Drawer Organizer: Custom Fit to Your Drawer and Contents
2,955
74
6
This project uses durable hardwoods to make a drawer organizer that fits your drawer - and your things - exactly.
The boards in the organizer have slots so they fit together like a puzzle. Glue is optional if you need a solution that you can disassemble easily.
Step 1: First, Draw Your Plan.
Measure your drawer and the things you'd like to keep in it, and create a graph based on that.
In this case, I have 5 rows of spice jars that measure a bit less than 2" wide, and then some larger spice jars and mixes.
My drawer is 16" wide x 21" deep.
My pieces of wood are .25" wide, and since I will have 5 of them, that will take up 1.25" of the width.**
That leaves a space that's plenty big enough for my needs, so I just went with the remainder for the large spices.
Also, measure the height of your drawer so you can get or cut your wood to size.
** You will have to decide on the type of wood you're using to get this measurement
Step 2: Step 2: Gather Supplies
Supplies I used:
  • 7 pieces of craft poplar (these happened to fit quite nicely for the height of my drawer). You may need fewer pieces depending on your design. I recommend one top and one bottom piece and then as many dividers as you need for your items.
  • Optional: glue to strengthen your joints
  • The finish of your choice. I painted my insert white to match my cabinet, but you may choose to stain and 2seal.
Equipment:
  • Measuring tape
  • Pencil
  • Graph paper (optional, for laying out the drawer plan)
  • Chop saw
  • Sandpaper (or rotary or belt sander)
  • Table saw
  • Wood file (optional, for cleanup or enlarging any holes)
  • Rollers, brushes or rags to apply your finish
Step 3: Step 3: Measure Overall Length of All Boards.
In my case, I had 5 21" boards and 2 16" boards.
Measure twice, if you're into that sort of thing. :)
Step 4: Step 4: Chop Away
Use a chop saw to make your first set of cuts to the boards.
Step 5: Step 5: Sand Those Jagged Edges
Use your sanding implement of choice to smooth your edges. I ground down my corners a bit as well.
Step 6: Step 6: Set the Depth of Your Slots
We're going to cut slots in the wood to make this divider go together like a jigsaw puzzle.
First, mark out the depth of your cuts. I suggest going about 1/8" beyond the halfway point in the board so that the surfaces can lie flush. This exact measurement will depend on the curve of your table saw blade.
Measure out half of your board PLUS 1/8" and draw a straight line all the way across every horizontal board. Mark the larger side so you'll know where to put your slots.
Then, measure out half of your board MINUS 1/8" and draw a straight line across each vertical board. Mark the larger side so you'll know where to put your slots.
Step 7: Step 7: Mark Your Slot Positions
As you can see from the picture here, I didn't get the most exact length cuts on my vertical pieces. So what's a girl to do if she wants the slots to line up?
I stacked them all together with their edge on the table and made a line about 1" from each end. That way, the lines were in the same place and I could use them as guides for the slots in the next step.
Step 8: Step 8: Mark Your Slots
NOTE: This picture shows me marking the slots on the wrong side. Please don't be like me and mark the other, wider side of the line.
Use one of your trimmed boards to mark the width of the slots. Line up the outer edge of the line you just made at the edge of the vertical boards and trace the outer edges of your scrap wood.
On the horizontal boards, you'll have several slots as shown in the second photo. Measure these out according to your plan and mark them using your scrap pieces of wood as a guide.
Step 9: Step 9: Saw Your Slots
Use a table saw to saw all of your slots. I found that my .25" boards fit perfectly in a cut that was three notches wide.
Test your widths and depths by sawing a slot on one vertical board and one horizontal board and seeing how they fit together. Make any adjustments to the height and width of the slots before moving forward.
Be careful and use all the proper safety tools for your equipment.
Step 10: Step 10: Refine Your Slots
My slots were a bit rough, so I used a wood file to even them out and remove some rough edges.
Step 11: Step 11: Test Your Assembly
Put your project together to make sure everything fits properly.
If not, you may have to go back to the file or the saw and widen your slots. I had one that was too tight and needed adjustment.
Step 12: Step 12: Paint or Stain and Finish!
Disassemble your project and paint or stain. Don't forget to paint the outer edges, since they'll be visible in your drawer.
Allow to dry thoroughly.
Assemble it and install it in your drawer. Stock it with your goodies and rejoice in your organizational prowess.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Jewelry Challenge
      Jewelry Challenge
    6 Discussions
    kinderdm
    3 years ago on Introduction
    What would you recommend for making the slots if sans table saw like myself. I could maybe do it with the circular saw but I have doubts about the quality of this method, as well as maybe the safety if a clamp should slip or something. Basically I have a lot of hand tools but no real shop size tools.
    SS427CamaroCrazyGirlkinderdm
    Reply 2 years ago
    If you use something thinner like balsa wood you could score it with a knife. As long as you're meticulous and careful slipping shouldn't be a problem. Accidents are caused from lack of concentration, carelessness, being too comfortable with a tool & just plain stupidity. Don't be intimidated and afraid to venture out and try new things. Power tools are for girls too! There are numerous videos on YouTube that show you how to use power tools.
    Terranankinderdm
    Reply 3 years ago on Introduction
    Don't risk your fingers with the circular saw... If you have a hand saw, just use that. It may take longer, but its safer than using a power tool not meant for the job.
    SS427CamaroCrazyGirlTerranan
    Reply 2 years ago
    If you own power tools you're probably smart enough to use them... A hand saw would take forever!!! Geez...
    erinstrattonkinderdm
    I don't have a lot of experience with tools in general - this is my first woodworking project. So I'm hesitant to suggest something with my limited experience, I'm sorry to say.
