Dino Lamp
5,046
69
16
About: Hi! You can call me Ardee. I'm a specialist (self claim) in paper and cardboard related DIY projects. You can see more of my works at ardeepapercrafthouse.blogspot.com.
Hi All! I have an interesting project to share with you today, especially for dinosaur lover such as myself. It’s my version of dinosaur lamp from diydinosaurlamp.com, a do-it-yourself dinosaur light puzzle kit made from PP plastic. They have various dino lamps – triceratops, diplodocus, pterodactyl and of course, the T-rex. You can buy the kit at dinosaurlifestyle.com (no, this is not an ad. And no, I didn’t get any commission).
I have made a simpler version of the kit using cheap materials aka poor guy method and I choose triceratops because it’s my favourite dino.
P.S:- Boston09 did post an –ible for the Dino-Lamp few years back. You might want to check it out as well.
Step 1: Gather Your Material and Tools
  • Craft Knife/X-acto Knife and Scissor.
  • Printer and Paper .
  • Transparent Binding Sheet – this is use for the smaller parts of the kit because it’s easier to cut, fold and shape.
  • Transparent Card Holder – I use this card holder because it has thicker plastic – 2/3 times thicker than the binding sheet. This will be used for the bigger parts such as the body and legs.
  • Permanent Marker Pen/Sharpie – preferably with fine tip.
  • Acrylic Spray Paint – White Color.
  • Lamp Cord with On/Off Switch.
  • Bulb Holder.
  • Screwdriver.
  • LED Bulb.
Step 2: Print & Cut Out the Template
The template consists of 6 pages, the first page is for the thinner plastic (binding sheet) and the rest is for the thicker one (card holder). First print all pages on a normal A4 paper. Place the plastic sheet on top of the printed template and start tracing out the outline using marker pen.
Use the craft knife and scissor to carefully cut out the template. The card holder I use is quite thick and rather difficult to cut – so be careful with that. The template has 5 parts consists of total 15 pieces. The parts are label as Head (H1 – H6): 6 pieces, Body (B1 – B4): 4 pieces, Legs (L1 – L4): 4 pieces, and Tail (T1): 1 piece. Make sure you only cut and remove the continuous/straight lines. The dashed and dotted lines are for folding, which bring us to the next step.
Step 3: Fold the Parts
Fold the cut-out pieces according to its designated line type as per template. Dashed lines are for mountain-fold; fold it downward to make a ‘mountain’. Dotted lines are for valley-fold; fold it upward to create a ‘valley’.
Step 4: Paint the Parts
Apply white spray paint over the folded pieces. Do it on both sides of the pieces. The idea is to make the paint diffuse the otherwise bright LED lights. I suggest applying 1 or 2 layers of spray paint on each pieces.
Step 5: Start Assembling the Parts
The assembling of the kit is quite straightforward you can refer to the pictures I post in the next few steps. A friendly reminder though, I drew the template based on the original kit but I made few adjustment along the way. It’s a trial and error process and some of the parts might not be fitted perfectly. In other word, it’s not a perfect template yet and you may need to adjust it accordingly during the assembly.
Step 6: Assembling the Parts: Head
Fold and joint H1, H2, H3, H4, H5 and H6 as shown in the picture.
Step 7: Assembling the Parts: Body
Fold and joint B1, B2, B3, and B4 as shown in the picture.
Step 8: Assembling the Parts: Legs
Fold and joint L1, L2, L3, and L4 as shown in the picture.
Step 9: Assembling the Parts: Tail
Fold and joint T1 as shown in the picture.
Step 10: Combine All Parts
Start by attaching the Body to the Legs. Then proceed with the Tail with the Head attach last. The Head part is detachable to access the inside compartment.
Step 11: Final Coating
Apply the finishing coating to the completed assemble body. I need to remind though, the more layers of paint you applied, the less transparent your lamp would be. With thick layers of paint, instead of diffusing the light it will block the light altogether.
Step 12: Add the Lighting
Open the Head compartment to insert the light fixture. Get the lamp cord and push it in through the tail. Terminate the cable pair to the bulb holder’s terminal. Install the LED light bulb and place the holder to its location. You may further secure the wire to the Body using cable tie.
I chose to use LED light bulb because it emits less heat than the usual fluorescent light bulb. I’ve turned on the lamp for few days and there’s no sign of any ‘melting’ of its plastic body.
Step 13: Play With Your Cute Dino
Now I have my glowing Triceratops accompanying me every night – and you should build one too =)
Make it Glow Contest 2016
Runner Up in the
    • Classroom Science Contest
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    16 Discussions
    jinxislonely
    2 years ago
    This is adorable! I'm going to make this for my little sister's birthday, she adores dinosaurs, thank you for this!
    apapercraftjinxislonely
    Reply 2 years ago
    Your welcome! Such coincidence that I made this project for a gift to my sister too. Lol. Hope she like it! =)
    Redken17
    2 years ago
    This is perfect for my daughters school project.
    WeAreMakeshop
    2 years ago
    Love this! We have various sheets of acryllic and PPE lying around waiting to be made into something like this.
    apapercraftseisei10
    Reply 2 years ago
    Please do. And share the picture here once it's done. =)
    kniegmann
    2 years ago
    Did you make the template? Any tips on which software you used to create the patterns?
    apapercraftkniegmann
    Reply 2 years ago
    I got the template from their website. Its in jpeg and the details are bad. I simply redraw it with CAD program, made some changes and omitted some parts.
    Chanit0
    2 years ago
    Completely agree. Looks fantastic! Thanks for sharing. =)
