Easy Cleaning - Clogged 3D Printer Nozzle
15,370
83
15
Cleaning a clogged nozzle is very hard at times. This is an easy and cheap method to clean clogged nozzle.
Step 1: Things You Need
1. Acetone (Nail polish remover)
2. Candle or Lighter
3. Needle
4. Aluminium foil
Step 2: Dip the Nozzle in Acetone
The higher the concentration of acetone lesser the time required.
I use nail polish remover because they are cheap and easy to get.
Leave it for 20-30 minutes.
Step 3: Clean the Big End Using Needle
Remove the plastic using a needle.
There will be plastic left over a the tip which cannot be cleaned using needle.
Step 4: Wrap the Nozzle
Wrap the nozzle in Aluminium foil. Leave the top end open so that the fumes can go out.
Step 5: Bring It Near to Flame
Hold the nozzle into the flame for around 5 minutes. Remove foil and check the nozzle
- If there is still plastic heat it again.
- If it is clean then wash the nozzle and remove any leftovers using needle.
Step 6: Thats It..:-)
Hold it near to any light source and check whether it is clean.
    • Faux-Real Contest
      Faux-Real Contest
    • Build a Tool Contest
    • Organization Contest
    15 Discussions
    MRDC
    3 years ago on Introduction
    This was my First Instructable. So please do share your ideas and suggestions to improve my future projects. Please feel free to comment ,share and favorite if you liked it.Hope you enjoyed it as much as I did. Thank you.
    voblak
    3 years ago
    modern nail polish removers aren't made from aceton. And if you compare the price to aceton is aceton cheaper (3-5€/l)
    mach1950voblak
    Reply 1 year ago
    Correct! And nail polish removers often have oil in them to prevent drying of delicate ladies hands.
    eatyone
    Thanks for this instructable. But, i think that it's ok just for ABS, Acetone has no effect on PLA.
    DrMakereatyone
    Reply 1 year ago
    You can use chloroform for pla :)
    AndrewH333
    2 years ago
    How do you get the nozzle off? I assume I use an adjustable spanner but I don't want to wreck it doing the wrong thing.
    WhiteRenard
    2 years ago
    Excellent idea wrapping it in foil, before this I just held them over stove but now with foil they'll look cleaner! :P
    mreber
    3 years ago
    I use these, Personally:
    http://www.amazon.com/Printer-Clogged-Extruder-Makerbot-filament/dp/B016O43KKC/ref=sr_1_22?ie=UTF8&qid=1453416225&sr=8-22&keywords=3d+printer+clean
    unix_guru
    3 years ago
    I found a sewing pin that was about 1/3mm, and fit through the nozzle to help clean it.
    Thank you for this.
    GarlandS1
    3 years ago
    Just to confirm, tried this with a 0.4 mm nozzle that had PLA clogged in it. Worked for me by attaching the M6 thread of the nozzle onto a nut and holding that with a set of helping hands over a flame for about 5-6 mins. And then every couple of mins I'd slide a piece of steel wire just to see if the PLA has evaporated. PLA burns with a sweet scent so you'll know when it stops burning and fully evaporated. Flush it under cold water and wholla! :) Presto. Key element in this instructible is the aluminum foil. Prevents soot from building up on the nozzle. Great work MRDC!
    arpruss
    Though around they do sell acetone in the nail polish remover part of the stores. It's 100% acetone, but oddly it doesn't have the scary warning labels that the acetone sold in the hardware section does.
    peabody1929
    3 years ago
    A steel guitar string will go through the nozzle end.
    RedFishRyan
    3 years ago
    Very good! This is very descriptive and every thing that was in words was in pictures. I have no suggestions for you! Great Job! :P
