Drill Powered Go Kart
35,070
229
29
Drill powered Go Kart for kids.
Video of build and Go Kart in action:
Part list:
  • 21mm plywood
  • cordless screwdriver
  • wheelbarrow wheels
  • skateboard wheel bearings
  • screws
  • tubes
  • old bike parts - wheel hub, chain, chainrings
Tools used:
  • Jigsaw
  • Drill/ screwdriver
  • Router
Supplies:
Step 1: Steering and Frame
At first I made frame/ steering part template on cardboard and checked if front wheels moves as expected. Then cut our frame parts and steering wheel out of plywood.
Step 2: Drivetrain
  • In wheels made groove for bearings and pressed them in.
  • Drilled 4 holes in wheel disc and screwed bike chainring.
  • Heated up axle bolt and melted it in acrylic. Then cut acrylic round and screwed chainring. Drilled hole between axle and bold and put screw there, so it don't unscrew.
  • Put chain on.
Step 3: Screwdriver Holder
Measured screwdriver dimensions and cut holder out of plywood.
Step 4: Seat
Seat also is made plywood
Step 5: Painting
When everything was tested, took everything apart and painted in grey / black.
Step 6: Closeups / Details
Other projects you can find on my youtube channel: https://www.youtube.com/channel/UCu7-pEsvU_GNoOkYGADyB3w
Design For Kids Challenge
Grand Prize in the
  • Gardening Contest
    Gardening Contest
  • Party Challenge
    Party Challenge
  • Woodworking Contest
    Woodworking Contest
29 Discussions
GalvãoJ
16 days ago
Vc tem as fotos das dimensões?
jjrussell25
Question 1 year ago
Hey, love the idea of this. My 5 year old son and I would like to make it, do you have exact measurements anywhere?
AurelieMarchaljjrussell25
Answer 3 months ago
Hello,
Have you manage to make it without the exact measurements? If yes, could you please give me the measurements of your pieces? My 11 year old son would like to make it as well and it would be indeed much easier to have the exact measurements to help him.
Thanks a lot for your help
torxAurelieMarchal
Reply 3 months ago
Sorry for the poor quality of the image; I hope you can still be useful
AurelieMarchaltorx
Reply 2 months ago
Thanks a lot! And could you please tell me how old is your kid? Mine is 11. Do you think the kart is big enough for a 11 years kid?
Thanks a lot for your answer.
Aurélie
torxAurelieMarchal
Reply 8 weeks ago
Please, Imagine. My nephew is 4 years old; For an 11-year-old maybe it's a little small: I would add 10 centimeters to the length, but then you have to see if it is well proportioned.
AurelieMarchal
3 months ago
Hello,
I would like to know if you could give us the dimension of the different pieces for my son and his friend of 11 years old who would like to make your kart.
Thanks a lot for your help.
Best regards,
Aurélie
torxAurelieMarchal
Reply 3 months ago
torx
11 months ago
Done!! Thanks for the Nice project!
AurelieMarchaltorx
Reply 3 months ago
Hello,
I would like to know if you could give me the dimension of the different pieces of the kart you made. My son and his friend of 11 years old who would like to make it as well.
Best regards,
Aurélie
JON-A-TRON
Tip 1 year ago
As NightHunter300 said below, you could have a reverse setting! Just make a c-shaped part on a post so it can swivel back and forth. The ends of the C push the reverse switch on either side with a brake cable, just like you did with the pedal.
simplerandomLuby
Answer 1 year ago
In left bottom corner there is pdf button - that should work.
PamelaM76
Question 1 year ago on Step 6
Do you think this possible to do with beginners?
How long would it take to make?
How much would it cost?
1 answer
simplerandomPamelaM76
Answer 1 year ago
Yes, we buid it with 3 years old.
I guess it can be done in 2 days of slow work. Can’t say how much it took for me - build it in free time randomly.
Cost depend on do you have any parts for build or not. I bought only wheels and some screws spending on total under 20eur. Was trying to use/ reuse parts and materials I already had.
Before build I suggest to make prototype from cardboard - it helps a lot later.
ganeshmahajan1985
1 year ago
This is fantastic.
I would like to build one.
Any plan for adding breaks to the cart ?
OrienteeringGuy
1 year ago
You are a master at making things work in the simplest way, often thinking outside the box. My only suggestion would be to add some kind of guard to keep little fingers away from the chain and gears.
