ESP8266 GMail Sender
128,667
647
165
Hello and welcome to my first Instructable.
I will show you how to send emails from any ESP8266 wifi module using Gmail server.
This instructable relies on Arduino core for ESP8266 WiFi chip,
which makes a self-contained microcontroller from it (no need of AT commands and master devices).
You can connect sensors and get notified by email about changes.
2018 Update:
Here is newer code written as arduino lib. It supports multiple recipients.
Also no need to encode login and password to base64 now it uses ESP core base64 lib. github
2019 Update:
  • This code doesn't work with ESP8266 core for Arduino version 2.5.0!
  • Temporary solution use core version 2.4.2
Before we begin
Required hardware:
  1. Any ESP8266 (I'm using ESP8266-07 ebay link).
  2. In my case USB UART Board(I'm using FT232RL FTDI Serials Adapter Module ebay). Not needed if your board has usb port.
  3. Some jumper cables.
  4. WIFI router of course.
List may be incomplete.
Required software:
  1. Arduino Software
  2. Arduino core for ESP8266 WiFi chip
  3. Sketch with project and test code (ESP8266_Gmail_Sender.zip).
Step 1: Gmail Account Setup
We are going to use SMTP to send messages.
Using SMTP Authentication we provide only email and password,
by default Google uses more complex verification methods so we need to change settings.
Go to your Google account settings and enable "Allow less secure apps" at the bottom of the page.
This mean apps only need your email and password when login to your gmail account.
If you concerned about security, just use different account.
Step 2: Edit Sketch
I wrote a little sketch which send one test message to check if all works as should.
When all software downloaded and installed:
  • Unzip ESP8266_Gmail_Sender.zip
  • Find and open ESP8266_Gmail_Sender.ino
  • Set your wifi access point name (SSID) and password. Should be like this:
const char* ssid = "MyWiFi";
const char* password = "12345678";
  • In setup() function find
if(gsender->Subject(subject)->Send("boris.on@live.com", "Setup test"))
First parameter of Send() function is recipient email, second message text.
Change recipient from boris.on@live.com to your email which will receive a message.
I'm receiving many emails every day because some of You guys not attentive, PLEASE DON'T FORGET TO CHANGE RECIPIENT EMAIL!
Subject function is optional! Subject sets once and stored until you change it.
You can send mails without subject or if it already set
gsender->Send(to, message);
  • Now open Gsender.h tab
  • We need Base64 encoded email address and password of gmail account which will be used to send emails.
You can use base64encode.org for encoding, result must be something like:
const char* EMAILBASE64_LOGIN = "Y29zbWkxMTExMUBnbWFpbC5jb20=";
const char* EMAILBASE64_PASSWORD = "TGFzZGFzZDEyMzI=";
  • Now set FROM field.
const char* FROM = "your_email@gmail.com";
That`s all for this part.
Step 3: Code Uploading and Testing
Save changes. Don`t forget to set your board in Tool menu.
Upload sketch to your ESP8266 board.
Open Serial monitor, board will print log messages.
That`s all I hope you will receive "Message send.". Thanks...
13 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
165 Discussions
pavs99
20 days ago on Step 1
To make this work with esp8266 core 2.5.0 you need to do add a line.
in Gsender.cpp at line 53 and 54 it looks like this:
WiFiClientSecure client;
#if defined(GS_SERIAL_LOG_2)
You need to change it to:
client.setInsecure();
This is because of breaking changes after implementing BearSSL API for all SSL/TLS operations.
(https://github.com/esp8266/Arduino/releases/tag/2.5.0)
By using setInsecure() no check are done of the validity certificates This is the same behavior as with axTLS library that was used before.
More about the new BearSSL api for esp8266:
https://arduino-esp8266.readthedocs.io/en/latest/e...
Someone could update this project to support full ssl validation.
ryuk3
Question 27 days ago
Hello,
im stuck at the last part it says: Error sending message: SMTP DATA error 1085
any clue what causes this?
dheerajgurjar
6 weeks ago
while running ESP8266 Gmail Sender We are getting
error: Mail server could not connect
Can someone help me??
