ESP8266 - $5 Internet Connected Switch
82,591
625
42
In this tutorial we will show how to build WiFi internet connected switch connected to EasyIoT Cloud. We will use ESP8266, solid state relay and Arduino IDE. Switch can be controlled by WEB application, native Android application or button.
Improved version of this switch can be found here:
https://www.instructables.com/id/ESP8266-5-Internet-Connected-Switch-Improved/
This internet switch is "plug and play" - it will automatically set all EasyIoT Cloud settings, so no configuration in EasyIoT Cloud is needed.
Material for switch cost about 5$.
WARNING!! You will play with LIVE MAINS!! Deadly zone!!
If you don't have any experience and are not qualified for working with MAINS power I will not ecourage you to play arround! Do NOT use it without proper Knowledge about MAINS circuits ! Do NOT use it without a proper FUSE on MAINS line! Max current for solid state in this tutorial is 2A - suitable for room light only.
Supplies:
Step 1: Material
Materials:
  • ESP8266 WiFi module
  • Solid State Relay 2A 240V
  • 3.3V 600mA AC-DC step down module
  • Push Button switch
  • NPN Transistor TO-92 2N2222
  • 1000uF electrolytic capacitor
  • resistor, 1K, 47K
Click to buying guide for ESP8266 internet connected swith.
Step 2: EasyIoT Cloud Registration
Register to EasyIoT Cloud. You will need username and password later in program. Also use username and password to access EasyIoT Cloud and control your device from computer or mobile phone. Also EasyIoT Cloud Android application is available.
Step 3: Program
Program is written in Arduino ESP8266 IDE. See Arduino ESP8266 IDE tutorial how to connect ESP8266 module to computer to upload program. Program can be downloaded from GitHub. You will also need MQTT client library. Add this library to library folder in Arduino IDE. Program uses EasyIoT Cloud MQTT API.
In program change following lines to set access point username and password and your EasyIoT Cloud username and password:
#define AP_SSID "xxx"
#define AP_PASSWORD "xxx"
#define EIOTCLOUD_USERNAME "xxx"
#define EIOTCLOUD_PASSWORD "xxx"
Step 4: Hardware
In our case we use ESP8266 01, but you can use any other type of ESP8266. GPIO2 is connected to NPN transistor to control SSR. Max current for our type of solid state relay is 2A - this is suitable for room light and not for applications which consume more power - for example heater.
For power supply we use 3.3V step down module. It's very important to add 1000uF capacitor to 3.3V power line - in our case switch didn't work if we skip this capacitor. GPIO0 is connected to push button for local control of internet switch.
After power on, switch will be automatically added to EasyIoT Cloud and it will be visible in WEB interface or Android application where you can control your device from remote locations.
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    42 Discussions
    juaalta
    2 years ago
    Where can I get the enclosure? It's not listed in your buying guide.
    BallscrewBobdjelincic
    Reply 3 years ago
    In my mock up the 3.3 triggers an opto switch that is part of a chinese relay module which allows the 5V to actually operate the relay.
    In this instance it is triggering a transistor as a switch to allow a larger load to operate the relay.
    Sort of like a relay to operate a bigger relay / larger load
    See the link for a little more explanation.
    http://www.hobbytronics.co.uk/arduino-tutorial9-po...
    MarkS654djelincic
    Reply 2 years ago
    It doesn't make sense, I'm afraid - there are traces of a couple of misunderstandings there. The ESP cannot supply enough current to drive a relay, and that's what you need a driver (e.g. the transistor) for, but in this circuit that does NOT increase the voltage - in fact (again, in THIS circuit) it decreases it. In the circuit as drawn, the relay is going to see a voltage of about 2.7v: it's being powered by a 3.3v supply, and you're going to lose about 0.6v of that across the transistor. Now, perhaps the relay will still work at 2.7v - I haven't tried - though it's not guaranteed. Really you either need a lower voltage relay, or a higher voltage supply for the relay. A supply giving 5v for the relay and 3.3v for the ESP would do nicely.
    darcicidade
    2 years ago
    Is it possible not to use the automatic registration of parameters?
    and, register manually the parameters!
    // Create Sensor.Parameter1
    #ifdef DEBUG
    Serial.println ( "/" + String (storage.moduleId) + "/Sensor.Parameter1/NewParameter");
    #endif
    myMqtt.subscribe ( "/" + String (storage.moduleId) + "/Sensor.Parameter1/NewParameter");
    waitOk ();
    NikkiS8
    3 years ago
    Thanks for nice tutorial. How can I use it behind the proxy server ( my institute have proxy server with id and user name)
    IshuJ1NikkiS8
    Reply 2 years ago
    Did you solve the proxy problem ? The same condition is in my institute also , I have also contacted various forums but they couldn't solve the problem.
    JasonG123
    2 years ago
    follow instructions and you will solve your error
    JasonG123
    3 years ago
    I receive this error .... seems im not the only one?
    ESP MQTT\mqtt\mqtt.c.o:(.bss.default_private_key_len+0x0): multiple definition of `default_private_key_len'
    ESP8266WiFi\WiFiClientSecure.cpp.o:(.bss.default_private_key_len+0x0): first defined here
    ESP MQTT\mqtt\mqtt.c.o:(.bss.default_certificate_len+0x0): multiple definition of `default_certificate_len'
    ESP8266WiFi\WiFiClientSecure.cpp.o:(.bss.default_certificate_len+0x0): first defined here
    collect2.exe: error: ld returned 1 exit status
    Error compiling
    ChứcNJasonG123
    Reply 3 years ago
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwiY5cPPwZTMAhUG5aYKHRCeBvsQtwIIIzAB&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DC1XSj9YvZtA&usg=AFQjCNG2YpTCfuuqjAY4yPFkmhzMrVZfxA&sig2=4Uhsl1oD2lu2ZBpp1PFAdw
    zikzak1
    3 years ago
    I just use my firewall/router. Log into it from anywhere. Added bonus, I can shut a single LAN IP address down, or all, or check traffic, or redirect, etc. Your device could come in handy for a few other things I can think of though!
    iftikhar1zikzak1
    Reply 3 years ago
    can you please shear your work.?i want to control esp8266 pins from global network.
    ChứcN
    3 years ago
    thank you very much your share
    aegis21
    3 years ago
    Any help on the enclosure would be appreciated, great work!
    Solominator
    3 years ago
    ...Aehm... It look like that you have voltage on the lamp even when it's not on...
    this can be dangerous.
    I think it would be better, when you connect the relais first to the power line and then the lamp... then you don't have voltage on the lamp, when the relais is off.
    Arty Marty
    3 years ago
    Just wondering if this relay would also work or be better.
    http://pages.ebay.com/link/?nav=item.view&id=351542314917&alt=web
    It can be triggered by 3v and looks like it can handle 240v+ at 20A+ so could be used to operate Hi-Fi amp etc.
    I want to be able to turn my Stereo on/off with my phone to control music through the house.
    Would this work with this relay?
    adillbeck
    3 years ago
    What I'd really love would be to be able to make a 3 pole switch, so I could put it in line with a normal 3 pole wall switch in order to control lights remotely while still being able to control them locally too...
    BallscrewBobadillbeck
    Reply 3 years ago
    I found that I can do just that. I can trigger my relay manually and latch it.
    Seems that easyIOT does not check the state of the relay it just sends a command.
    I can power mine down even and the easyiot does not know about it but will send a signal and tell me its on when its actually off. Most of the cheap chinese relay module have both an NC and an NO connection so they are pretty versatile.
    It would be nice if the IOT could register the state so I would know of power failures etc.
