ETextile Felt Skull Brooch
6,295
82
5
In this tutorial I will show how to sew your own skull brooch that lights up by touching between its eyes. Firstly we will sew the felt skull, and afterwards, a felt battery holder with metal snap buttons on the backside.
Materials
- Skull pattern
- Felt
- Lining and wadding
- metal snap buttons
- 2 leds (3mm)
- 100 Ohm resistor
- 3V battery
- Conductive thread
- Conductive fabric
Step 1: The Pattern
Download and cut the skull pattern.
You need to cut two bases, two eyes, a nose and a theeth.
Step 2: Cutting and Sewing the Skull Face
Cut the felt patterns and sew the eyes, nose and teeth. Hand sew and embroider the skull face with colored threads as you prefer!
Once the skull face is decorated and stitched, punch the two leds in the eyes and the resistor between the eyes.
To correctly orient the leds, the positive leg must be in the upper side and the negative leg in the lower side.
Step 3: The Circuit
In this circuit, the two leds are connected in parallel. The positive legs are connected to the positive borne of the battery. The negative legs are connected to a 100 Ohm resistor and the resistor is connected to the negative borne of the battery.
Step 4: Sewing the Led's Negative Legs
Use a plier to make a loop shape with the negative legs and the resistor legs. Use conductive thread to sew the two negative legs and one of the resistor legs together.
Sew the other resistor leg with conductive thread and stitch until the skull teeth. These stitches will be later part of the negative borne of the battery.
Step 5: Sewing the Led's Positive Legs
Place the lining on the back of the skull face by punching the two positive legs through it. Make a loop shape with the positive legs and sew them together. These are the positive borne of the circuit.
Pass the conductive thread (negative borne) through the lining too.
Step 6: Cutting a Hole in the Wadding
Cut a hole in the wadding and place it over the lining. Cut a little piece of conductive fabric and place it over the hole.
Pass the conductive thread (negative borne) through the wadding too.
Step 7: The Backside
Sew two metal snap buttons on the backside. First, sew the buttons with normal thread and then sew them again using conductive thread.
Sew a few stitches on the upper button using conductive thread. This button is the positive borne.
Then, sew a few stitches on the lower button with conductive thread by passing through the wadding (negative borne).
Step 8: Final Stitches
Sew around the edge of the skull with colored thread. The skull is now finished.
Finally, sew the metal snap button in a felt battery holder too and connect it to the skull. The skull will light up when you touch it on the middle of its face.
You can nail a safety pin on the backside and wear it in your t-shirts!
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
5 Discussions
ColleenF31
Question 25 days ago
Love this and I want to make it. You didn't mention the little bread board looking thing in the picture that shows the connections. Where did you get it and what size is it? Thanks!
krummrey
4 years ago on Introduction
Cute little skull. I had a very similar idea. We must think alike :D
BLR_RAVI
4 years ago
looks so nice..this tiny little skull with lightings..nice
Mola molt! Ja fa temps que tinc ganes de fer alguna cosa amb leds i em sembla que per fi he trobat el què! Gràcies per compartir-ho!
It's so pretty and it even lights up! This is awesome, and you did an really nice job explaining all the electronic bits! Thanks for sharing!
