Easy Build Burning Laser for Less Than $20
239,301
2,241
114
About: If you have any questions about my Instructables just ask me Kaltol1994@gmail.com Twitter and Snapchat Kaltol1994
In this Instructable I will show you how I built my own burning laser, including the driver circuit, the laser is able to burn through electrical tape, black plastic, and light matches with Sharpie on them (I'll let you figure out what happens to the Sharpies on your own) I diode I used is a 400mW 650nM laser diode, for those of you who don't know what that means, 400mW means 400 thousandths of a Watt is the peak power for this specific diode and 650nm is short for 650 nano meters this is referring to the wavelength of the radiation (in this case light) coming from the laser diode 650nm happens to be red.
UPDATE: Here are some links about lasers and safety precautions, link 1 will teach you about lasers, the second page teaches the hazards, link two is a guide to which goggles you will need.
1.) http://web.princeton.edu/sites/ehs/laserguide/
2.) http://www.newport.com/Laser-Safety-Accessory-Sele...
Curious as to what my exactly this project will do before you build it? Click this link to watch.
https://www.youtube.com/watch?v=xrtRaO9lLP0
**The $20 estimate is assuming you don't get everything from Radio Shack**
I would like to thank Maximilian Collins, who sold me the diodes and module, he tracked down the schematic and gave me some advice, If I can't answer a question, he can. Email: temporalanomalytech@gmail.com
Materials needed
1.) One (In my case a few) Laser diode $6.50 (plus a $2 shipping fee)
http://www.ebay.com/itm/171461736231?_trksid=p2059...
2.) One Aixiz Laser Module $4.50 (plus a $2 shipping fee)
*this module also acts as a heatsink for the diode*
http://www.ebay.com/itm/171503336476?_trksid=p2059...
3.) Perf board or bread board
4.) Thin gauge stranded wire
5.) One LM317 voltage regulator
6.) Heat sink for the LM317
7.) One 100 Ohm potentiometer
8.) Two 10 Ohm resistors
9.) One Diode (1N4001) (I used whatever diodes I had on hand)
10.) Push button/switch whatever your preference may be
11.) A 6V-9V DC power source
12.) One 10µF 16V capacitor, The individual I bought the diode and module from told me as long as the capacitors voltage rating is higher than the power input it's fine and I also used a non polarized capacitor in mine and it worked fine.
13.) Some heat-shrink tubing.
Tools Needed:
1.) Soldering Iron
2.) Third hand
3.) Lighter or Heat gun*
3.) Drill press and your smallest drill bit**
4.) Needle and hammer*
*I used my soldering iron to shrink the tubing, you may prefer to use a lighter or heat gun.
**These are optional and are possible solutions if fitting your diode into the module is an issue.
DISCLAIMER: I do not claim any responsibility for your actions or those of anyone involved in reproducing this experiment you should research and observe your local laws concerning this project and following all proper safety precautions before beginning the experiment. Your typical 5mw laser will irritate and even damage the eye, this laser WILL in fact burn your pupil and burn it if properly focused, it WILL blind you. Take the proper precautionary measures before going any further, it's up to you to know how to be safe I am merely showing you something I built and how I built it.
Supplies:
Step 1: Solder Leads to the Diode and Glue Into Aixiz Module
I press fit my diode into the module with my hands and some good luck, you may want to press them in with the right tools a drill press (Turned off of course) with a small drill bit would be the ideal tool for this situation, after pressing in the diode, use adhesive to lock it in place, I used gorilla glue, one drop is enough to do this twenty times so be cautious.
Next I bent the "not used" pin and removed it using wire cutters, then, I bent the negative pin to easily tell between the two remaining pins "What if I accidentally cut off everything but the positive lead?" Don't worry, every thing other than the positive lead is negative, including both pins and the body of the diode, as long you have the positive right, you're fine. I then tinned my leads, I highly recommend that you use stranded wire as opposed to solid, then all it took was touching the wires and soldering tip to their respective pins just long enough to melt the solder any more time than this and you can burn the diode like I did, don't be like me, I've had to buy four (I'm showing you how to do this so you don't have to!) Now heat up the heat shrink and tie a knot in the wires and you're good to go.
Lastly for this step re-insert the lens in to the module, a trick I found that works on anything with threads, turn it counter clockwise until you feel a "click" then turn clockwise until snug, or in this case, focused.
*Reminder when finished the Aixiz module will be grounded so be mindful of this. Don't touch it to the heatsink of the LM317 unless it's insulated, this is another way to burn a diode.
Step 2: Build the Circuit
For this step I tried to devise my own color coding system to make things easier, here I'll list the colors of wires and what they are, also DO NOT connect the battery before you connect the laser diode, this will charge the capacitor and blow the laser diode. be safe and short out the cap before connecting the diode.
All Red wires are positive, and head straight to the power source, aside from the two used for the switch.
All Black wires are ground.
The Orange wire is wired from the middle pin of the LM317 to one pin of the POT.
The White wire on one end is connected to the left most pin of the LM317 to the end of the resistors opposite of the POT.
The Yellow wire is used to make more room for components, one end is wired to the White wire and resistors and the other to the diode, cap and laser.
The Blue wire is the wire used to connect the positive side of the cap to the positive lead of the laser diode.
