Digital Message in a Bottle
6,258
76
25
About: My name is Troy. I'm a Mechatronics graduate studying Mechanical Engineering. I like to make things and spend time outdoors (especially SCUBA diving). I am a Community Manager for Instructables.
Communication is a fundamental human characteristic. We communicate face-to-face, through written word, pictures, over the telephone, and hand gestures. Even with all these ways of communicating the one method of communication that has always mystified me is the message in a bottle. There are plenty of amazing stories through history of people sending and receiving written messages through a bottle found on the shore or caught in fishing nets.
I wanted my own message in a bottle but with a twist. Being inspired by my fiancée, I set out to design my own digital message in bottle. It features a usb flash drive and can be made to either be found floating in the water, or sunk in the depths of the ocean for a scuba diver like myself to be found.
Supplies:
Step 1: Materials
Materials:
  • Bottle
  • Flash Drive - I used the Super Talent Pico-C for it's ability to be water resistant, small, and inexpensive
  • Wire
  • Eyelets
  • Cork
  • Instamorph
  • Silicone
  • Sand
Step 2: Remove Soda and Label
The easiest way to remove the label is to soak the bottle in hot water then peal it off. Use Goo Gone to remove the remaining adhesive.
Step 3: Fill With Sand
If you are planning on sinking your message in a bottle, fill it mostly with sand. One pound is enough to make it negatively buoyant. If you want to make it float, skip this step.
Step 4: Prep USB Drive
Wanting to present the flash drive in an easy to view manner, I decided to hang it vertically from the cork.
  1. Take a length of wire and loop it through the eyelet and flash drive
  2. Place the eyelet in a drill chuck
  3. Slowly twist the wire
  4. Cut off the tail end of wires
  5. Screw the eyelet into the bottom of the cork
  6. Copy whatever message you'd like onto your message in a bottle. Here is what mine had:
    • Text Document:
      Good Day Diver! Congratulations! You have found one of three Digital Messages in a bottle!
      This has been designed and placed around Roatan Honduras by Troy Hawkins during the week of July 25 -31, 2015.
      A little about me. I love diving! I live in Utah USA and I have been a diver since 2008. I was originally certified in Okinawa Japan. I received my Divemaster certification at CoCo View Resort here on Roatan in February of 2014.
      I graduated in 2013 in Mechatronics Technology and hope to be graduated in Mechanical Engineering by 2017.
      I want to hear from you! I want to hear a little bit about you. If you could share who you are and what you love to do that would be great!
      The full write up on how this bottle was made can be found at https://www.instructables.com/id/Digital-Message-i...
      My profile can be found here: https://www.instructables.com/member/tomatoskins/
      Please take a look and I can't wait to hear from you!
  7. Wrap with plastic to protect the flash drive from sand
Step 5: Insert Cork
Insert the cork into the bottle, using an f-clamp press the cork into place. Use proper safety measures as the bottle has a very small potential of breaking.
Step 6: Instamorph Cap
As an added measure to keep the bottle sealed and the cork in place, I added an Instamorph cap.
  1. Heat Instamorph
  2. Form cap
  3. Using scissors, square the bottom of the cap
  4. Once the Instamorph has cooled slightly, coat the inside with silicone
  5. For an added measure, secure Instamorph cap with a zip-tie
Step 7: Attach Note
Attach an eye catching note asking passerbys to take the bottle home. I included my email on the note for an added measure asking the finder to contact me (has been edited from pictures).
Step 8: Parts for Pressure Test Rig
Back in March, I asked the community for some help to figure out a way to read the internal pressure of my bottle of Dr. Pepper. This is what I came up with from their help.
Parts:
  • Saddle Valve
  • 1/4" all thread
  • Tubing
  • Hose clamps
  • Low pressure gauge
  • Bottle of soda to test
Step 9: Assemble Pressure Test Rig
Cut the gasket flat where it will contact the top of the bottle. Shape the all thread to fit around the bottle. Assemble the top half of the saddle valve. Bolt the saddle valve and plate to the all thread. Attach the pressure gauge.
Step 10: Test Soda Pressure
I was really surprised at the consistent pressure of the 3 bottles that I tested. They were all within one PSI from each other. Since the average internal pressure of the soda was 54 PSI, these bottles (not necessarily the Instamorph cap) should be able to withstand the pressure all the way down to 121 feet underwater at sea level.
The deepest I ended up taking them was 70 feet. There's not usually a lot of coral much deeper than that, and most divers are only certified for 60 feet anyway.
Step 11: Underwater Test
Not being sure of how secure my cap assembly was, I decided to test my bottle closer to home in case I needed to make any changes before I left to Honduras. I would hate to be 2200 miles from home and tools realizing that my project wasn't going to work.
Step 12: Disassembley
I wanted to inspect the bottle first hand to make sure that there was indeed no water leaking in. To disassemble remove the cap and cork. Look at how dry that cork is!
Step 13: Find Some Water
Find somewhere you'd like to leave your message in a bottle. I personally went to Roatan, Honduras to leave my messages
Step 14: Go for a Dive!
Find a nice sandy area to leave your bottles. Remember to bury them deep enough in the ocean as to protect them from surge and deep enough in the sand they don't move.
I placed three bottles while in Honduras:
Step 15: Enjoy Your Time on the Reef
After you place you bottles, enjoy the rest of your dive! It's great to be underwater!
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
  • Arduino Contest 2019
25 Discussions
PlaidPete
2 years ago
Have you been contacted yet?
Flabbydog14
3 years ago
This one is by far my favorite!!! I've made it and it's REALLY cool! Thanks for the ideas!
ossum
3 years ago
This is great, I hope you update us if anyone contacts you, I've always liked the idea of sending out messages for strangers to find. As a kid i used to write notes on paper planes and throw them off our balcony.
snarklow
3 years ago
This is awesome!!!! Such a great idea
Big Projects
3 years ago
Has anyone contacted you yet?
RichL1
3 years ago on Introduction
Thats so cool ! Interesting concept. Now you have to call Sting, and tell him to change the name of the song. I like the underwater idea, who knows what people will find 100 years from now...
Don't be haters its not going to break or litter unless because its going to stay in the same place until a diver spots it because its full of sand which ways it down! Anyway I love the idea.
bakichmg
3 years ago
That looks cool. Going to try that. What kind of info did you put on the drive?
tomatoskinsbakichmg
Reply 3 years ago on Introduction
I can't believe that I forgot that! I updated step 4 to include that info! But I should have added my mixtape! :)
