Double Chair Bench With Table
20,156
494
13
About: I make all sorts of stuff. You can watch my YouTube Channel or Follow me on other Social media!
I needed a nice seat in my Garden to Relax, so i made this Bench with some minimal tools and some reclaimed Pallets, and 2x4's, i had to buy some 2x4 to get the project done, so this Bench is just partly Reclaimed.
This Bench is not a Unique one ,lots of them are Build the same way, is just fused them together so that everyone can build it!
Step 1: The Cutlist and Instructions
1pcs- 2×4 61″ long – Front Support
1pcs- 2×4 58″ long – Rear Support
2pcs - 2×4 23 1/2″ long – Front Legs
2pcs - 2×4 22 9/16″ long – Arm rest supports / side frame
2pcs - 2×4 24 5/16″ long – Rear Legs (inside edge to inside edge (24 5/16″ long Outside edge to Outside edge) 15 degree angle on each side (cut ends parallel to each other)
4pcs - 2×4 19 3/4″ long – Cross Supports 15 degree angle on 1 side
4pcs 2×4 24″ long – from square edge to outside point – Backrest Supports – 15 degree angle on bottom only – Top is cut at a 90 degree angle.
Cut each piece on your miter saw. For all angles in this project, set the saw to 15 degrees. Use a jigsaw to cut out the notch on the two front legs. The 2×4 piece will eventually rest in the notch. Measure 9 1/2 inches up from the bottom of the 2×4 front leg and mark. Measure 1 1/2″ back (depth). Then measure from your nine inch mark up 3 1/2″ and make one more mark. Connect the lines and cut out your notch on both pieces. Next, Cut with a jigsaw and use an orbital sander to smooth the edges. Assemble Both Sides As shown in the video, attach the front and rear leg together on the top with the arm support 2×4. Measure 11″ back from the rear of the front leg and put a mark. Then line up the rear leg so that the 15 degree angle sits flush with the arm support. Only attach the two legs to the arm support in this step. We’ll get to the lower cross support later.
Measure 11 inches from the back of the front leg to the front of the back leg. Flush it up with the horizontal 2×4 and attach with 3 screws. Attach each cross support. For the middle 2 you can drive 2 screws in from the front side. (Through the 2×4 and into the cross support.). To attach the rear side of the support drill a pilot hole through the side of the cross support at an angle down into the rear support. It will keep it in place and later steps will solidify the joint. Attach Back Supports Fasten to the sides with 2.5″ screws. Flush up the bottom with the 15 degree angle. The upper support arm bottom corner will be flush with the back side of the backrest support. Attach Chair and Backrest Wooden Slats Attach the front slat so that it hangs over the front 2×4 by 3/4″. Then attach the rear slat so it touches the two backrest supports. Attach the remaining 3 slats and space them evenly apart. (About 1/4 or so). Next, attach the backrest slats. Attach the top board first to help square up the backrest supports. Then attach the bottom slat. Finally, attach the remaining boards and space evenly.
2 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Party Challenge
    Party Challenge
  • IoT Challenge
    IoT Challenge
13 Discussions
TerryD78
1 year ago
Do you have a bill of materials for this? I am adding up the board feet for the 2x4s. I do not know how many or what type of screws though. Thank you
Bob BurgerTerryD78
Reply 7 months ago
I use ceramic coated deck screws, about 65 x 2-1/2" for the frame assembly and about 116 x 1-1/2".to attach the table uprights, tabletop boards, slats, and arms.
KeithC117
11 months ago
We all need a complete cut list how many 2x4 . are they 8ft studs or 16 ft & forget it. Ill do it myself. Peace
Bob BurgerKeithC117
Reply 7 months ago
I make and sell these but don't notch the front beam, I set it back 1/4 and screw from the side like the rear beam so both are 58", my versions require the following materials - two 2 x 4 x 105" studs, three 2 x 4 x 8', five 1 x 4 x 8' and one 1 x 6 x 10' cut according to the attached screenshot.
kmorken
2 years ago
yo confused. using 2x4s front leg notches 9 1/2 then mark up 5 1/2? how your 2x4 fit in a 5 1/2 notch so snug??
Bob Burgerkmorken
Reply 7 months ago
Because he's copied DIY Pete's design which has a 2x6 across the front, but forgot to change it when he copied it into this site.
Strollyman2004
2 years ago
How wide are the seats and how wide is the table in the middle?
steven.laver1
2 years ago
can you give more pictures?
OllarisDIY Hacks and How Tos
Reply 2 years ago
Thanks! Yess i really love it i think i make some more, eventually w.o. the table in the middle!
