; i <10; i++)
PORTD = digit[i];
delay(1000);
PORTD = 0;
void loop()
count();
Step 4:
4 - Multiplexed Via shift register from Arduino / Atmega 328 / Pushbutton counter
Push buttons increment and decrement a counter between zero and eight
Code
//  7-Segment LED counter, multiplexing using 74HC595 8-bit shift register, increment counter zero to eight to zero via push button switches
// Code mangled together from these sources - thanks fellas
//  http://www.sweeting.org/mark/blog/2011/11/27/arduino-74hc595-shift-register-and-a-7-segment-led-display
//  http://thecustomgeek.com/2011/06/29/multiplexing-for-a-7-year-old/
const int latchPin = 5;  // Pin connected to Pin 12 of 74HC595 (Latch)
const int dataPin  = 6;  // Pin connected to Pin 14 of 74HC595 (Data)
const int clockPin = 7;  // Pin connected to Pin 11 of 74HC595 (Clock)
int upPin = 12;      // pushbutton attached to pin 12
int downPin = 13;      // pushbutton attached to pin 12
int currUpState = 1;   // initialise currUpState as HIGH
int currDownState = 1;   // initialise currDownState as HIGH
int prevUpState = 0;
int prevDownState = 0;
const byte numbers[10] =  // Describe each digit in terms of display segments  0, 1, 2, 3, 4, 5, 6, 7, 8, 9
B11111100,
B01100000,
B11011010,
B11110010,
B01100110,
B10110110,
B10111110,
B11100000,
B11111110,
B11100110,
void setup()
pinMode(latchPin, OUTPUT);   // set SR pins to output
pinMode(upPin, INPUT);   // sets pin 12 as pushbutton INPUT
pinMode(downPin, INPUT);   // sets pin 13 as pushbutton INPUT
void loop()
currUpState = digitalRead(upPin);
if (prevUpState != currUpState)             // has the state changed from
{                                           // HIGH to LOW or vice versa
prevUpState = currUpState;
if (currUpState == HIGH)                  // If the button was pressed
counter++;          // increment the counter by one
//delay(1);
if(counter > 8)
counter-=1;
show(numbers[counter]); // display the current digit
currDownState = digitalRead(downPin);
if (prevDownState != currDownState)         // has the state changed from
prevDownState = currDownState;
if (currDownState == HIGH)                // If the button was pressed
counter-=1;                              // decrement the counter by one
//delay(1);
if(counter < 0)
counter++;
void show( byte number)
// Use a loop and a bitwise AND to move over each bit that makes up
// the seven segment display (from left to right, A => G), and check
// to see if it should be on or not
for(int j = 0; j <= 7; j++)
byte toWrite = number & (B10000000 >> j);
if(!toWrite) {
continue;
}  // If all bits are 0 then no point writing it to the shift register,so break out and move on to next segment.
shiftIt(toWrite); // Otherwise shift it into the register
void shiftIt (byte data)
digitalWrite(latchPin, LOW); // Set latchPin LOW while clocking these 8 bits in to the register
for (int k=0; k <= 7; k++)
digitalWrite(clockPin, LOW); // clockPin LOW prior to sending a bit
if ( data & (1 << k) )
digitalWrite(dataPin, HIGH); // turn “On”
else
digitalWrite(dataPin, LOW); // turn “Off”
digitalWrite(clockPin, HIGH); // and clock the bit in
digitalWrite(clockPin, LOW);  //stop shifting out data
digitalWrite(latchPin, HIGH); //set latchPin to high to lock and send data
Step 5:
5 - Multiplexed via shift register from Arduino / Atmega 328 / Potentiometer counter
    Potentiometer used to increment and decrement a counter between zero and eight
Code
//  7-Segment LED counter, multiplexing using 74HC595 8-bit shift register, increment counter zero to eight to zero via potentiometer
int potReading =0;
B11111100,
B01100000,
B11011010,
B11110010,
B01100110,
B10110110,
B10111110,
B11100000,
B11111110,
B11100110,
void setup()
void loop()
potReading = analogRead (A0);
potReading = map(potReading, 0, 1023, 0, 8);
if(potReading > 8)
potReading --;
show(numbers[potReading]);
if(potReading < 0)
potReading ++;
if(!toWrite) {
continue;
// Note that in our case, we need to set pinState to 0 (LOW) for
// “On” as the 74HC595 is sinking current when using a common
// anode display. If you want to use a common cathode display then
// switch this around.
else
    • Weaving Challenge
      Weaving Challenge
    • Tape Contest
      Tape Contest
    • Epilog X Contest
      Epilog X Contest
    5 Discussions
    BadegharS
    5 months ago
    I need to move 4 digit seven segment didplay left and right of each seven segment display and increment each segment using up down counter. How it should be done
    WeirdAlWalker
    1 year ago
    Very well written instructable!
    Q: I need to run 2 - 7 segment displays... Does one of these driver chips (74HC595?) let me do that? I need to show a double-digit number on a project I'm muddling through....
    pedro147WeirdAlWalker
    Reply 1 year ago
    Thanks. It is appently possible. See this guy did a 4 digit 7 seg with one SR
    https://forum.arduino.cc/index.php?topic=76883.0
    Here is another guy using two SR, one for each 7Seg. I am out of touch with Arduino as I am now building quadcopters :) which all began from Arduino actually. My website is not responsive as it is an amateur hand coded site but it looks OK on a desktop or laptop. Looks crappy on a mobile device. I have done a much better version on this Instructable there
    http://www.pedrosdigitalsolutions.com/7SegLEDcircuits.php
    . Good luck Pedro
