Display Temperature on LCD
34,775
49
6
I will bring two projects together in this instructable.
I will demonstrate how to measure the temperature using a LM35 temperature sensor and an Arduino then display the temperature on a serial LCD 16X2 in Celsius and Fahrenheit.
You can find the initial projects here:
https://www.instructables.com/id/How-to-connect-a-s...
and
https://www.instructables.com/id/How-to-display-tem...
Step 1: The Electronics
For this project you will need:
  • 1 Arduino UNO
  • 1 LM35 temperature sensor
  • 1 Serial LCD 16X2
  • 1 Breadboard
  • Some jumper wires.
Step 2: Connect the LCD, LM35 and the Arduino UNO
The LCD I will be using is a serial LCD with a I2C.
Connect the LCD
VCC connects on the +ve red rail on the breadboard
GND connects to the -ve blue rail on the breadboard
The SDA connects to the SDA on the Arduino
The SCL connects to the SCL on the Arduino
For more detail on how to connect it visit my earlier instructable:
Connect the LM35
The VCC connects on the +ve red rail on the breadboard
The GND connects to the -ve blue rail on the breadboard
The Middle pin connects on the PIN A0 (analog 0) on the Arduino
* remember to connect the VCC and GND correctly otherwise the LM35 will heat up to 300 degrees and more.
I have detailed instructions on LM35 and how to connect it on
Now we are ready for the sketch ............
Step 3: The Sketch
The sketch is not as simple as copy and paste both sketches together, I had to modify it to accommodate both devices and to tell the Arduino to get the data from the sensor and display it on the LCD. But the Variables and libraries remain the same.
There is a zipped copy of the sketch in this instructable you can adjust it as you see fit.
I started by defining the libraries we need for the LCD. For more details on how to load the libraries in your Arduino library folder follow the instructions in this instructable:
//load libraries
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h>
The I defined the variables needed by the LCD and the LM35
I added the variable tempf to help display the temperature in Fahrenheit
//Define variables for the LCD
#define I2C_ADDR 0x27 //Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
//define variables for the LM35 temperature sensor
float temp; //Define the temp float variable
float tempf; //Define the Fahrenheit float variable
int sensor = 0; // sensor middle pin on analog pin 0
Then I initialized the LCD using this line:
//Initialize the LCD
LiquidCrystal_I2C lcd(I2C_ADDR, En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
In the Void setup, I tell the Arduinio that I am using a 16X2 LCD, turn on the backlights and print some lines that will not change.
void setup() {
lcd.begin (16,2); //Define the LCD as 16 column by 2 rows
//Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.setCursor(0,0); //goto first column (column 0) and first line (Line 0)
lcd.print("Temp C = "); //Print at cursor Location
lcd.setCursor(0,1); //goto first column (column 0) and second line (line 1)
lcd.print("Temp F = "); //Print at cursor location
In the Void loop I will read the temperature from the sensor, change it to Celsius and display it on the first row, then change it again to Fahrenheit and display it on the second row. The repeat the process every 5 seconds
void loop(){
temp = analogRead(sensor); //assigning the analog output to temp
temp = temp * 0.48828125; //converting volts to degrees celsius ----- 0.48828125 = [(5V*1000)/1024]10 tempf = (temp * 1.8)+32; //Convering from celsius to fahreneit
lcd.setCursor(8,0); //move the cursor to position 8 on row 1
lcd.print(temp); //print the temperature in Celsius
lcd.setCursor(8,1); //move the cursor to position 8 on row 2
lcd.print(tempf); //print the temperature in Fahrenheit
delay(5000); //wait 5 seconds
I hope you like it, if you have any questions don't hesitate to ask.
Enjoy
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    6 Discussions
    Elementk2
    Question 1 year ago
    would the VSS pin work like the VCC pin. I dont know what kind of LCD I am using but there is only VSS not VCC
    theflash9000
    2 years ago
    i can make this but can u plz elaborate on the coding part
    thank u
    SimoneR2
    3 years ago on Introduction
    Hi, to reduce the temperature's reading error you could also change che ADC reference and set it to INTERNAL (1,1V max) if you don't need to measure high temperature (max 110°C) . In the setup you should just add: analogReference(INTERNAL); and then change in loop when you convert volt to temperature: temp = temp*0.107421875; //([(1,1V*1000)/1024]/10).
    //load libraries
    #include <Wire.h>
    #include <LCD.h>
    #define En_pin 2
    #define Rw_pin 1
    #define Rs_pin 0
    #define D4_pin 4
    #define D5_pin 5
    #define D6_pin 6
    #define D7_pin 7
    //Initialise the LCD
    void setup()
    //change ADC reference voltage to 1,1V to get more precision
    //max temperature to be read is 110°C
    lcd.begin (16,2);
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    void loop()
    temp = temp * 0.107421875; //converting volts to degrees celsius ----- 0.107421875 = [(1,1V*1000)/1024]/10
    tempf = (temp * 1.8)+32; //Convering from celsius to Fahrenheit
    //wait 5 seconds
    delay(5000);
    bye, I hope it can be useful =)
    p.s. small note on volt's measure unit: volt is derived from a proper noun (Alessandro Volta), so this unit doesn't need s for plural (Ampere, Watt, Ohm, Hertz too!)
