Dremel Table Saw
28,063
257
19
During a project a little while ago, I needed to make a small insinuation, smaller than the curve of a blade, thus I constructed this little table.
Step 1: The Table
To create the table, I used three leftover 2x4s.
Step 2: Hole for the Dremel
After the table is constructed, I used a drill press to make a hole the size of the dremel head in the wood.
Step 3: Dremel Table Saw
Then I screwed the table to my work bench and clamped the dremel to a post. After that I clamped an extra piece of wood to the top in order to create a strait edge and there we go, a dremel table saw!
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    19 Discussions
    swisscarp
    2 years ago
    A) I love the whole midea here...
    B) I noticed that you drove the nails “under” the plane of the “table”. I don't know that I would have thought of that, and I'm glad that you showed it.
    C) However, if you've got newer or nicer workbench, you might think of using “carpet tape” instead of nailing/screwing the “Rotary Tool Auxiliary Table” to your workbench surface.
    PKM
    2 years ago
    "I needed to make a small insinuation"
    I think you might have meant "incision" there- an incision is a small cut, whereas insinuation means hinting or suggesting something. Just a thought.
    I like the look of this, although the table is quite small- if you made a bigger table this could be a really cool project.
    srilykPKM
    Reply 2 years ago
    Ah, incision makes a lot more sense. I also assumed the OP meant kerf of the blade, which is the width of the cut that the blade makes. I was guessing that they wanted a thinner kerf than their normal table saw provided.
    unusual architectPKM
    Reply 2 years ago
    correct on both accounts. The one I constructed is small because I use it to construct architectural scale models
    Dawsie
    2 years ago
    I found a circular cutter for the dremal which I can use just like a standard circular saw it did cost a but I think I paid around $50AUS for it at Bunnings but well worth every penny I spent on it I also bought the router setup for it as well, it cost about the same I think. I use them for making miniatures for dollhouses. The dremal is great for doing this as they also have the add ons depending on what you need them for.
    ochetski
    2 years ago
    Genius!
    I have a very limited space and this will save me. Thanks a lot.
    DaveErving
    2 years ago
    Sorry, I'm not trying to be mean or a smartass, but how is this a table saw. I can understand a router table, but how can you cut things with this? Maybe if the dremel attachment stuck up above, but then it would be a thick crude cut. Even if it was a cut off wheel turned sideways, that way you could cut things. Great idea, I'm not trying to put you down, just wondering.
    ghostgeekDaveErving
    Reply 2 years ago
    I agree. This is not a table saw. Though a very clever hack to turn a dremel into a table ROUTER! I'd suggest renaming this 'ible (if you can). Other than that, brilliant hack! :)
    unusual architectDaveErving
    Reply 2 years ago
    its just what I called it because I used it as both a saw and a router table. and I was only cutting balsa wood. sorry
    walter_wpgDaveErving
    Reply 2 years ago
    I agree with you, Dave. This is a Dremel router table, and a perfectly adequate one. Sure, it could be used to cut some materials, but it is misleading to Instructables readers to call this a "table saw".
    John T MacF MoodDaveErving
    Reply 2 years ago
    With the right bit (a plunge router type) this arrangement will work very nicely as a fairly accurate and fine cutting table saw. Nothing crude about it.
    Tystud
    2 years ago
    So simple, yet genius. I was trying to find a real simple way to use my dremel in this very way, and I'm too lazy to make one of those fancy "drill press" or "table saw" ones on Instructables. Thanks man!
    John T MacF Mood
    2 years ago
    I'm thinking some of these concepts could be used with the heavier plunge router type drills, I may try it with mine.
    DylanD581
    2 years ago
    Nice portable saw! Can it cut through plywood? Dremel tools are so useful!
    Razanur
    2 years ago
    I would like to see a live-action video :)
    Yonatan24
    2 years ago
    Cool! What do you plan on using it for?
