How to Bake Easy Bread
107,556
257
52
Making your own bread can be easy, and it's tastier and definitely cheaper than store-bought. Here's a simple recipe for bread with an overnight rise and minimal kneading.
Mix up a batch of dough one evening, mess with it for ten minutes the next afternoon, then bake. You'll have fresh bread in time for dinner.
Step 1: Ingredients & Supplies
Kitchen supplies:
1 or 2 loaf pans
1 or 2 mixing bowls, with lids or foil to cover
oven (and potholders)
spoooon!
Ingredients for two small loaves of bread:
3 cups all-purpose or bread flour, more for dusting
1/4 tsp instant/active dry yeast
1 1/4 tsp salt
~1 5/8 cups water (can substitute milk/soymilk for part of this)
cornmeal as needed (a pinch or two)
Ingredients for 2/3 recipe, for one larger loaf of bread:
~2 cups AP or bread flour
1/5 tsp yeast
1 tsp salt
~1 cup H2O (can substitute milk/soymilk for part of this)
Step 2: Mix the Dough, Let It Rise Overnight
In a large mixing bowl, combine flour, yeast, and salt. If you're adding in any other dry ingredients, mix them in at this step. For a savory bread, add in chopped or dry herbs (I'm adding basil to this batch), shredded cheese, chopped olives, curry, or other spices. For a sweet bread, you can add a bit of sugar, cinnamon, cardamom, chopped nuts, whatever else might be tasty.
Add the water & milk/soymilk. (If you're going for a sweeter bread, you can add in a touch of vanilla here.) Stir until well blended. The dough should be sticky and wet.
Cover bowl with lid or plastic wrap. Let dough rise for 12-18 hours at warm room temp (~70F).
Step 3: The Next Day...
After 12-18 hours, check the dough. The surface should be dotted with bubbles, and it should occupy more volume than it did the day before.
Lightly flour your counter or work surface. Place the dough on it -- you'll have to gently scrape it out of the bowl. Sprinkle the top of the dough liberally with more flour, the fold it over on itself once or twice. Form the dough into a ball, then set it seam-side-down back into a clean mixing bowl. Cover the bowl and let the dough rise again for another 1-2 hours. The dough should approximately double in size.
(The New York Times recipe I started with has several more steps here involving covering the dough with plastic wrap, letting it rest for 15 minutes, shaping the dough into a ball, then setting it in a flour-coated dishtowel for the second rise. I don't bother with any of that, and the bread turns out just fine.)
Step 4: Baking
About 30 minutes before the dough is ready, put your empty loaf pan(s) in the oven and set it to 450F.
(Note: the NYT recipe recommends using a "large, heavy covered pot" such as a Dutch oven to bake the bread. If you've got one, use it; I hear it works well. I don't have one, so instead I use regular loaf pans, cover them with foil, and set a shallow dish of water on the bottom rack of the oven.)
When the dough is ready, carefully remove the loaf pan from the oven. (Remeber, they'll be very hot!) Sprinkle a bit of cornmeal on the bottom of the pan; this will keep the loaf from sticking and make it much easier to remove from the pan later.
Carefully tip your dough-ball into the loaf pan, using the spoon to gently release it from the sides of the bowl. You want to keep the little bubbles in the dough intact as much as possible.
Cover the loaf pan with foil (again, using the oven mitts because the loaf pan is hot). Set the loaf pan on the middle rack of the oven, and put an ovensafe dish with 1/2" - 1" of water in it on the lower rack of the oven. (I'm doing this because I'm not using a pot with a heavy lid to keep the moisture close to the bread.)
Bake for 30 minutes, then remove the foil. If desired, you can brush the surface of the loaf with milk or butter at this point. Bake another 15 to 30 minutes until the crust is well-browned.
Step 5: Mmm Tasty!
Slide a knife around the edge of the pan to release the loaf, then tip the bread out onto a wire rack to cool.
Let it cool for 5-10 minutes. (I never manage more than that, because warm fresh-baked bread with butter is just too good.) Eat, toast, make sandwiches, enjoy!
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    • Fat Challenge
      Fat Challenge
    52 Discussions
    Tarkanos
    7 years ago on Step 3
    I'm not sure, from the pictures, if my dough is turning out right in this step. I find it hard to "shape" it in any way at all, and usually end up just putting it back intot he bowl. I can't shape it as such because it is still rather sticky and wet. Is it possible I just need to decrease my original amount of water for the dough? Or is it still supposed to be rather wet and sticky when it goes back for the second rise?
    reno_dakotaTarkanos
    Reply 7 years ago on Step 3
    When I've made it, it does stay pretty wet and sticky, and that seems to be fine. I use a liberal amount of flour on my counter & then sprinkled on top of the dough, just enough to fold it over itself a few times before it goes back in the bowl for the second rise.
    (Sometimes I also just do the second rise in the pans / dutch oven and then pop it straight in the oven from there, too.)
    This is an amazing recipe! I agree about double-quadrupling it. It's too good to only have a little!
    hobbaloo
    8 years ago on Introduction
    Oh man, I have to say, this is a great recipe. I added half a cup of raw sugar, a dash of vanilla essence and a handful of sultanas and it resulted in the most wonderfully moist fruitloaf... I had it fresh out of the oven (burning my fingers in the process) with butter and milk... *drools* Thank you so much for the great 'ible :)
    wenpherd
    9 years ago on Introduction
    Hey this looks great, but would it be better to do a double, triple, or even quadruple recipe since this takes a real looooong time?
    bonfire817
    8 years ago on Step 5
    I am SOOOO getting the dough going tonight! This looks FAN_TABULOUS! I even have some fresh basil I need to use up!
    thenear1send
    10 years ago on Introduction
    Hey, Nice Instructable!! I drew inspiration from this and decided to bake my own bread. I followed NO recepies or proportions and came up with a beautiful disaster! You know that you learn from your mistakes, i figured the more mistakes i make the smarter i will become, which worked in my instance! Lets see, it tasted horrible, it was fairly hard, it was too gooey in its dough stages, i added all sorts of berries, AND i even added green food coloring. xD Thanks for the inspiration!
    porero
    Hi, everybody. great, smooth and more. you use this recipe as a starter..... we, the newly born in the Heaven of bread, use as a sparker for creation..... I said too much, didn't I? be sure it is fantastic.
    million thanks reno dakota. the same to instructable.....
    Kroil
    Made this the other day with brown sugar, flax seeds, and a drizzle of honey on the top.
    Holy delicious.
    I've tried dozens of bread recipes and it wasn't any good.you see I've aurtirites in my hands. and your recipe is just God sent. it just wonderfully ease, ant what a taste. i would recommend this recipe to anyone who's hands are hearting-no knedding-thats what attracted me to this recipe. just follow the instructions to the T .( I've used small cast iron casserole dishes w/lids-perfection. Thank,you and God bless you for this.
    Thanks for the great instructable.! I can't wait to try it! Also: Dear "Homemadeby wife", thanks; your comments inspired me. God bless you too :0)
