Dinosaur Trophy
10,264
299
18
About: I am a senior laboratory technician in a analytical facility by day and by night I make and fix things. I prefer to work with wood but will give anything a go. I also enjoy gardening and an kept busy by my ...
This instructable will take you through the steps of converting a cheap wooden dinosaur puzzle into a large dinosaur wall trophy.
Step 1: Bits & Bobs - Tools & Stuff
Material
Puzzle
Wood Glue
Spray mount (or other way of temporarily attaching paper templates to wood)
Card for shield template
Picture Hanger
Wood for Shield
6mm MDF or Ply for puzzle pieces
Tools
Computer with scanner and printer
Scroll Saw (you may be able to do it on a bandsaw with a narrow blade)
Drill with 6.5mm bit
Chisel
Sand paper and files
Router and bit
Step 2: Making Templates
The original puzzle was purchased form ebay for about £3.
I then scanned the puzzle piece boards and resized so that the slots for the pieces to join together matched the size of the wood I was using (in this case 6mm).
I then printed them out, I had to spread the image over 4 pages and then tape it together. (you can use paint to do this)
To make the shield template, fold a piece of thin a card in half and draw a half shield shape then cut it out. It is roughly 8” square.
Step 3: Prep and Cutting
Using the original puzzle work out which pieces are needed for the head and neck assembly. Cut these out and stick to your wood (I use spray mount as it peels off again easily)
Drill a hole at the top of each slot, I used a 6.5mm bit so my slots where a slightly lose fit. (this is fine as they are being glued)
Using a scroll saw cut all the pieces out and then sand any rough edges. Ensure all pieces will slot together.
Using the shield template cut out the shield from your wood of choice and route the edge (I used some rubber wood offcuts)
Mark a slot for the neck to fit into then chain drill and chisel it out.
Fix on your choice of picture hanger.
Step 4: Finishing Up
Dry fit all the pieces together and when happy glue the pieces together with PVA wood glue.
Hang on the wall and enjoy.
Note:
I have left mine unfinished as I fully expect the recipients to paint them.
Step 5: Extras
I made a Velociratoptor and used that as the basis of this instructable.
I also made a Styracosaurus and have included the templates for those here.
2 People Made This Project!
  • Tape Contest
    Tape Contest
  • Gardening Contest
    Gardening Contest
  • Arduino Contest 2019
18 Discussions
bretinc
4 years ago on Introduction
awesome work and great instruct able, i will be making this one when my other projects die down, cheers! \m/
You know, I think your technique of scaling up those wooden puzzle toys would be an insanely awesome way to make a killer lawn ornament.
neo71665gravityisweak
Reply 4 years ago on Introduction
Thats actually on my list of things to build this summer. I already have a bunch of 3/4 plywood and the patterns scaled up. I've always wanted to build a 6 foot t-rex since I was a kid and now my son is old enough to help.........he he he he
Gonna use the ply as a base and fiberglass each part to stand up to the weather.
pudtinyneo71665
Reply 4 years ago
sound like a great project, I await photos
pudtinygravityisweak
Reply 4 years ago
check out this guy's work: uctables.com/id/T-Rex-Dinosaur-Puzzle-with-different-sizes-and-pos
pudtinypudtiny
Reply 4 years ago
that did paste properly it should be: www.instructables.com/id/T-Rex-Dinosaur-Puzzle-with-different-sizes-and-pos
jmwells
4 years ago
Great idea. For the lower tech types instead of a scanner computer you can use a pantograph. Add a few teeth and its a dragon trophy for those with medieval decor.
pudtinyjmwells
Reply 4 years ago
nice idea for scaling up. A dragon is on my list of things to do.
pudtinyhegure_ryu
Reply 4 years ago
to be honest I think that one looks better.
tomatoskins
4 years ago
This turned out great! I know a few little cousins of mine that would love a wall mounted dinosaur!
