Dollar Bill Ring Bling
158,207
178
46
About: I like taking things apart and figuring out how they work. I generally loose interest after that.
How to create a ring out of a dollar bill, or any other US money, for that matter.
This is a continuation of my money origami series, started here. As with the previous one, massive credit goes to Clay, who put up the idea originally, along with much other money art.
Step 1: Cold Hard Cash
Start with the side that reads "ONE" facing towards you on a flat surface. Like all money origami, a crisp bill will work best.
Flip the bill over, and fold the "white" edges on the top and bottom inward. Crease those folds, and return the bill to its original side.
Step 2: A Half Then a Quarter
Fold the bill in half. (You can flip this over to do it, or not. It doesn't matter.). Then fold the bill in half again.
Step 3: Making a Diamond
Fold the end of the bill up from the bottom. That "1" will be the center of the ring, and ideally you're trying to center to be even on both sides. The "white" of the bill gets folded under the "1."
Press everything down and crease.
Step 4: Ring Around the Finger (optional)
Just to get the shape of the ring, you can bend the folded bill around your finger a few times. It's not necessary to do this, however.
When you're done. place the bill back on a flat surface.
Step 5: Creating the Circle
This is one of those steps which is much easier to show than to describe. As seen below, fold the bill upward to create a 45 degree angle. The distance between this angle and the "1" will be the circumference of the ring.
Continue moving that fold under the ring, and back to the other side.
Step 6: Completing the Ring
Bring both ends of the bill together to form...a ring. Take the long end, and fold under the "1", tucking the folded end of the "1" under the long end.
Continue bringing the long end underneath the ring, and back around to the top.
Tuck the remaining flap underneath the "1", and press down all creases.
Step 7: Bling Bling!
And viola! You have a dollar ring.
*NB: If the ring is too small, as it will be for most men's fingers, there's a simple way to fix this not discussed in the original author's directions. You can skip the part of Step 5, where one wraps the bill around itself. Instead, just make the 45 degree angle fold (the first picture), and proceed to step 6.
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    46 Discussions
    CrackersW
    2 years ago
    I used some tape to hold it in place and folded in a different direction. Still, works! A great instructable
    emilolip
    6 years ago on Introduction
    Very cool! I used a little glue to keep it strong, but other wise a good instructable!
    X41
    7 years ago on Step 7
    awesome instuctable
    but it is 90°, not 45° ;D
    NinjaToast
    8 years ago on Step 7
    Sweet, My pinkie is no longer naked!!
    FoyetMoypalicious
    Reply 8 years ago on Step 7
    its cool i made one and i wear it too lol but then i spent it... :^(
    101lenny101
    9 years ago on Step 5
     Just wanted to let you know, that's a 90 degree angle. Great Instructable though!
    KC-Dimples
    9 years ago on Introduction
    You are my newly found hero! xD
    I've been making dollar rings for a while, but i couldn't figure out how to make the 1 in the center of the ring... Then again I never put much thought into it. But thanks! :D
    jeffreyfPetervG
    Reply 12 years ago
    If you'd like to send me some Canadian notes I'd be happy to figure out a modification :)