Thanks in advance
Ottov8henkoegema
Reply 3 months ago
I tried to use MicroPython to send e-mail but I quickly gave up.
You will need a library that allows you to send e-mail in Python.
With Arduino you can just install libraries. With normal desktop Python you can do that too. But with MicroPython you only have the select libraries that come with it, I think you can make a custom MicroPython build with extra libraries and flash that to the ESP8266, but I couldn't find out how. There's a MicroPython forum where you could ask.
I decided to just learn to work with the Arduino IDE (using C++) as there are many thousands of Arduino tutorials out there that work on ESP's and there aren't a lot of MicroPython tutorials out there.
It also makes it much easier to communicate with sensors. And it's faster then MicroPython. There's definitely a place for MicroPython, but I flashed MicroPython to my ESP because I thought it would be easier then using C++ as I already know Python a bit, but actually learning C++ made everything much, much easier for me.
RenataD9
3 months ago
Hello, I've been tried to use this code and i had some difficults. i have this:
Connection: ESTABLISHED
Got IP address: 192.168.0.14
Error sending message: Could not connect to mail server
Anyone knows how can i solve this?
Thank you!
omrif1RenataD9
Reply 2 months ago
Getting the same issue:
"Connection: ESTABLISHED
Error sending message: Could not connect to mail server"
i tried to modified the ESP8266WiFi\src\WiFiClientSecure.h file as suggested by Rundhall but still getting the same error...
i am using nodeMCU V3
Arduino IDE 1.8.6
any idea? someone?
many thanks
RFcontrolledSwitchRenataD9
Reply 3 months ago
Your problem is probably the ESP8266 core version you are using. The new 2.5.0_betaX is using BearSSL. If you downgrade to anything lower than beta1 you will have AxTLS and should be good to go. Worked for me.
It also works with 2.5.0-beta2 core if you switch to WiFiClientSecureAxTLS.h as this uses the old AxTLS.
RundhallDavidS1694
Reply 2 months ago
I had the
same issue.
In my
Arduino library I modified the ESP8266WiFi\src\WiFiClientSecure.h
To this:
#define USING_AXTLS
#include <ESP8266WiFi.h>
//#include <WiFiClientSecure.h>
#include "WiFiClientSecureAxTLS.h"
using namespace axTLS;
#ifndef USING_AXTLS
// do not default to BearSSL API ("using" has no "unusing" counterpart)
using namespace BearSSL;
#endif
After it
worked!!
mooserpRundhall
Reply 2 months ago
Thanks a ton Rundhall! worked perfect. Thanks for taking the time to post!
1-prop-headRundhall
Reply 2 months ago
As I did not properly encrypt email and pw
I also needed to enable less secure feature
All good sorry for the unnecessary question Great stuff thanks
1-prop-headRundhall
Reply 2 months ago
This did move me forward but.. now I see the following response
501 5.5.2 Connot Decode response d3sm--------------.64 - gsmtp
502 5.5.1 Unrecognized command. d3sm---same----.64 - gsmtp
Error sending message: SMTP AUTH error
Great sutff thanks for your help
dm
DarkoP3Rundhall
Reply 2 months ago
With same problem ... Now I got:
Got IP address: 192.168.1.76
1517
Do you have any idea what is wrong? (Arduino 1.8.8, ESP8266 core 2.5.0) Tnx
mooserpBorya
Reply 2 months ago
Hi. I have tried your new code but get the following error>Error sending message: Could not connect to mail server. I am using "version 1" of ESP8266WiFi. Could this be a problem?
Thanks.
By the way, your first version works perfect!
georgek25
3 months ago on Step 2
Please change your password on your email.
With reverse engineering on b64 is posible to get your password of email.
ThalesC1
3 months ago on Step 3
Hi, is it possible to send anexo file.txt in Attachment using your example ?
Diez66
4 months ago
Well, well, well. That went well; Thanks.
It took a while as I did not understand it all in one go, lack of experience I have never used the "include" a separate file before, but with some careful thought and the best part of a day I got there.
I had already tried other folks offering and after a lot longer came upon yours, THANK YOU.
You have helped me a lot, I will be looking at the code in more depth and I will learn, I am sure, quite a bit more. Onward and Upward.
