Dual Axis Solar Tracker With Online Energy Monitor
86,973
609
61
About: Hello, I'm Bruce. I'm a student in Belgium. I have a wide variety of interests: electronics, computers, technology, ... In my spare time I spend a lot of time on: projects, exploring the internet, cycling. ...
This project was one of my final projects I did on my exchange studies in Finland.
For this project I worked together with Fatbardh.
This is a much larger and more advanced version of one of my first projects ever.
Also a solar tracker: https://www.instructables.com/id/Arduino-Solar-Tracker/ .
The features of this solar tracker are:
  • Solar tracking: making sure the solar panels are aligned to the sun as long as possible.
  • Energy monitor: This measures the voltage and the current generated by the panels and calculates the generated Power and Energy.
  • Data logging: this sends the data from the energy monitor into the cloud of ThingSpeak.
  • Also there is an LCD to display the values of the energy monitor
In this instructable are technical drawings of the project included. And at step 10 there is a link to the complete project report and presentation.
Why:
To read more about the energy profit from this kind of system please read this chapter on wikipedia.
This is also my entry for the 3D printing contest:
I would love to have a 3D printer. It will help me a lot to do other projects. To make gears and enclosures. So if you found this Instructable interesting please vote for my Instructable in the 3D printing contest.
My excuses for my spelling mistakes, you may always let me know if you see some.
Step 1: Overview
In this step I’ll go over all the used components in this project.
Solar panels:
We used 2 solar panels of each 12V 150W which will bring the total to 300W.
Ebay link
Energy Monitor:
The energy monitor uses 2 current sensors, to measure the current.
And one voltage divider to get the voltage down to a voltage that the Arduino its analog-digital-converter or ADC can handle.
If you don't want to make it your self you can buy one as well: ebay link
Light direction sensor:
Light direction is detected by four Light dependent resistors or LDRs. Each of the LDRs is placed in a voltage divider and the signal is fed to the Arduino its ADC.
ebay link
The end stop Switch
The end stop makes sure the mechanical construction doesn’t collide in its self.
Ebay Link
The motors
The motors are 12V linear actuators from internet.
Actuators on ebay
And are controlled with a very simple H-bridge.
motor drivers on ebay
ESP8266
The ESP8266 is a cheap WIFI module which we use to send the data to a ThingSpeak datastream
Ebay link
The LCD
The display is used to display the energy monitor values
ebay link
The microcontroller
The microcontroller we used was an Arduino ATMEGA 2560
Arduino MEGA 2560 R3 ~10$ - Ebay
The charger
For the charger you should search for a MPPT (max power point tracking) chager. And for sure not buy the one in the picture because this one overcharged our batteries and is not MPPT.
Step 2: Mechanical Construction.
We both didn't had a lot of experience with metal working. Because of this we got help from a local vocational school.
The construction exists of a strong steel beam, in which a second part is placed, by sliding in a rod in a hole. To this set-up are levers added to which we connect the linear actuators.
Have a look at the technical drawings (PDF) and the pictures to get a better idea of what it looks like.
The technical drawings and the renderings are made with Fusion 360
Linear actuator ebay link
Step 3: The Light Sensor
This is the same principle as the previous version. 4 LDRs separated by a crossbeam. This time the crossbeam was 3d printed.
It works by comparing the average of LDR values of each side to determine which side to rotate to.
LDR holder 3d model: http://www.thingiverse.com/thing:1500571
Photoresistors ebay link
Step 4: Motor Control Algorithm
The motor control algorithm is responsible for turning the motors on and off. This all depending on the data of the ligh sensor.
This also improved compared to my previous version. Now there is a hysteresis implemented. Comparable to a Schmitt trigger. So the motor turns only in if the light difference is larger than a certain threshold value, and it will only stop if the light difference is below a certain value.
Step 5: Energy Monitoring
The energy monitor works by measuring the voltage and current output of the panels.
By multiplying these two values you get the generated power.
P = U * I
P= Power in Watt; U = Voltage in Volt; I = Current in Ampere.
By integrating the Power over time you'll get the total generated Power.
Voltage measurement
The voltage measurement is done by a voltage divider over the panels output. To get the output range of the panels 0-22V down to a range of 0-5V to protect the analog-digital-converter.
Current measurement
The current measurement is done by two ACS712 hall effect current sensors.
Current sensor ebay link
Step 6: Data Logging
The data logging is done by sending all the data to a ThingSpeak channel.
This is done by an ESP8266 WIFI module.
The ESP8266 ebay link
Step 7: Microcontroller
Step 8: Software
If you want to use this code you should have a look at:
  • EnergyMonConnections.h
    • connections for the energy measurement
  • solartrackerdefines.h
    • settings and conenctions for the LDRs and solar tracker
  • solarPanel.h
    • to set the formulas right for the calculations of the ADC
  • internet.h
    • set wifi name and password aswell as api key
Step 9: Final Results!
