Driftwood Canoe Paddle Connect With the Past.
11,268
241
18
About: We celebrate creativity on the southern Oregon coast at our store, the Electric Hospital, and outdoors where we enjoy the wonders. We might be sewing with a long arm robotic quilting machine in the morning a...
I was loaned a book called, Cedar The Tree of Life. It told about the amazing uses the natives of the Pacific Northwest had for this remarkable wood. It was the most important wood for its ease of working. I was inspired to find a driftwood cedar log to craft a native style paddle from. I took my canoe to an island where much driftwood collects in Coos Bay. As I began this quest a young eagle circled above a stretch of beach where I soon found a cedar log.
Supplies: you will need an eagle, canoe, vehicle, rope, buck saw, axe wedges, milk jug, pack, survival gear, life jacket, draw knife, shave horse, sand paper, cod fish liver, chalk line, pencil, luck and an island covered with driftwood.
Supplies:
Step 1: Split Off Plank.
When it comes to finding a cedar log in a pile of driftwood all logs look the same gray. Cedar splits easy according to the book. Walk around splitting and sniffing for cedar.
The challenge was the log had a nice flat side positioned 90 degrees from where I wanted it. I could not drive the wedges sideways to split it easily. I began digging out the sand with my hands to get the log to roll over. Then it hit me If this log rolled it could pin me to the ground. I might be there until the next high tide or worse. I abandoned that plan and began driving wedges to split off a plank on the side with lots of knots.
Step 2: Repeat and Start Over.
This created a twisted knotty non paddle looking board. After 9 twisted planks I ended up with a usable board.
Step 3: Shorten Plank to Movable Length.
Eat lunch take a break and prepare to burn some more calories. Drag the canoe unloaded across the sticky mud. Drive a stake in the mud and tie up the canoe. Carry the gear and plank to the waters edge. Take a photo of the canoe at the waters edge this may be your last photo alive make it a good one. Tie the wedges, axes, maul, and saw you would not want to loose when you capsize in a pack and attach a 50 foot rope with a milk jug as a float. Untie the coil of rope and leave it in the bow with the float attached. When you capsize, the float will mark where your wood working tools are for recovery latter (if you survive.) Head into the wind to keep the waves from crashing over the side of the heavily loaded canoe.
Step 4: Don't Talk.
Thank the Eagle Spirit when you finally get back to the dock. Collapse in total exhaustion on the dock then get rest for the next part. After a 15 minute rest pack the gear to the vehicle. Carry the canoe to your vehicle on your shoulders, try not to scratch the roof or hurt your back as you put it on by yourself. Tie on the canoe then go back and get the plank. Slide the plank between the ropes and canoe. Drive home carefully.
Don't tell your wife about the Eagle Spirit, the scary crossing or the milk jug float. This will avoid another call she will make to your doctor about your sanity. Besides she might ask silly questions like, "why didn't you go to the lumber yard for a board." When home don't unload yet just fall asleep on the couch in the middle of the afternoon.
Step 5: Look for a Paddle in the Plank.
Look for parts of the plank that could be a paddle like the local natives used. They had a pointed blade and a V shape on the shaft where the grip attached. There was a smooth shoulder as the blade transitioned from the shaft. I needed some explanations as why that would be done. Thin the plank using a draw knife while clamping the paddle in your shave horse. Take out the big bumps and pop center lines on all edges with a chalk line. Draw the shape you want to carve avoiding loose knots.
Step 6: Carve With the Grain.
Cut out the rough shape including the V in the shaft for the handle grip. Carve with the grain what does not look like a paddle. You will want to have the edges thin and the middle thicker for strength. As you carve turn the paddle so it is easier to go with the grain. When the wood is splintering turn the tool around or the plank. Sometimes it helps to slice the wood. Instead of just pulling the draw knife towards you pull the knife sideways (perpendicular to the pull) as it comes towards you. It is OK to flip the draw knife upside down or even push with it. Carving is about what ever works. You can take a lot of wood off fast so as you get close to the finished thickness S-L-O-W D-O-W-N.
Step 7: Attach the Grip.
As the paddle begins to take shape you can sand it with old belt sander belts. The grip is attached by boring two holes in a block adding a bit of glue and hammering in place. Finish with linseed oil if you do not have a cod fish liver.
Step 8: Discover Why.
Abuse the paddle to discover why it was shaped that way. It makes a great instant anchor in the soft silt of the estuary. When in shallow water you can pole with it. It releases from the silty mud easier than any other shape. The shaft has a soft shoulder that allows it to paddle in seaweed without hanging up. The V grip gives a hole that makes it easy to hang up in your plank house.
It must be the Eagle Spirit that makes it so magical. (Shh don't tell my wife.)
Magic paddle video
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    18 Discussions
    ChristineH1
    4 years ago
    What a great story and finished project...might try to recreate my own someday when I find my own eagle, cod fish liver and have an extra milk jug...until then, keep creating for the rest of us to enjoy!
    Ninzerbean
    4 years ago on Introduction
    What a pleasure that was to read - you are a wonderful and funny writer and the paddle is amazing. I also collect cedar driftwood, it is so strong, the grain is so pronounced and the color inside is beautiful. I dye it with fabric dyes and make wall hooks.
    bartworker
    It's always a great pleasure to find a project that makes me jealous. This is just beautiful & full of harmony & good taste. Thanx for this great 'feel good' instructable, and thanx to the great Eagle Spirit to have guided you to this mighty worktool hidden on that beach. I want more of that.
    I love it all! The story, pictures, shave horse, draw knife and especially the finished paddle. I made a cedar oar once from a single tree.
    Dr. Joealexanderall
    Reply 4 years ago on Step 3
    Yes I have floated telephone poles and towed them with a double canoe and 4 paddlers. The shave horse was an 18 foot 4 X 12 I pulled out of the bay but I had a second paddler. Towing makes for a very difficult to control boat. I would not want to do that in whitecaps with a 25mph wind.
    JmsDwh
    4 years ago on Step 8
    Nice shave bench. I've thought of making one of those but I never found plans I liked. Did you make that one?
    Dr. JoeJmsDwh
    Reply 4 years ago on Step 8
    Yes this shave horse was made from driftwood and a section of rebar. The wedges can me changed to adjust the project you want clamped. One wedge has a dowel pin that keeps it from sliding.
    JmsDwhDr. Joe
    Very nice. You should make an Instructable about it if you can.
    Dr. Joeplanca40
    Reply 4 years ago
    Yes Astoria is on the other end of Oregon but the state is not that big. Are you from Astoria?
    NathanSellers
    4 years ago
    very cool looking paddles. I love the story too. thanks for sharing. I just love raw wood.
    Tangski
    Very very nice project. Wish I were at the coast to make one! Take care and happy paddling....and I won't tell your wife!LOL
    smorgsborg
    4 years ago
    Wow! Beautiful work!
