Dual Mode Windup Car
11,717
158
29
About: Retired and still learning.
Dual Mode Windup Car is my first attempt at an enclosed windup vehicle. My previous designs have been "open chassis" to reduce weight, and of course so that I could watch the gears in motion (I truly like watching gears in motion, but it's just a hobby, I hope). This enclosed windup vehicle is a significant weight increase over the open chassis designs, and to compensate I did increase the final drive gear ratio from 1/25 to 1/16 to increase the torque. As such, I also strengthen the axles and gears to handle the increased torque. After testing, this vehicle easily traveled around 40 feet over the rough epoxy surface in my workshop. I'm still learning Autodesk Fusion 360, but it was instrumental in the design and appearance of this vehicle.
Dual mode refers to this vehicles two modes of operation, power and coast. Once the spring is wound using the key, releasing the vehicle propels it forward until the spring is depleted of its stored energy. This is the power mode. When the spring energy is depleted, the rear axle is disconnected from the spring motor via a floating pinion gear allowing the vehicle to truly coast. This is the coast mode.
The wheels and body top as shown in the photographs and video are designed for a dual extrusion printer, however I have included single extrusion versions of all the necessary parts.
You will need to purchase 16 "AS 568" size 222 (1 3/4 O.D., 1 1/2 I.D., 1/8" diameter) o-rings for the tires.
I probably forgot a file or two or something, so if you have any questions, please feel free to ask.
Designed using Autodesk Fusion 360, sliced with Cura 2.3.1, and printed on an Ultimaker 2+ Extended and an Ultimaker 3 Extended in PLA.
Step 1: Print and Prepare the Parts.
I printed my parts on an Ultimaker 2+ Extended and an Ultimaker 3 Extended using .1mm vertical resolution and 100% infill for "Axle Spring.stl", "Key.stl", "Pawl.stl", and "Spring.stl", the remaining parts at 50% infill.
Print two "Cross Member.stl", two left and two right wheels of your choice (dual or single extrusion), and one each of the remaining parts.
Prior to assembly, test fit and trim, file, sand, etc. all parts as necessary for smooth movement of moving surfaces, and tight fit for non moving surfaces. Depending on the colors you chose and your printer settings, more or less trimming, filing and/or sanding may be required. Carefully file all edges that contacted the build plate to make absolutely sure that all build plate "ooze" is removed and that all edges are smooth. I used a flat jewelers file and plenty of patience to perform this step.
Study "Assembly.stl", carefully noting the locations and positions of the various components as assembly proceeds.
Finally some terminology. When "press" is used, this means the parts must fit tight and as such must be pressed together using a vice, C clamp, slip joint pliers or equivalent. When "place" or "slide" is used, this means the parts fit loose and should slide / rotate freely. The body side references of "right" and "left" are in relation to the vehicle itself as if you were sitting inside.
Step 2: Assemble the Axles.
Start by pressing "Axle Gear Pinion Floating.stl" into "Gear Pinion Floating (12, 8 Teeth).stl". Leave 4mm of the axle exposed on each side of the gear.
Next press "Axle Rear.stl" into "Gear Axle Rear (12 Teeth).stl". The gear must be centered on the spline of the axle.
Finally the spring axle is assembled in place on "Body Right.stl". Press "Axle Gear Idler Large.stl" into "Body Right.stl" (this axle also functions as the spring end mounting point). Slide "Axle Spring.stl" into "Body Right.stl" from the outside of the body. Next press "Spring.stl" onto "Axle Spring.stl" carefully noting the orientation of the spring on both "Axle Spring.stl" and "Axle Gear Idler Large.stl" (again, the spring end mounting point) and making sure the spring is firmly seated (there should be very little, about .5mm, endplay of the axle on "Body Right.stl" but it should rotate freely). Press "Pawl.stl" onto "Axle Spring.stl" again carefully noting the orientation of the pawl on the axle.
Step 3: Assemble the Body Right Side.
Press one of each of "Cross Member.stl" into "Body Right.stl".
Press "Gear Pinion Floating Guide Right.stl" into "Body Right.stl".
Place the idler gear assembly into position in "Gear Pinion Floating Guide Right.stl" noting the orientation.
Place "Gear Axle Spring.stl" onto "Pawl.stl".
Place "Spacer Axle Spring.stl" onto "Axle Spring.stl".
Place "Gear Idler Large.stl" onto "Axle Gear Idler Large.stl".
Place "Spacer Axle Gear Idler Large.stl" onto "Axle Gear Idler Large.stl".
Place the rear axle assembly into "Body Right.stl".
Step 4: Assemble and Attach the Body Left Side.
Press "Gear Pinion Floating Guide Left.stl" into "Body Left.stl.
Press the body left assembly onto the body right assembly. This step requires that all axles and cross members be aligned to fit into their proper holes.
Once completed, all gears should rotate freely and the floating pinion should easily slide throughout the guide slot.
Step 5: Assemble and Attach the Wheels.
Install the o-rings on the wheels.
Press two wheels onto "Axle Rear.stl", one right and one left, noting the alignment of the wheel spokes. Once installed, the rear axle should rotate freely. If not, make sure the body sides are pressed fully into position.
