Doctor Who Tardis Costume
65,162
254
29
The Calgary Comic Expo was coming and my son wanted to go in costume this year. I only had two weeks to work on this prior to the Expo so I had to come up with something quick. When I asked him if he wanted to go as the Tardis from Dr. Who I got a huge YES!!!
This costume only took me 2 days to make and another day to paint.
I started this costume by first figuring out some proportions. This involved me looking for every picture of a Tardis from the show I could find on the internet. I came up some percentages on the width of the Tardis, and from there made up my own numbers to build it to the size I wanted. The main body of the Tardis should be about 75% or your planned width with each corner panel being about 12.5% of the width. See my diagram for details.
Supplies:
Step 1: Materials Needed / Getting Started
This costume is about 98% cardboard. I got myself 8 large flat screen TV boxes by going to my local TV / electronics dealer (In my case it was 'Future Shop') and ask for empty boxes. I lucked out and they had just thrown out a bunch of boxes and was able to get all that I needed in one trip. These stores normally throw out or recycle their boxes early so you'll need to catch them early or make arrangements for them to save them for you. You need large uncut, not bent or crushed cardboard. The larger you want to build the costume the larger the boxes will need to be.
You will also need:
-Carpenters glue (white glue doesn’t dry fast enough or is strong enough)
-Four 1x1 strips of wood
-Four 1x1/2 strips of wood
I made a box with the 1/2 inch strips and then used the 1x1's to create the 'legs'. I made this simple frame so that I would have something to attach all the cardboard to.
Sorry about switching units of measure, but to calculate my sizes and proportions quickly I switched to metric.
I based the size of the Tardis on my son. In my case the top square was 64 cm by 64 cm and I made it 103.5 cm tall.
Step 2: Building the Sides
I took one sheet of cardboard and cut it to the size of the frame. Make sure when you cut each panel that you only cover the top 1x1/2 lumber square by a 1/4 inch or less. you will need to attach more cardboard above these panels later on.
Once I had my sheet I had to work out the dimensions of the door details (panels and windows). I measured out the height (103.5cm) and width (64cm) and then worked out dimensions to make the eight panels all the same size. The windows count as panels as their dimensions are the same as a panel.
See the image for the dimensions of my Tardis.
With the amount of cutting that will be needed I recommend getting yourself a pack of new blades. Changing the blades often makes the cutting go smoother and your hands will thank you by the time you are done. I used a metal straight edge and a cutting mat so as to save my floor.
I used the first panel I cut as a template to cut three more sides. In the diagram picture I only have the dimensions for one side of the sheet of cardboard, but both half’s are the same dimensions. Do not cut the sheet you've selected to be the entrance door in half yet. You need to keep this as a solid sheet for the time being.
Step 3: Attaching the Sides, Filling in the Panels
Again I used carpenters glue to glue everything together. To hold it in place while it dried I used an air stapler. A hand stapler would probably do the same trick but you'll have to be careful as they tend to shake as you drive the staple in.
At this point you only want to attach three sides of the Tardis; the fourth side will be for the doors which will be dealt with in another step.
To create depth I glued another piece of cardboard to the inside of each panel. Carpenters glue doesn't take long to start to set so I only needed to weigh each board down for a short while. I used anything I could find (or would stay long enough) as weight.
Step 4: The Base and Add Extra Height
Next I created a base for the Tardis. I put what I had made so far on a large un-cut sheet of cardboard and traced on the inside of the walls of the Tardis. The base square I created was 7.5 cm thick. To me this looked the correct proportion to the rest of the Tardis. To attach it I put carpenters glue on the bottom of the wooden legs and set it on the base. Once dry, turn the Tardis upside down and using a strong tape (Duct, Gaff, Gorilla or something similar that doesn’t fall off after a while), tape from the inside of the walls to the bottom of the base. The Tardis will get abused from just walking around and the extra hold will be needed to keep the base on.