Step 10: More Information
For much more information about this project.
I would like to recommend you my project report and presentation.
Report
Presentation
Step 11: Questions
If you have any questions, feel free to ask. If you can't find your answer in the comment section.
And I'll try to add more information to the Instructable depending where the most questions are about.
I hope you had fun reading my Instructable.
Outdoor Structures Contest
Runner Up in the
Automation Contest 2016
Second Prize in the
3D Printing Contest 2016
Runner Up in the
5 People Made This Project!
  • Organization Contest
  • Weaving Challenge
    Weaving Challenge
  • Tape Contest
    Tape Contest
61 Discussions
TCIII
3 months ago
An excellent project for a well earned degree.
I have bought two of George's 3D printed LDR array shields and have experimented with LDRs of high and low dark resistance. I have found that it is best to buy a number of LDRs and hand select LDRs with the same dark resistance to use in the LDR array.
I actually built George's earlier tracker that used an Arduino Uno R3 to work with different LDRs. George used pots to adjust the delay time and the tolerance values in his original code. However a delay time value of around 10 is a good arbitrary value, but you must experiment with the tolerance value to prevent hunting if you do not include the pots from the original Arduino code. I found that LDRs with high dark resistance required a tolerance value of around 25 while LDRs with a low dark resistance required a tolerance value of around 5 to provide accurate tracking and prevent gimbal hunting.
I live in Central Florida, USA and plan to build a solar tracker system similar to George's to provide emergency power when we lose power during a hurricane.
Regards,
TCIII AVD
wicherc
9 months ago on Step 11
Hi Geo! Great job!!!! I have two questions: 1) Can I work with this idea for my home? 2) Where was instaled and connected the stop switch?
Thank you!
lmresende
Question 11 months ago
It is possible to have the schematic diagram, of the completed project. Or at least how have you connected the linear actuator ? Please
RuneL6
12 months ago
HI, can you please send me all drawings and how to connect everything?
runlud@gmail.com
RuneL6
Question 12 months ago
Is it possible to gett more dravings?
And information?
i want to make a 5 kw system , panels ca 37 volt
runlud@gmail.vom
Djeffers12
Question 1 year ago on Step 7
I'm curious to know if this Arduino has the same capability as the Uno when it comes to control systems. Do you need to have the Uno hooked up to a laptop?
GulM6
1 year ago
Hello,
First of all, GREAT project.
Kindly tell me what stroke length motors you have used?
JankoS1
Question 1 year ago on Step 8
great. project. i would need like to make a smelter for bee wax with duak axis solar tracker system. i am a beginner with program arduin and i would need help at code. i just need code for solar tracking system with end switch.
bestregards janko
FellaMegaOld.
1 year ago
Meh.. 2x 5v 200mah panels (east/west or north/south) placed flat on the edge of the pv panel . 2x 5v relays with flyback diodes & 5v PV blocking diode to both east or west relay. Connect battery positive to n.c. of both relays & battery negative to n.o. of both relays. Connect common of one relay to actuator positive , connect common of remaining relay to negative of actuator.
No micro, No mosfet, No worries.
Absolutely foolproof & cheap. Please find a simpler & more elegant way ?
mongause
1 year ago
Why add other sensors when the solar panel itself knows when it's squared up with the sun. Have the program measure panel output voltage each step until the voltage starts dropping then reverse to where the highest voltage was measured.
davem304
1 year ago
Hi Guys,
How did you calculate the rotational angle possible by the fixed arms and selected actuators. Really stuck on this.
Regards,
Adam
36South
1 year ago
What azimuth angle can you achieve ? I have a 300mm (12 inch ) stroke actuator and am trying to reconcile the two pivot arm dimentions. As I read the plans, you have 330mm on the fixed pivot and about 715mm for the moving pivot. What is the stroke length you used ?
JuliusH20
1 year ago
Do you think that's possible that I use an Arduino Uno (see the project from Joshua Zimmermann) to control two 12V/24V DC motors for an dual axis slew drive?
is it possible to use big servo motors to support such charge of 150W solar pannel? if yes may i have the name of such servo motors and how to use it?
great work at all. thank to share it Ing. Geo Bruce. please i would like to know which motors you are using and the electronic scheme for command with connections details. Waiting please
rohit27arora
1 year ago
can you help with the code , as i'm using a stepper motor for pan motor
and the tilt motor is a dc motor .
chilefil
1 year ago
Nicely done!!
bror2011
2 years ago
How big is the motor which use solar tracker ????
NetoW
2 years ago
geo bruce, thank you very much, for passing your knowledge to us, I am from Brazil, and I am studying about photovoltaic energy and I will put this project into practice if you authorize, of course.