Press a right wheel onto "Axle Front.stl", slide the assembly into the body assembly starting on the right side of the body, then press the remaining left wheel onto the remaining end of "Axle Front.stl" again noting the alignment of the wheel spokes. Once installed, the front axle should rotate freely. If not, make sure the body sides are pressed fully into position.
Step 6: Attach the Top.
The top snaps onto the front and rear cross members. Noting the orientation, slightly spread the top, then position it around the cross members and snap into place.
Congratulations, you're done!
Hope you like it!
Design Now: In Motion Contest
First Prize in the
3 People Made This Project!
  • Organization Contest
  • Pocket Sized Contest
  • Build a Tool Contest
29 Discussions
ebrennan5
18 days ago
Great design! I have been a huge fan of your work and truly appreciate you posting your files for anyone to download and learn from. I saw you had several Youtube tutorials and wondered if you ever intended on posting a screen capture of your design process on Fusion 360 for a project such as this. Would love to see how you layout your designs and compensate for tolerance and 3D printing. I noticed you stopped posting on Thingiverse, do you have a website? One more questions, do you add a positive tolerance between your pitch circles and how much?
Thanks and keep up the good work.
gzumwaltebrennan5
Reply 17 days ago
Hi ebrennan5,
Thank you very much, I am truly glad you enjoyed this model and my other designs!
I have not posted a screen capture design process for anything other than the containers, hinges and "two gear" tutorials that I published. A screen capture of a model such as this would require some time to capture since I'm quite confident I would make numerous mistakes during the screen capture process and have to perform numerous restarts!
Regarding Thingiverse, I post there on and off due to low traffic. I'm not sure if it's Thingiverse, Thingiverse members or both, but there seems to be little interest in what I publish there.
Regarding gears, yes, I do add tolerance between the gears. I add the pitch radius of the two gears to a "tolerance" value to space the gears. The tolerance value varies depending on the colors I use, and for publishing, I usually use .4mm. Also, after printing, I use either jewelers files or a handheld motor tool with a wire brush wheel to remove the build plate "ooze", as this is an important step for proper gear mesh.
Many thanks again!
Greg
DaveK145
8 months ago
well finally got it done took me awhile but worth it nice print cant wait to print more of your stuff.had to print at 75% thats all i could get on my print bed.
gzumwaltDaveK145
Reply 8 months ago
It looks fantastic, congratulations!
Greg
gzumwalt
9 months ago
When you say "freeze", you mean your printer just stops?
What printer are you using?
gzumwalt
9 months ago
That depends on what you mead when you say it "stops about half way". Is your printer air printing? Does it freeze up? Is the model skewing?
First, using Cura, place the viewport mode in "layer view" the, using the vertical slider, make sure Cura t is producing a slicing pattern suitable for your printer.
Next, if it is air printing, then it's more than likely a nozzle or filament feed issue.
And finally, if the model is skewing, then it is more than likely a printer issue (loose belt, loose build plate, etc.).
I'm not sure which it is, but hopefully with a little more experimentation we can fix the issue.
Sorry about the problems you have had with this model.
Greg
jbumstead
1 year ago
Beautiful design. Did you use a program for modeling your gear system?
gzumwaltjbumstead
Reply 1 year ago
Thank you so very much, I'm glad you enjoyed it.
The only program I used for the entire design was Autodesk Fusion 360. The gears were generated with the gear add-in with a specified number of teeth and module in order to obtain the desired pitch radius. I also add .5mm to the computed distance between gears for 3D printing.
Thanks again!
jbumsteadgzumwalt
Reply 1 year ago
Thanks for your reply. I am thinking about doing a gear project soon and your note provides some helpful advice.
gzumwaltkenyer
Reply 1 year ago
Thank you very much, I'm sincerely glad you like it!
HendoJ
1 year ago
Awesome slick design. Love it- Will print one soon- when I get a printer XD
gzumwaltHendoJ
Reply 1 year ago
Thank you very much, I hope you do get a printer and print one!
Davecc
1 year ago
Great design! I've saved all of the STL files for a later date so I can make one for my grandson. How big is the toy car in size? I have an original Makerbot Replicator 3D printer. Will I be able to print it on my machine? My build area is 6" x 9" x 6".
gzumwaltDavecc
Reply 1 year ago
Thank you so very much, I am sincerely glad you liked it!
The "longest" parts of the car are the body sides and top, which measure about 8" long. When you print yours, see if it fits on the build plate "diagonal" (e.g. corner to corner as opposed to front to back). It may be close!
Thanks again!
gzumwaltTimothee Gillier
Reply 1 year ago
I runs 40 feet in my shop then as you can see in the video it hits the door. Because of the additional weight, it doesn't accelerate as fast as the rolling chassis version, but for top speed, I've never checked.
Thanks, glad you liked it!
MarkT112
2 years ago
Great design-Surprising power from a PLA "spring"!
gzumwaltMarkT112
Reply 2 years ago
Thanks!
I spent more than just a few hours designing, printing and testing spring configurations before I finally succeeded. One thing is for sure, always print it at 100% infill.
Thanks again, glad you liked it!
Stymieddd
2 years ago
Nice design! Good luck!