Once again be sure the power source is the LAST thing you wire up to the circuit and don't forget the HEATSINK for the regulator.
Step 3: Burn Things!
Take the proper precautions and have fun burning anything dark (black) in color, focus the beam by turning the the lens on the module, don't worry about it burning your finger unless it's at the focal point (even then I'm pale so it can't burn my skin), This doesn't mean your eyes are any safer, you've been warned.
In the pictures you can see it can cut through tape and I managed to burn holes in the plastic reels LED strips come on. I think the plastic is about 1mm thick and it burnt through two layers.
Did I mention I found a fun use for old sharpies?
Click here to watch my laser in action on Youtube!
Don't forget to vote for me, this is my first Instructable!
First Time Author Challenge
First Prize in the
2 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Classroom Science Contest
  • IoT Challenge
    IoT Challenge
114 Discussions
jman250x
4 years ago
Can I use a blue laser diode instead of red if since it has the same voltage just different wavelength?
yrralguthriejman250x
Reply 2 years ago
No. KalTol1994 is wrong.
Blue laser have less energy because of the color of the light. The 400 mW is input power not output.
burnerjack01yrralguthrie
Reply 2 years ago
LESS energy?? Blue is a higher frequency, by definition, it has greater angular momentum. This should equate to higher energy. Isn't this why there was such interest in designing X-ray lasers? Can you elaborate on this. Please?
I do know that some frequencies are better for cutting metal than say, organics such as wood.
Schlag96yrralguthrie
Reply 2 years ago
Actually, you're wrong. The lower the wavelength, the more heat is transferred. Ever heard of blocking UV rays to prevent sunburn? If everything else works with blue diodes in this build, it would be more powerful. Probably not enough to make much difference, though.
KalTol1994jman250x
Reply 4 years ago on Introduction
if it's 400mW it should be fine, here's the email of the guy I bought my diodes and module from, he's very knowledgeable and helpful which reminds me I should probably make another edit to my Instructable.... Maximilian Collins <temporalanomalytech@gmail.com> this guy really is helpful just mention this instructable.
samern
4 years ago
One thing that might be useful is to build a box around this rig so os mounted pointed down at a suitably absorbant surface. You can then place your item inside the box and bore your hole. The box walls can be made of material suitable for the wavelength. Extend that a little more and mount it on a suitable CNC type rig like Littlebox does and you have an engraver you can fully control. With it fully enclosed you are well protected from the light itself. What I haven't heard mentioned is the protection needed from what you are burning into. PVC for exanple, will release Chlorine gas which is lethal. So don't just protect your eyes, be sure to have loads of ventilation and don't inhale any fumes -- if you are burning through plastic have some sort of breather mask on.
msallen
The most important part has been left off the parts list - A PAIR OF LASER SAFTEY GLASSES!!!!!
Guys, this will do very serious, irreparable damage to your eyes, and all it takes is a stray reflection off a mirror or piece of glass or reflective piece of metal. PLEASE do not make this without buying and religiously using laser safety glasses (ordinary dark glasses will NOT work!). It only takes a flash of light to damage your eyes and there is no healing them. Try closing your eyes and walking around without them for 2 minutes so see what that means...
NoseyNickmsallen
... and that sign that says "WARNING! LASER! DO NOT LOOK INTO BEAM WITH REMAINING EYE" :-)
I flagged this as incomplete. Although you did add a warning to take safety precautions, you did not provide any details about such precautions. Laser safety glasses should be in the materials needed list and there should be a step about proper usage. eBay GLASSES DO NOT WORK with this wavelength! The cheapest ones that actually work are the Eagle Pair available from Survival Laser. At least provide a link to them. The AixiZ glasses work better, but cost more. This is a case of, "You get what you pay for."
http://www.survivallaserusa.com/Eagle_Pair__190-40...
That's good information that I can now research. Lasers and wavelengths vs what kind of eye protection. I would not have thought to look for that specific info. Thank you!
I've found a link about lasers and one for goggles, and I've featured your comment since it contains links for goggles pertaining to this.
Bowtie41
Another GREAT source of info is laserpointerforums.com about all sorts of lasers and their SAFETY
jay-bee
I would highly recommend Laser Safely Goggles when using a High Powered Laser as you describe.
A 400mW Laser WILL burn your retina since your eye's lens acts as a magnifying glass. It may also burn your skin if contact is made with the focused beam.
According to the drawing you supplied the Max current that can be supplied to the laser is limited to ~250mA. (1.25 / 5 Ohms = 0.250 A)
Not knowing your Laser diode type... An LPC-826 red Laser Diode will output ~150mW at 250mA. It will output ~350mW at ~570mA.
I say "about" (~) because all LDs are not identical.
The only true way to know the exact power of your Laser is with a Laser Power Meter. Hobbyist power meters such as the LaserBee Laser Power Meter products would be the way to go.
sappalangi
2 years ago
Hi guys, I got a laser diode from my DVD writter drive.before making the driver circuit I just want to check the laser diode is working or not .so I checked with a multimeter using diode mode.there is no light rays multimeter shows the value 1702 but no beep sound.is that spoiled? Plz help me
RGTech
2 years ago
Hi! Can you tell what gauge the wire is you are using is ??
Troller521
2 years ago
Will this not work if i use a 2000mW laser diode?