At this point I realized I needed a little extra height for my Tardis. You could incorporate this extra height in your original panels, but the door section must not have this extra height. All these seams will be hidden later by more cardboard.
I cut these panels 8 cm high and the width of each side. Remember that you'll end up with two sets of widths for these panels. One set will be slightly wider as they will overlap the other two in the corners.
Step 5: Fixing an Oopsy...
Once I put all the top boards on I realized I screwed up and they were not all level with each other. That’s when I realized my frame wasn't 100% square. Crap!
I fixed this issue by clamping my meter stick and setting a cut line between the adjoining cardboard. This is where a really sharp knife comes in handy. I sliced along the ruler to make sure It was a perfect line.
Step 6: Corner Trim
I started by cutting eight corner strips. I cut them all 8 cm wide and the height of the Tardis. When you go to attach them you will need to cut each strip so that they end 1 cm below the top of the Tardis. When attaching these strips I did overlap them on the corners so as to make the corner square.
Attach the corner strips on three sides of the Tardis.
Next take the front door panel and place it on the Tardis. Do not attach it. Hold a corner strip on the door panel and mark the overhang on the door panel.
Step 7: The Doors
Once you have marked the Corner overhang, draw a cut line 1.5cm away from the overhang line towards the outer edge of the panel. Do this on both sides of the sheet. The reason for this is that the corner trim on the outside will hide the hinges for the doors.
Now cut the door sheet in half.
Next cut the outside strip off each door. I went to my local hardware store and bought a cheap set of door hinges for a couple dollars a set. You need to re-attach the outside strips with the hinges. I used a hot glue gun to attach the hinges with. Make sure you line up the two pieces to be re-attached perfectly or once you attach the doors to the Tardis they won’t open and close properly.
Once the hinges were dry I covered the panel’s 18 cm by 21 cm openings. If you cover them before this step it will just make it difficult to cut the doors in half and cut the sides.
Step 8: Attach the Doors and the Rest of the Door Trim
Now the fun part, holding the doors in the correct spot while you attach them. If you have someone to help you it will make it go smoother.
Run some glue down one of the wooden legs and place one door panel on. I stapled it in the top corner only to start so that I could adjust the doors so they were perfectly level with the base. If you don't do this and your doors are off at an angle a little, they will always fall open or closed depending on which way the angle is. I didn't want my doors falling open.
Once you have them level, staple the rest of the side of the door on. When you go to attach the other door, leave a slight crack between the two openings. This way the doors won't bind when you close them.
Step 9: Starting the Roof
Lay a large sheet of cardboard on top of the Tardis and trace the outside edge of the walls. Draw another line 5 cm in from this line and cut out both lines. This will give you a square ring, just like the base.
I wanted to make sure that the roof glued evenly all around when stuck it on. So I used canned goods as they had enough weight and were small enough to balance on the top of the Tardis.
Step 10: Continuing the Roof
Once the square ring was glued down it was time to continue upwards. Cut strips of cardboard 5 cm thick and the length of the roof square or a bit longer. I found it was easier to just cut them longer and then cut them back after they dried as shown in my photos. I just glued them on and held them in place with clamps. The clamps were tightened only enough to hold the cardboard in place.
Step 11: Finishing the Roof
Take another sheet of cardboard and lay it on the roof. Trace around the outside again but do not cut this line. You will need to draw a second line 2 cm farther out. This is the line you will cut. The reason you need to add the extra 2 cm width is when you push the cardboard into a pyramid shape, it will make the size of the base smaller and will fit the roof perfectly. If you are making a Tardis of a different size, you will have to experiment with how much overhang you need to start out with.
Draw an X though the sheet. The Tardis roof does not come to a full peak; it has a flat spot on top. At the center of the roof draw a 10 cm by 10 cm square. This box will be your fold lines.
