Drill Perpendicular
30,188
242
8
Hi There!
This is my old work. I decided to share this too
Everyday I needed to drill perpendicularly what I did not do well :(
So I did it
Material: beech plank 20 mm (preferably any other material, such as polyamide nylon), iron pad 5 mm and a spray of 6 mm diameter
I will share the drawings but perhaps these measures do not work, the other drill might need another size :(
Step 1: Dimensions and Drawings
It should be measured by the details of which is attached to the item.
Then create a drawing whose internal diameter should be equal to the measured drill's detail
In my case, 51 mm ...
Step 2: Making
Step 3: Result
It's a simple thing but I've helped :)
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    8 Discussions
    BenjaminK79
    1 year ago
    and here we see a life hack
    Gofish
    1 year ago
    Just about to make something similar for a particular job. Very useful.
    AMbros Custom
    1 year ago
    nice design but required some more improvement.it will be better to add springs in your 4 post.so that you could drill at what ever depth.
    johan.j.edman
    1 year ago
    This is really great work. Simple design but highly modifiable.
    joen
    1 year ago
    How did you get the four posts exactly 90 degrees to the base?
    GiorgiQjoen
    Reply 1 year ago
    I prepared this detail cnc machine, he managed it :)
    baecker03
    1 year ago
    you should add a depth setting tool into this. Wouldn't be much more, and the functionality would be more than worth it.
