EMP Generator
96,035
341
49
About: I am always making electronic stuff. I like to do Arduino projects best. more projects coming soon!
This is a easy, portable and cheap DIY project to make a electromagnetic pulse (EMP).
Follow the few steps and you got yourself your own EMP to disable or destroy electronic devices (this EMP is only strong enough to destroy a calculator).
Supplies:
Step 1: Schematic
I made a easy to follow schematic of the device.
basicly it`s just a coil thats connected to the capacitor whit a switch on the positive wire.
I used a DPDT switch to arm and fire it. If I turn the switch to the right than it charges the capacitor, in the middle it´s off and to the left than the voltage goes to the coil.
Step 2: Parts & Tools
For this project you only need 4 parts (thats what I used)
- DPDT switch, I would recommend using a plastic switch so you won't get a nasty shock.
- Thick isolated copper wire.
- Disposable camera.
- Some wires
Tools:
- Soldering iron.
- Soldering tind.
- Desoldreing pump.
- Tape.
- Toilet paper roll.
- Cutter plier.
Step 3: The Coile
Making the coil:
Make a small hole on the top of the toilet paper roll and stick the wire thru the hole like shown in the picture.
Take the copper wire around the roll 7 times.
Slide the copper wire off the toilet paper roll and tape the coile when you get it in its shape.
Step 4: Removing & Soldering
Open up the the camera and take out the circuit board but be careful if you get your fingers in the wrong place than you are going to get a nasty shock (if the capacitor is charged).
Remove the flash and the switch for the flash.
Solder 3 wires to the charge switch as shown in the photo and just follow the photos and the schematic.
Step 5: Finish
Now you are ready to do whatever you need a electromagnetic pulse for, you can make a nice enclosure for it to. I am not responsible for any destroyed phones or damage!
If you have any questions or tips to this project than post them in the comments, thanks for viewing and check out my channel for more projects.
  • Gardening Contest
    Gardening Contest
  • Fandom Contest
    Fandom Contest
49 Discussions
DiegoT62
2 years ago
Hola como puedo hacer para ampliar su poder asta un alcance de 50 metros aproximadamente? gracias
TylerD92DiegoT62
Reply 1 year ago
Hola, he buscado informacion en español sobre todo lo que tenga que ver con PEM pero no he visto nada bueno, dan por hecho muchas cosas .. sobre lo que he leido para conseguir mayor alcance, la bobina tendria que tener mas vueltas de alambre o el circuito deberia funcionar con mayor voltaje, he visto que ocupan 4 baterias de 9 volts y aun mas pero en ese cso cambiaria el circuito.
Si tuvieras algo de informacion sobre PEM basico en español te lo agradeceria.
WEB1One
2 years ago
How would I go about making this thing directional??
bnnormanWEB1One
Reply 1 year ago
With great difficulty!. You could try a parabolic metal mirror.
Bpgas01
3 years ago
You could use one charging circuit connected to a bank of capacitors connected in parallel. But if you make it too powerful, the EMP will release everythinh in the spectrum from radio to x-radiation. So if you are in the blast radius, you might end up with cancer.
Note: if you do make it powerful. I recommend using a directional antenna
ShupedewoopBpgas01
Reply 2 years ago
false, the energy released from this is and can only be a electro magnetic pulse,
pumping more power into a microwave wouldnt give you the amount of radiation, so why would this do that, and its not even on the spectrum related to radiation
bnnormanShupedewoop
Reply 1 year ago
Wrong! An electromagnetic pulse is made of multiple frequencies (harmonics) though they tail off in amplitude the further you get away from the base frequency. If the Pulse duration is, say, 1ms that's a base frequency of 2khz, you then get odd harmonics at 3x,5x,7x etc. Just Google for square wave harmonics.
togdyBpgas01
Reply 2 years ago
It's just not the truth. Or you've got no idea what you're talking about.
Demonstrations (see YouTube Videos) indicate this device works on devices only in very close proximity -- in some videos only when this EMP device is literally IN CONTACT with the "EMP-ee". How can its power be actually TRANSMITTED?
Shupedewoop
2 years ago
It works by charging up the capacitor then releasing all the stored power in one short burst
Shupedewoop
2 years ago
To all asking about gauge of wire, try something around 26 thats what i did, i also made a massive coil though
PhilieBlunt
3 years ago
sorry if this is a dumb question, but where is this getting power from? i dont see any kind of battery or anything on this circuit board...
PhilieBluntPhilieBlunt
Reply 3 years ago
Oh duh, nevermind, i see the battery in the first pic now, yup im an idiot
ibenkosPhilieBlunt
Reply 3 years ago
It might be a bit hard to see but the battery is under the capacitor and its not in the photo under the building photos.
PardalP
2 years ago
Making a bigger one is for when there is someone walking with the car glued to their back. Just give a pulse to destroy the electric motor.
patrebates
3 years ago
I have a suggestion that would offer up a MUCH more powerful EMP generator for fairly little money. Go to any farm store (Rural King, Tractor Supply) even online. Buy a livestock electric fence energizer. I have one to energize my fence on 5 acres, capable of energiing up to 5 miles of fence. It puts out 20,000 Volts. There are bigger units that will energize 10 miles of fence, I think generating ~40,000 volts. There are even solar powered versions that have a small 12 volt battery pack and a couple solar cells to keep it charged. THAT would be the basis of a self-contained unit. The
patrebatespatrebates
Reply 3 years ago
The cost for a basic 5 mile fence energizer is about $40. The solar versions are more expensive because of the battery pack and solar cells. Still, not too expensive (maybe $150) for a nice EMP generator. You can HEAR the EMP off these fences in normal operation on any AM radio if you are within about 100 ft of a short in the fence. The spark jumping to a nearby nail or tree limb produces a clock-like blast of static on your radio, and that's not even trying. Put the juice through a coil and you could get a nice, intentional blast.