In the picture with the ruler, you can see I made a mark at the corners 1 cm on each side of the line drawn to the corner. From these new marks you need to draw a line connecting the edge of the cardboard to the corner of the 10 x 10 box that was drawn in the middle. As you can see in the pictures I cut up these lines from the outside corner to the center box. Now fold all four flaps of the roof down until they touch. I used Gaff tape, but Duct or Gorilla tape as well (you just want a strong tape that won’t let go), to hold the flaps of the roof together for the time being.
Place the roof on the Tardis. To hold it in place and stop the glue from pouring through onto my floor I taped around on the inside of the roof where it connects to the Tardis. I then poured glue into all the seams and used my fingers to smooth it all out. you don't want lumpy bits here, they will show too easily. I actually did two rounds of glue as I found the cardboard liked to suck it up into the spaces between the cardboard paper. I let the first round set so first so then when I did the second round, the glue stayed at the edges where I wanted it.
The last step of the roof was to cut out another 10 cm by 10 cm piece of cardboard and glue it to the roof. The Tardis light sits up slightly so i found one piece was all i needed to make it look right.
Step 12: Making the 'Police Box' Panels
Next the ‘Police box’ boards need to be made. First draw a line 2.5 cm from the top of the flat part of the Tardis roof. Next, eight strips of cardboard 8 cm wide by 53 cm long need to be cut. You only actually need four to be 53 cm long, the other four will be shorter, but it’s just as easy to cut them all the same first. Cut a strip so that it will fit between two of the corner strips. You want it to hang down over a door panel. It’s not necessary to glue it to a panel, but will not hurt it if you do. The exception is the actual doors. You want it to cover the doors but not attach to them.
Next take a full 53 cm strip and center it on the Tardis. Glue it at the same level from the top as the previous piece. This will be the board you will place the ‘Police Box’ sign. Do this on all four sides of the Tardis.
Step 13: Finishing Details
On the front doors of the Tardis, I added a strip of cardboard 2 cm wide and the height of the doors to act as a door jamb. I wanted to do all four sides, but was getting tired and ended up leaving them off.
For the light on the roof I used a Mason jar. I hot glue gunned the lid to the roof and then just screwed the jar on. I ended up using a mag light with the top off as the light, so before a glued the lid down a punched a hole in the lid and the cardboard to fit the light through.
Step 14: Painting
Before starting I used painters tape and wrapped the glass part of the mason jar except the top cm or so. This would end up giving the blue cap above the light.
I used CIL Rich Navy and applied it with an air sprayer. I did this all outside on my driveway to avoid the fumes. If you spray it make sure its not too windy or nothing is close that you don't want any over spray to hit. In the bright sun it looks very blue, but under normal lighting it looks like the perfect Tardis blue.
Once the outside was done I painted the inside gloss black to hide all the TV advertising and it served to give some depth.
To paint the windows I taped around the windows leaving a 1/2 cm around the edge as a border. This will also line the windows up with the rest of the door panels when done. Make sure you put paper on the inside too or the white overspray will show on all the black inside the Tardis.
Step 15: Adding the Signage
With the "Police Box" panel being 53 cm by 8 cm, I had the signs printed at 52 cm by 7 cm. I took my "Police Box" and "Pull to Open" signs to a printer as I didn’t want any seams that would be made if I printed them myself and glued them together. I spray coated the 'Police box' signs with a gloss coat to make them shine.
I lucked out and they were able to print the "Pull to Open" sign as a sticker which made my life a lot easier when it came to attaching it. I printed that sign at 20cm by 17cm.
The St' John's emblem I just printed myself. My wife is into scrap booking and has a Xyron sticker making machine so I ran it through that. You’ll want to print the emblem at 6 cm across.
I ended up screwing up one of my Police Box sign and the perfectionist in me made me re-do the one. I printed it off in three sheets (I've posted them here in case you wanted to go that route) and glued them together. Spraying the gloss coat on after helped hide the seams. Any sheets I glued on I used the carpenters glue again. Use your finger to spread it around thin and evenly for best results.
Step 16: Mounting Brackets
The first method I thought of to wear the costume was to install two pieces of wood on the sides. I cut two large holes for a rope handle to be inserted through, and then a series of smaller holes for a pair of eye hooks to attach shoulder straps to. I was going to have the straps criss-cross over each shoulder and then down to the other side. This method did not work. The Tardis was too wobbly and was hard to control. It also ended up hurting my son’s shoulders.
I would still install this piece in your Tardis as the handles did come in handy when walking around.
The next method I tried, which worked quite well, was to build a bracket to mount a backpack to. I installed two cross beams at the back of the Tardis. You'll need to make sure they are not flush with the back. I then put two vertical beams in. I found that once I put the backpack on the center of gravity for the Tardis was too far forward, so I removed the backpack and added some spacers and another two vertical bars. This put my son more in the middle of the Tardis and the balance was much better when he put it on.
To mount a backpack I just put the backpack against the bars and ran a heavy tape around all the bars and the backpack to secure it in place. I found that one vertical strip and two horizontal strips worked great. Using a backpack that has both a chest clip and a waist strap will work best.
Step 17: Have Fun!
For a finishing touch I made a red cardboard bow tie for my son.
The costume was a huge hit at the show. My son couldn't walk 5 feet without someone wanting a picture with him. He even made the newspaper the next day.
3rd Annual Make It Stick Contest
Grand Prize in the
Halloween Epic Costumes Contest
Finalist in the
3 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Party Challenge
    Party Challenge
  • Fandom Contest
    Fandom Contest
29 Discussions
Red5iveCraftybrosephBW
Reply 3 years ago
Sorry for the late reply. Yes you could use cardboard. I would layer it up, at least 4 layers to replace all the wood in my build. 4 layers glued together should make the frame strong enough to keep the rest of the costume together. You might have to make each piece wider though to compensate. I'd love to see a finished photo! Thanks for the interest.
Red5ivejpartridge4
Reply 4 years ago on Introduction
I designed the Police Box signs on my computer and then took them down to a local printer as I wanted them as one piece. When applying them I promptly screwed up the first one (always start with the back panel as your practice BTW...). I didn't want to pay to print another one so the one I screwed up I just printed at home in two pieces and then applied them carefully. I placed the first one down and then I cut the second one at a 45 degree angle so it would be easier to match up pieces perfectly.
CraftybrosephBWRed5ive
Reply 3 years ago
hey could i use card board instead of the wood strips? because i don't want to use wood. just cardboard
Nellielewis
4 years ago
We used your instructions for my sons costume this year. It was a hit! Everyone went crazy over it. Thanks.
Monkeydizzy212
4 years ago
Awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
weargle
5 years ago on Introduction
he has the wrong sonic screwdriver because he is wearing a bowtie meaning he is the 11th doctor
darthbindy
I'm waiting for the paint to dry on mine right now (I left my costume late) Due to printer issues I only have the sheet thats on the left door, (no public call police signs along the top) I'm hoping it will still work, and hope that however I mount it will be comfortable...Any suggestions for mounting if I'm out of wood?
Red5ivedarthbindy
Reply 5 years ago on Introduction
I'm not quite sure what you are wanting to mount, but hot glue will stick wood and cardboard (and cardboard to cardboard) together quite well. Wood glue (Its like white glue but yellow) will also stick cardboard to wood or cardboard to cardboard very well. It takes a little longer to dry than hot glue, but it is actually stronger in the long run.
What are you trying to stick together?
Mr_will
This is by far the coolest thing made out of cardboard that I have ever seen! Good job bloke!
elmochick
6 years ago on Introduction
Awwwww! I saw this little guy at Calgary Comic Expo in 2012. Cutest Doctor I'd seen all day. :) Very well done. :)
poofrabbit
Congratulations on being a finalist in the Halloween contest!!! Can’t wait to see if you win! Good luck!
Lucky7x7
Great build! i bet the Doctor is so happy to finally be a ginger Voted! My daughter was a dalek this year.
misko13
Wow... this is amazing!
I voted for you in the contest :D
